Question about Vulcan 60XLC Gas Kitchen Range
Vulcan Commercial Oven Serial # 481497152 - Oven Stay Lit
  • Does your oven pilot stay lit for a while and then go out or does it go out when you release the safety button?
    Scholar:
  • 127 Answers
If the oven won't shut off when the thermostat is turned to off, the thermostat will have to be replaced.
Posted on Feb 25, 2010
Will not stay on will shut off
Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
forum.appliancepartspros.com/oven.../482851-whirlpool-gas-oven-will-...
Jun 20, 2012 - 2 posts - ‎1 author
My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
Feb 19, 2013
Oven does not stay lit
Jun 19, 2012
Oven will ignite but will not stay lit
Aug 3, 2010
Gas Oven won't stay lit
Mar 25, 2008
More results from forum.appliancepartspros.com
Jan 04, 2016 | Ovens
Royal commercial oven pilot
replace the thermocouple first. it can be purchased at you local hardware store.
if that does not fix it, you will need to replace the Baso, pilot safety. that can be purchased at partstown.com
Jul 07, 2013 | Ovens
I have an old Vulcan 6 burner commercial gas stove with a 24" griddle. The gas was turned off during a remodel. Now the gas is back on and the gas burners work fine but I cannot get the oven pilot light to...
Hi- This should have a gas Safety Valve, this is the main valve to the oven (this probably has 2). If you remove the lower panel under the doors they are probably right there. Looks like a large gas valve with a button on it, sometimes the button is red. You need to hold in that button while lighting the pilot and keep holding it in for a few seconds until the thermocouple gets hot enough to tell the valve to keep the pilot on. You'll have to do this for both ovens if there are 2 valves. It's possible the valves are located somewhere else on the range so you may have to hunt a bit. If the pilots still won't stay lit you may need new thermocouples in which case I'd call a Tech out to look at it. Hope this helps. Good Luck.
Sep 24, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
One of the top burner pilot lights will not stay
You probably have grease that has gotten into the pilot. Turn off the gas to the pilot and detach the pilot tubing and pilot tip. It sometimes helps to take a propane torch and heat up the pilot tip and tubing, paying special attention to the first bend from the pilot tip. Get it red hot and tap out any ash from the inside. You may have to **** out the tubing with a piece of bare wire or blow it out with WD-40. With the oven pilot, check the pilot flame. If low, adjust. If OK, replace the thermocouple. If neither of these corrects the problem, replace the pilot satety. I always recommend a new thermocouple with a new pilot safety.
Feb 23, 2010 | Vulcan Kitchen Ranges
I have a Garland stove series #G286, the oven won't stay lit.
it sounds like a venting problem, the oven heats up and it not venting,it will put the pilot out.
Aug 27, 2009 | Garland H286 Gas Kitchen Range
Oven keeps randomly shutting off. wont stay lit
pilot sensing device should have tip in the flame only, calibration of thermostat possible with butto removed, if standing pilot is going out possible thermocouple or pilot generator or gas valve bad! could also be a safety hi limit opening in control circuit if has one?
Aug 23, 2009 | Vulcan Ovens
My vulcan burners lit but I can't get the OVEN pilot to light . What are the steps to light the oven ?
use matches,the pilot ligth is hard to replace unless in the tecnician can do,and hard to find the parts.
tnx.gerbee
Jul 04, 2009 | Vulcan GCO2D Gas Single Oven
Oven pilot light will not stay lit
The thermocouple is bad this is the probe that sits next to the pilot,the pilot flame heats the thermocouple and then it sends a micro voltage to the valve to keep it lit.Goto hobartcorp.com and find your model then the part number.
Sep 04, 2008 | Vulcan 60L Gas Kitchen Range
Oven pilot light will not stay lit on Garland 6 burner, double stove, salamander commercial in home
Use a needle right where the pilot flame comes out. Should do the trick. GOODLUCK!!
Dec 16, 2007 | Garland H283 Gas Kitchen Range
Vulcan oven will not stay lit
I would take out the pilot and clean it up and see what happens,also look behind the unit and see if theres a gas regulator on the gas line,if so you will see a nut on it take it off with a pair of pliers and clean as well.that valve is actually the saftey valve,when the pilot lights the flame impinges on the thermocouple and that sends a millivolt back to that valve in order to open.if none of these resolve your problem i would replace the thermocouple first as this is a cheap part and easy to put on.if you need a part # i can give it to you.let me know.
Nov 16, 2007 | Ovens
Vulcan 60XLC Gas Kitchen Range Logo
273 people viewed this question
Top Vulcan Kitchen Ranges Experts
Treefrog15
Treefrog15
Oloyede Monsuru
Dan Webster
Dan Webster
Are you a Vulcan Kitchen Range Expert? Answer questions, earn points and help others
