Question about Datamax I-4208 Thermal Label Printer
Labels run through, but nothing is printed on it
I have label matrix 8 installed and when i go to print a test label the labels do not print out. The labels are ran through like normal, but nothing is printed on them. I have the printer selected in the software. I have looked at all settings and can not resolve this problem.
    Sergeant:
    Champion:
  • 317 Answers
Test it using Windows Printers first, if you get a TEST label, you are ok. Make sure the ribbon type is the one pertaining to your label type, also make sure the temperature is between 12-13 to make sure you have a good burn. If this does not work, flip the ribbon to have it print on the REVERSE, some ribbons are weird like this.
Posted on Sep 21, 2009
I've had that happen a couple of times over the past few years and what I found each time was that the printhead latch was not pushed quite all the way down. Lifting it and locking it down tight fixed the problem. If yours never prints at all it is probably a different problem.
  • 155 Answers
When the printer receives print information, the power LED blinks, but then you do not receive anything, check the communication cable LPT or serial is the speed of communication and the correct port (COM1, COM2, etc) .
Posted on Mar 10, 2009
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
1} go to the MEDIA AND RIBBON CALIBRATION,
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Jan 21, 2011 | Zebra Z4M Printer
Dymo label writer 400 turbo will not print
Uninstall the software and disconnect the printer from your PC. Then reinstall version 8 of the Dymo Software (without the printer connected) and connect the printer when prompted by the software.
Make sure you are using version 8 of the dymo label software - it is compatible with Windows 7.
Apr 24, 2010 | Dymo LabelWriter 400 Turbo Thermal Printer
Smart LabelPrinter Seiko 440
The code between the labels indicates either you are using labels designed for another model or that it is thinking it has a shippinhg label opr some lareger type installed. IT is more likely to be the first option, you are usinjg the wrong coded labels
Please rate my help++++Thanks for using FIXYA
Dec 06, 2009 | Seiko Smart Label Printer Pro Thermal
Display reads ready, but when print is press the labels run but nothing is printed on the labels.
Is your label "direct thermal"? or using a ribbon to print.
If using ribbon, high probability that you install the ribbon the other way around.
Aug 20, 2009 | Datamax DMX-I-4208 Label Printer
I am printing individual labels and want the stop after printing the label - goes down 4 or 5 labels
You have to go into your printer settings and change the size of the "paper" you are printing to so that it matches the size of the labels you are printing to.
Jul 15, 2009 | Panasonic KX-P2023 Matrix Printer
We have a microline 320 turbo. we installed a new dell computer and now cant get the printer to print corectly on contineas feed labels. The print head starts on the right side and prints off the sheet...
Try downloading and installing an updated driver for your printer.
Here is the driver download page for your printer: MICROLINE 320 TURBO < Drivers & software
Select your operative system, download the file, then run the installer.
Mar 03, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Not Printing Correctly
Try reinstalling the printer driver using the CD with label on it LX-300+.
Sep 25, 2008 | Epson LX-300 Matrix Printer
Will not print labels
you have connected two printers on a data switch.right.
1. Print test page through Printer driver.
2. If you are using command for printing on Intermec printer, you should not use generic printer.
3. Interchange the cable connected to printers
May 01, 2008 | Intermec EasyCoder PC4 Label Printer
Okidata ml390/391 Turbo
you have to set this on your computer. when the print box comes up you need to choose the label catagory to make your printer print labels just right
Aug 06, 2007 | OKI MICROLINE® ML390 Matrix Printer
Datamax I-4208 Thermal Label Printer Logo
303 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
