Question about Canon PowerShot S1 IS Digital Camera
Fuzzy image LCD screen is unfocused. In playback mode will not scroll either way. Images also will not focus.
I have a problem Canon PowerShot S1 "Code E01" , and also please help me to provide me Schematic Diagram to solve this problem.
Posted on Feb 16, 2009
I HAVE A NEW POWER SHOT SX130 IS (CANNON0 I DO NOT KNOW HOW TODELETE THE DOWNLOADED PICTURES FROM THE MEMORY CARD
You can delete photos from your SX130 IS in two ways:
To Delete Photos Individually:
  1. Press Playback Mode button (looks like a play button and is located on the top right on the LCD-side of your camera)
  2. The last image you took will appear on the LCD screen.
  3. Use the Left & Right arrow keys or turn scroll wheel to cycle through your images
  4. Once you find an image you want to delete, press the Trash button. The image will be erased.
  5. Press the Playback Mode button or the FUNC/SET buttons to exit when done
To Delete ALL Photos
  1. Press the MENU button (bottom right button on LCD-side of camera) to bring up the Menu screen
  2. On the Playback tab (Looks like a Play button icon), use the arrow buttons or turn scroll wheel to scroll down to Erase. Press the FUNC/SET button.
  3. You now have three options Select, Select Range, and All images. Select will allow you to delete individual images, Select Range will allow you to select a series of images, and All images will delete all images from memory. This last one is the option we are looking for.
  4. Use the arrow keys or scroll wheel to choose All images
  5. Use the arrow key or scroll wheel to select OK when the Erase confirmation screen pops up.
  6. Your images will be erased!
Mar 14, 2011 | Canon Cameras
Fuji Finepix S5700 digital camera. LCD green-pink
try to playback previous images ..If screen looks good on playback and or main menu..Camera likely has problem with CCD imager and camer digital processor board.If camera also looks bad on playback and menu..its possible the LCD IS BAD..easy test is to hook up camera on a monitor or computer and see what picture on camera mode looks like..If it also looks bad on a different monitor..Then CCD imager could be bad..If playback and camera mode lokk bad on monitor ..then you have a video process board problem ...please let me know
Dec 18, 2007 | Fuji FinePix S5700 Digital Camera
S1IS canon camera
Apparently the vendor-supplied CCD image sensor used in this Canon digital camera may cause the following malfunction: When the product is used in recording or playback mode, the LCD screen and/or electronic viewfinder may exhibit either a distorted image or no image at all.
To determine if the CCD (image sensor) is working properly, follow these steps:
1. Insert a memory card with known good images on it into the camera.
2. Power the camera on to the Playback mode.
3. Press the DISPLAY (DISP) button to enable the LCD panel, and observe
the LCD.
a. If the images are displayed properly, please proceed to step
four.
b. If the images are not displayed, or a "NO IMAGES" message
appears, please ensure that the memory card contains known good images.
c. If the card contains known good images, and the issue persists
with a second memory card, the camera will require service.
4. Switch the camera to the Camera mode. You may use any shooting mode
(i.e. Auto, Manual).
5. Press the DISPLAY (DISP) button to enable the LCD panel.
6. Point the camera at a well-lit scene and observe the LCD and/or
viewfinder. If the scene the camera is pointed at appears on the LCD
and/or viewfinder, the CCD is operating properly. If the LCD and/or
viewfinder remain black, the camera requires service.
Effective immediately, and regardless of warranty status, Canon will
repair, free of charge, products exhibiting the above-mentioned
malfunction if the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair.
Regards.
Dec 01, 2009 | Canon PowerShot S1 IS Digital Camera
Unable to focus with magnification greater than 40x
You must collimate the scope. Watch this video.
http://www.andysshotglass.com/Collimating.html
Also the maximum magnification of any telescope is NEVER more than 50 times aperture, so your scope is 400 power. BUT everything including the sky must be perfect. Usually 30-40 times aperture is the most you will ever get.
Oct 20, 2009 | Orion Optics
LCD screen not sharp / focusing when taking pictures
This camera is ancient by today's standards, at least 8 years old.
Your focus problem is that the back display is very low resolution, so it will never show a sharp image. 9MP should give a decent image when you view it on a computer. If not, you probably need to part with the camera. it is not worth much these days anyway.
May 01, 2017 | Canon Powershot SX110 IS Digital Camera...
Pt5499hd akai
It looks like you may to replace the convergence units. It will require repair.
Jun 03, 2008 | Televison & Video
Video Camera Malfunction
http://www.circuitcity.com/ccd/productDetail.do?oid=170896
This is a link that has camera reviews on it.
Apparently the camera that someone reviewed there goes fuzzy.
Mar 16, 2008 | Cameras
Horizontal fuzzy purple images
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Feb 21, 2008 | Canon PowerShot A95 Digital Camera
Unfocused
Take it back to whoever TRIED to fix it.
Dec 26, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Trouble with lcd screen
Have you tried it with another card? might help to narrow it down. Post back
Jun 09, 2006 | Fuji FinePix F401 Digital Camera
Canon PowerShot S1 IS Digital Camera Logo
117 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
