Question about RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower Case
Raidmax Sirius mid-tower case fan alarm
My side fan keeps shutting itself off making a highly annoying alarm go off for 10-30 second till it turns itself back on. Right now I can't afford to buy a new fan, so I just want to know how to make the alarm stop going off. One of my friends built this comp for me, but he is unavailable for a while and I can't use my comp when my girlfriend is sleeping because of the alarm. I'm not very computer literate (tech wise), but if someone could please tell me how to make this alarm stop going off, I would greatly appreciate it.
    Sniper:
  • 96 Answers
Here are some solutions:
1. Try to use some silicon oil in fan apertures to decrease rub
2. Try to manually (look for a mainboard's service software settings) decrease rotation speed if available
3. Less recomended: disconnect fan cable from mainboard and don't stress your computer (try not to overheat, - work with software that uses less resources) and buy a new one when available
Posted on Jan 28, 2009
Power button switch
Send a request to the following email address. Mention the exact model number like you did in your question and request a replacement front panel on/off switch. rma@raidmax.com
Nov 19, 2013 | RaidMax AURA ATX-927WB Black SECC Steel...
Installed a GA H55M USB3 motherboard in a Raidmax Tornado case. When I go to turn it on their is power for about for about a 1sec and the fans turn a couple of times and a couple of seconds later their is...
I once had something similar happen to me. Triple check to see that all connections are secure to the motherboard - a loose 20 pin ATX cable was the culprit in my case.
Hope that helps. Good luck!
Dec 09, 2010 | RaidMax Tornado ATX238WRP Black SECC Steel...
I need a motherboard that will fit in a Raidmax ATX1072BP Mid Tower ATX Computer Case!
Most desktop computer cases have a range of standard mount holes, standard offs.
I suggest you select a motherboard that suits your requirements.
To be sure that the motherboard will fit your case, take the motherboard mount base with you to the computer shop and place the motherboard of your choice on the base to see if the mounting holes line up.
You may need to upgrade the switch mode power supply to a higher power unit if the total power requirements is near the maximum the existing unit can deliver.
Dec 03, 2010 | RaidMax ATX1072BP MID TOWER ATX COMPUTER...
Raidmax Sirius case not turning on
Recheck the wiring. Make sure the fans are all plugged into the proper place. Then try reseating the RAM, video card, & cpu. Make sure you have applied a good thermal paste between cpu & heatsink as overheating can cause the system not to boot. Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower...
Raidmax 500w power slowly died, then wont turn back on.
1.-Your CPU fan is working?
2.-Your Power supply fan is working?
If not and following your description I think that you have to replace your power supply.
If you have the light on in the motherboard doesn't mean that your power supply is good.
Check the first to points above and if 1 and 2 are not working
Replace your power supply.
Let me know how it is going!
Thank you for using FIXYA!
Don't forget to rate my help
Pablo :-)
Oct 13, 2008 | RaidMax (ATX-612WBP) ATX Mid-Tower Case
Cant get sound from my pc
Please spell the name of the speakers again, I have no listing...accordianman
Mar 08, 2008 | RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower...
I broke my temp probe on my raidmax
if by the probe you understand front fan controller,yes,there are controlers to replace yours..just pay attention to fit in the bay..
Jan 21, 2008 | RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower...
Raidmax Scorpio ATX Mid-Tower Case
The on/off connector is the power labelled one. The one thing you may have to do is (if you have'nt already)connect the power connector from the PSU to the processor power supply, close by to it as it may not just run off the motherboard ZIF socket for it's power up.
Feb 07, 2007 | RaidMax Scorpio 868W ATX Mid-Tower Case
RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower Case Logo
447 people viewed this question
Top RaidMax Computers & Internet Experts
Mohammad Abumuailek
Mohammad Abumuailek
gaucherre
Are you a RaidMax Computer and Internet Expert? Answer questions, earn points and help others
