Question about Sharper Image Ionic Breeze GP SI730 Air Purifier
Not running quietly
After running my Ionic Breeze GP constantly for over a year(with great results), I noticed that the indicator light no longer comes on. This is the little orange light that tells you when it is time to clean the fins that trap the particles clean from the air. Just about every two weeks this light would come on. If I ignored it I noticed a very large increase in coughing. Well now it no longer lights but still every two weeks I would clean it as per the instructions. This last time however before cleaning I noticed a noise coming from the Breeze. This was intermitant and almost unnoticable. I assumed it was time to clean it and that the noise would stop after doing so. That was not the solution however. The noise is hard for me to discribe accurately. It sounds as though the Breeze is turning on and off several times in a ten minute span. I am not sure but it almost sounds as if there is electrical arcing. I watched very carefully while it was running and cannot see any signs of shorting. I have eliminated the obvious possible causes. For instance there is no fluid spilled inside and no small paricles or debris as far as I can tell. The sound is very faint and cannot be heard above the normal sounds in the room. But at night when all is quiet it is very unsettling to hear it come and go as it does. I have shut of the Breeze until I can figure this out. As I said though my breathing discomfort increases immediately. Is this just a harmless sound that doesn't matter or is this a symptom of an even larger problem needing repair?
  • 135 Answers
"A blinking light indicates when the blades should be wiped clean with a damp cloth." I actually had a "handyman" contract last year to visit an elderly gentleman once a month and clean all 9 of his Ionic Breeze GP air purifiers. Before I did that for him, they would make hissing noises and he really didn't like that. Here's how to clean the operative compnents of these machines: First, unplug the machine and place on a work surface, such as a table or kitchen counter. Second, remove the metal blade insert from the top by gripping the release tab and lifting it up and out. Also remove the front and back grilles by pressing on the plastic tab at the bottom and lifting up on them. Third, use a damp rag or paper towel to wipe the three metal blades clean. Do not immerse this assembly in water, because it has to be completely dry when re-installing it in the machine. Fourth, use a small piece of damp paper towel to VERY GENTLY wipe clean the two thin wires inside the unit. These are located behind the two rubbery flat blades just inside the unit and can be accessed from the front side. You won't damage these rubbery flat blades by pushing your hand gently between them, but be VERY CAREFUL when wiping the wires clean. (This step is important, as the wires must be clean.) Fifth, using another bit of damp paper towel, carefully clean the wire attached to the inside of the front grille. Dry this off with a dry bit of paper towel, then clean any accumulated dirt off the front & back grilles. Check the metal contact near the bottom of the front grille (attached to the wire) to verify that it's clean and will make good electrical contact. Sixth, pick the unit up and turn it upside-down & right-side up about 6 to 8 times. The two wires inside have plastic beads on them that slide up and down the wires. This brushes any bits of leftover dust or lint off of the wires. (Again, these wires must be VERY clean.) Seventh, replace the front and back plastic grilles by placing them in their slots and sliding them down to snap into place. Verify that the assembly with the three metal blades is COMPLETELY dry, using a hair dryer if necessary to dry off damp areas, then slide it back into place from the top of the machine. Now the cleaning process is done, so plug the unit in and turn it on to test operation. If it makes ANY noise, then some component is not completely cleaned off, or still has a presence of moisture, which must be completely dried off before the machine is ready for operation. Hope this helps! ;)
Posted on Aug 05, 2007
MIDI Ionic Breeze quit working
Unit seems to need reset...To do this simply, with unit still plugged in, set to off by selecting on button until there are no high, med, or low lights on. unplug unit from wall for about 15 seconds then plug back into wall socket and select your favorite setting high, med. or low. The order in which you perform this task must be as stated above and the unit must be clean and the door and cleaning rod must be in home position. Hope this helps, mines working fine now but took a couple tries to find right order to reset.
Sep 16, 2009 | Sharper Image Professional Plus Ionic...
Ionic breeze quadra constantly blinking cleaning overdue, evenghough it is clean.
