Can't focus. IN 24 Projector has new lamp. Can zoom, but cannot adjust ''dial'' for focus to get a better picture. Pushing auto image button did not help..
    Problem Solver:
  • 5 Answers
Sounds like the projection lens i jammed. you will have to have the lens replaced. need to send to your local ASC
Posted on Feb 03, 2009
How can I adjust focus?
Turn the grey ring around the lens (where the light comes from) until the image is sharp.
Apr 11, 2016 | NEC VT595 Projector
When I zoom in to take a picture I get it focused I hit the button and the picture shows up not zoomed?
How are you zooming in? If you are using a button to zoom, that is to check the focus: it's just enlarging the image for your convenience during focusing. In order to get a zoomed-in image when press the shutter button, you need to adjust the zoom ring manually on the lens barrel before taking the picture.
Sep 24, 2014 | Canon EOS 600D Rebel T3i Digital Camera
Why won't my fugi finepix s4500 won't focus sharply ?
No good working auto focus can have many causes.
Like the camera is in Macro mode, or manual focus. The best thing to try, is to switch your camera to the auto mode. The camera logo on your mode dial. And then shoot some pictures. There should be enough light and contrast in the frame, on the place you want the camera to focus on. Sometimes you have to chose an object, with enough details and contrast, on the same distance as the object you want to take a picture of. Then press the shutter half way, till the camera is in focus. the indicator lamp next to the mode dial glows green. Then frame the picture like you want it taken end only than press the shutter completely.
If the camera does focus correct in the auto mode, then you can check, why it did not focus before.
Check page 19 of the manual, to see how to use the shutter release button, for correct focus.
Apr 23, 2014 | Fuji Finepix S1500 10.0 Megapixel 12x...
The image needs to be wider on the screen - not asdjusted up and down
Procedure
1,Using the buttons on the projector,perform zoom adjustment or keystone correction. The Image Shift adjustment screen is displayed after you finish making adjustments.
2,Adjust projection position.
3,Press the ESC button to close the adjustment screen.
note:the projection position cannot be adjusted when zoom is set to be maximum "wide" position
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 18, 2014 | Epson PowerLite S3 Multimedia Projector
I have an Infocus LP70. My question/problem is in regards to the lens. I dropped the projector from about a foot off the carpet and onto the lens. The focus/zoom became jammed together, AND the lens came...
What I would try to do is, loosen the screw so its not stiff to adjust, adjust the lens to the right position then tighten up the screw again. Hopefully this should work for you!!
Nov 03, 2013 | ASK Proxima InFocus LP70, LP70+ and...
White spots on screen i have changed the lamp
It's probably you have a busted DMD chip, have your technician replace that, better yet buy a new projector because replacing that chip costs almost a brand new unit.
Nov 19, 2011 | BenQ Office Equipment & Supplies
How do I zoom and focus the LV 7350? It is ceiling mounted. I want to make the image smaller so that people in the audience can see the image over the heads of those in front.
There are zzom and focus buttons on the remote if you have it. If not, use a safe ladder and use the zoom/focus buttons on the projector itself.
Good Luck
Aug 13, 2010 | Canon LV-LP11 Projector Lamp for LV-7345,...
The projector is approximately 4 years old & on average runs for about 60 hours per week, 40 weeks of the year. After fitting a new lamp last October & resetting the projector, the image is still...
Additional information is required for us to assist. Can you better describe what you mean by "poor image"? Are the colors separated? Is the picture out of focus? Are the colors wrong?
Please describe the picture or post a picture of the screen if you can.
Thanks,
Dan
Feb 03, 2010 | Sanyo PLC-XP57 LCD Projector
Sanyo projector image problem
Can you describe the issue?
check out fixmyprojector.com
they can fix this problem for you!
Jan 04, 2009 | InFocus ScreenPlay 4805 Multimedia...
Switching from auto to manual focus
AF/MF (Auto Focus/Manual Focus) * The AF/MF function works in CAMERA, M.REC mode only. * In most situations, it is better to use the automatic focus feature, as it enables you to concentrate on the creative side of your recording. * Manual focusing may be necessary under certain conditions that make automatic focusing difficult and/or unreliable. Auto Focusing * If you are inexperienced in the use of camcorders, we recommend that you make use of Auto Focus. Manual Focusing In the following situations, you may obtain better results by adjusting the focus manually: * A picture containing several objects, some close to the camcorder, others further away. * A person enveloped in fog or surrounded by snow. * Very shiny or glossy surfaces like a car. * People or objects moving constantly or quickly like an athlete or a crowd. Follow These Simple Steps To Set The Manual Focus 1. Set the power switch to CAMERA mode. 2. Turn the MENU DIAL up or down until the FOCUS is highlighted and then press the ENTER button. M. FOCUS(MF) will display. 3. Turn the MENU DIAL up or down until the object is in focus. Zoom out a little if focusing is difficult. 4. To return to AF (Auto Focus: ), press the ENTER button again.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
410 people viewed this question
jasbo
jasbo
