Question about HP Officejet 5610 All-In-One InkJet Printer
Fax problems with hp 5600
I'm having problems faxing documents. it is giving me an error but when im using the hp disk it is telling me certain file are missing. what do i do?
I have fax pluged into phone line and every time I try to send it states fax failed. How do I correct
Posted on Feb 19, 2009
Lexmark 5600 how can a I scan or make it a word document or pdf file
You will need the Lexmark OCR scan software to scan a document from the printer to your computer and save the file as PDF, word document, etc. The Lexmark OCR scan software is only available in the installation disk. If you don't have the disk or you lost it, contact Lexmark technical support to request for it. Thank you for choosing Lexmark.
Sep 14, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
Fax sends certain pages in duplicate
If it only happens with that one vendor, the problem is almost certainly either on their end or somewhere in the interaction between the two fax machines.
The most likely answer is that their fax machine has a problem receiving some pages (either because the line is noisy or for another reason) so it has to reprint them. You could tell your vendor to try turning off error correction on their fax machine and see if that makes a difference.
Hope that helps.
Jul 05, 2010 | HP 920 Plain Paper Fax
Hp4300 series disc won't work with my new hp window vista computer my printer is a 4315v
Please perform the steps given below and check if yuo are able to fax
1. Open a MS Word Document.
2. Click File -> Send to -> Recipient using a fax modem.
3. Follow the instructions given in the fax wizard. Ensure that you select the HP all-in-one as the fax program.
Now check whether you are able to send the fax.
OR
Try setting up the Fax once again
=== Fax Setup wizard ===
- Double-click on the HP Solution Center to open it.
- Go to Settings --> Fax Settings & Setup --> Fax Setup Wizard.
Complete the fax setup wizard and then, try to fax
Vishwanath V U
May 19, 2009 | HP Officejet 4315v All-In-One InkJet...
Since I'm unable to fax through the computer I'm using my HP J4680 All In One as a free standing fax machine. The directions that came with it stink. I enter that I want to fax in color and put the...
Are you pressing the GREEN start button?
If you think HP's are junk, you wouldn't want to deal with the rest of the **** out there.
HP's business nowadays is to sell INK not printers.
IMHO, stick w/HP
Jan 21, 2009 | Office Equipment & Supplies
When trying to fax connects ok but comes back failed error 388
A list of HP aio error codes:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
You could try running the Fax test. Press setup > Tool> Run Fax test.
This will give you instructions about what you need to check and what you need to do if it failed on some of the tests.
Then try to send a fax to the HP fax test server detailed below:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00259105&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Jan 19, 2009 | HP Photosmart 2410 All-In-One InkJet...
Error message 388
Hi! Error 388 means the local machine has originated a fax session and detected a remote fax machine but has been unable to detect any T30 frames.
If the machine is in V.17 mode, it is likely the connection has been interrupted. In V.34 mode is also possible for this error to occur due to compatibility problems with certain machines and/or line conditions.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
2. Disable V.34 on the local machine and attempt the transmission using the V.17 mode. ( See error 227 for changing to a slower speed or disabling V.34 .)
Use the link below-
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1153695&prodTypeId=18972&prodSeriesId=1153695&objectID=buu02549
Jan 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
In what folder are received faxes stored to on XP
the address of fax folder is given to the server. thats why it is giving such error. normally files received in my documents "my received files" folder.
Nov 29, 2008 | HP LaserJet 3300mfp All-In-One Printer
Printing
hi,
here are the things that i want you to follow to somehow resolve your issue.
1. On your computer, click on start then go to control panel
2. inside control panel open the PRINTERS and FAXES (XP) or PRINTER (VISTA).
3. make sure change the default printer icon to the HP Officejet 5600 series.
- right click HP Officejet 5600 series and choose "set as default printer"
4. then try printing,
note: the reason why you encounter that problem is because the default printer icon is the "HP officejet 5600 series fax".
best regards
adonscott
Apr 04, 2008 | HP Officejet 5610 All-In-One InkJet...
FAx Error
I understand that you are receiving the error "fax not sent" and the transaction report Error 389*. while sending fax.
The issue that you are experiencing is due to communication, however please follow the instructions from the below article to get the issue resolved.
Here is the web document:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=buu02549
Just copy and paste the entire link into the Internet browser's address bar and press enter.
This should resolve the issue that you are experiencing with.
Regards,
Lawrence
Feb 06, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
155 people viewed this question
Ben Johnson
