Question about Sharp AR-5316 Advanced Digital Imager Copier
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
    President:
  • Sharp Master
  • 990 Answers
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Posted on Jan 28, 2009
  • hmusafir Oct 15, 2011
    Thanks. This worked for me !
ERROR CODE 4H IN DIGITAL SHARP PHOTOCOPY AR-5316E
Posted on Aug 17, 2011
  • Sharp Expert
  • 316 Answers
Heat roller abnormally low temperature
Posted on Oct 04, 2012
    Habit-Forming:
  • 41 Answers
Press:
# --> interrupt --> clear --> interupt
reset : 14 --> start
Posted on Sep 10, 2012
Code H4 comes up when the sharp copier ar-153e is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
H4 normally is the problem with the fuse unit caused by thermistors or therm-state charge them then clean it by sim 14 but first check if the connector and fame then do sim 5-02 to check the lamp status
Oct 23, 2015 | Sharp Office Equipment & Supplies
Error h4 sharp ar-5316 can you help me ?
H4 indicates "low temperature", possibly caused by a failure of the heater lamp or fuser. Sometimes this error is shown without an actual damage when the power cord is pulled without shutting down the copier first.
To cancel the error code, press [CLEAR], [AUTO], [CLEAR], [AUTO] in rapid succession. The display should go blank. Next, select 14 (clear low temperature code), press [START]. Finally, switch off and on the machine.
If there was no actual damage (i.e. power cord pulled), the machine should be OK again. If the error persists, immediately or after short time of operation, you will need to contact Sharp technical service for repair.
Jan 08, 2011 | Sharp AR-5316 Advanced Digital Imager...
H4 error on sharp ar-5316
H4-00 Heat roller low temperature detection
Nov 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
I have H4 error on my Sharp AR5516 copier. What should I do?
For H4 enter the following codes # interrupt C interrupt 14 Start button twice For ch check whether all the doors(side door,front door) are closed.
#Kintu Dennis Kentus
Aug 14, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
Jul 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-5316 errors
heat roller low temperature direction
Jun 24, 2010 | Sharp AR-5316 Advanced Digital Imager...
H4 error for ar-5316
Reset the error by pressing [#] [interupt] [ C] [interupt] [1] [4] [start]
If the problem persists check the heater lamp and the thermostat by ohm meter
May 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-5316
I am getting a problem code H4 for sharp copier when i start the machine. what is the problem. is ther any solution for the problem of the said model.
Aug 28, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
1,859 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