If it still works after you cleaned it, consider yourself lucky. If light blinking bothers you, just put a piece of black electrical tape over it and enjoy it. That unit has been driving me nuts for years. I cleaned mine and now it doesn't work at all. A blinking light I could put up with, with a little tape. Enjoy it because it still works.
Apr 05, 2009 | Sharper Image Professional Plus Ionic...
I haven't heard of a class action suit.  I've heard they recalled them.  I don't know if it's good any since they are chapter 11 right now.
They went out of business defending Ionic Breeze and lost due to Consumer Reports stating it wasn't effective as well as EPA data indicating that ionizers are harmful to use.
By the end of the year, The Consumer Products Safety Commission is going to make a decision on all ionizers sold in the US.  It's possible no one will be selling them much longer.  The industry should have been regulated years ago and it wasn't.  The EPA knew they were harmful and didn't step in to take them off the market.
Sep 09, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Sharper Image Design Ionic Breeze GP Professional Series Mod 1861
My professional series Ionic breeze GP blows out what seems to be clean air but the purple lights inside it are no longer working. Can anyone tell me where I can find replacement bulbs or just what I need to do to get it working again. I got it as a gift 4 or so years ago. The gift giver says there was a 5 year warranty on it but I am not sure. Any advice would be helpful.
thank you. Nicole
Aug 28, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
I have the Ionic breeze Professional Series GP. It wont turn its getting no power, but it is plugged in. It has no lights nothing!
Ionic Breeze is no longer being supported by Sharper Image. They did have a recall program on the product but I believe it has been discontinued.
The product was proven not to clean the air by Consumer Reports as well as EPA studies. Sharper Image tried to sue but lost.
Consumer Products Safety Commission is reviewing all ionizers and will make a decision by the end of the year. Due to health issues with using the machines themselves, these machines may disappear for good.
Aug 18, 2008 | Sharper Image Professional Plus Ionic...
Ionic Breeze GP Sharper Image
Sharper Image ionizers are no longer being serviced. What got them into trouble in the first place was the fact that they were not cleaning the air and that the air they were filtering was hazardous some peoples health. This was based on data by Consumer Reports as well as the EPA. They went to court on it and they lost.
Sharper Image was offering a rebate to people who had purchased ionizers.
The Consumer Products Safety Commission is going to be making a decision on ionizers by the end of the year. It could be that they will no longer be sold in the US next year since they are ineffective and can cause health problems.
This is an industry that should have been regulated years ago just by EPA data alone. The idea that charging the air around you gets rid of stuff is a joke. In the copier industry that I work in we are told that it is bad since copiers create ozones in the same way.
Jul 22, 2008 | Sharper Image Professional Plus Ionic...
Sharper Image no longer supports Ionic Breeze machines. They recalled them a few months back since Consumer Reports and the EPA has determined that they weren't working and can even cause health hazards during usage. Sharper Image sued an lost forcing the company in bankruptcy.
The Consumer Products Safety Commission is going to make a decision on sales of all ionizers in the U.S. by the end of the year. It's looking like you won't be seeing these around much longer.
Jul 06, 2008 | Sharper Image Ionic Breeze Air Freshener...
Ionic Breeze Silent Air Purifier GP
Ionic Breeze products are no longer being supported because Sharper Image has gone into bankruptcy because the units were proven to be ineffective for cleaning the air by Consumer Reports magazine and by EPA studies. In face they have proven that ionizers can be harmful to use if you have breathing problems.
Here is an article about Sharper Image
Here is the EPA article
Jun 30, 2008 | Sharper Image Professional Plus Ionic...
No power.
there is a small micro switch that is actuated by the grid. This is mounted on the side of the top control piece. There are two wires attached to the little circuit board, usually one is corroded so you need to cut it back and soder it to the center pin of the switch.
Jan 29, 2008 | Sharper Image Ionic Breeze GP (SI730) Air...
Sharper Image Ionic Breeze GP SI730 Air Purifier Logo
168 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
