Question about GE XL1800 1100 Watts Microwave Oven
Exploded a musical mug in spacemaker xl1800 microwave.
I put a mug of water in the microwave and it exploded and went on fire. It turns out it was a musical mug. The battery flew out the bottom of the mug and burst into flames. I've cleaned the microwave out and there doesn't seem to be any damage. I'm wondering if the battery exploding may have done some unseen damage and is it still safe to use my microwave.
  • GE Master
  • 9,047 Answers
If there's no damage it should be fine.
I would double-check for cracks, especially in the inner door glass and the screen / mesh.
If it looks fine, heat a cup of water in a microwave-safe container for about 2 minutes and see if it cooks without arcing or odd noises and that it boils in about 2 minutes.
As always, never leave a microwave unattended while running.
Posted on Jan 28, 2009
Somebody exploded an egg in Kitchenaid Microwave combo oven, and circuitboard went bad. Power but no heat. Coincidence?
The circuit board is in a separate section so the motherboard can't come into contact with the exploded egg. Was any liquid cleaning solution sprayed inside to clean up the mess? There might be some crevices where cleaning solution spray could work its way into the circuit board section since it's very close by. Always use a damp cloth instead of saturating the oven with cleaner.
Apr 24, 2014 | GE XL1800 1100 Watts Microwave Oven
GE Profile Spacemaker XL1800 microwave turntable
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
On some, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 28, 2013 | GE WB26X10037 Microwave Stirrer Motor
I have a GE Spacemaker XL1800 Adora Microwave (manufactured in 2004) and the light bulb went out but I can't located it to replace it. Where is it located? Thanks
If it is meant to be user replaceable, then your owner's manual will cover it.
If not, then you may need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Either way, you can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jan 17, 2011 | GE XL1800 1100 Watts Microwave Oven
I need a couple of bulbs for my undercounter Spacemaker GE Profile XL1800- do you have a reference or part number
Be sure to unplug the oven before removing or installing bulbs, or the circuit board may be damaged. We repair these all the time for that.
Let me know if I can help further.
Aug 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The surface light cover for my GE spacemaker xl1800 is broke, where can i find a replacement part? Thks!
Jul 31, 2009 | GE Microwave Ovens
When opening the door a venting sound immediately starts up.
The charcoal filter needs to be changed every 6-12 months, or sooner if it gets clogged.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts (including charcoal filters) by entering your full model number from the tag on the oven here.
Feb 11, 2009 | GE XL1800 1100 Watts Microwave Oven
GE Spacemake XL1800 whines every time it cooks works great the
The charcoal filter must be changed every 6-12 months, depending on how much and how the oven is used.
If a filter clogs, it will interfere with cooling and lead to magnetron damage.
It may also be putting a strain on the cooling fan or hood vent exhaust fan, or one of those fans may have a blade loose on the motor shaft.
You can usually find helpful exploded view diagrams and order parts (including filters) by entering your full model number here.
Dec 23, 2008 | GE XL1800 1100 Watts Microwave Oven
Broken handle on GE Spacemaker XL1800 microwave
New handles for microwaves can be bought on amazon. Take a look here Amazon com microwave handle and choose one (which fits). P.S. watch out on reviews and handle sizes. I hope this was helpful. cheers
Sep 07, 2008 | GE JVM1851BD 1100 Watts Microwave Oven
My ge profile spacemaker xl1800 turntable stopped it turns once in a while. What do I need to replace. Where can I find the part number?
It's probably a bad turntable motor or coupler.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
XL1800 still works fine but makes a lot of noise while on.
It may be the stirrer in the ceiling area.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Nov 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
128 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
