Question about Garden
Need diagram of how to replace snowblower belt
I have a tecumseh snowblower. The belt came off and I don't know which pulley it needs to go around. There are three. The machine is a TH098SA
thanks, Cindy
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hellocindy! the number you gave is for the engine.i need the boby model number and brand of machine.thank you.
Not sure my neighbor did it while I was on the phone.
thanks,
cindy
Posted on Jan 29, 2009
I have an Ariens ST724 7hp snowblower (model:924075 serial 005629) that needs to have the starter cup, recoil, and the 4 bolts that secure the recoil replaced. The problem is all of these parts are NO
In order to order engine you must look-up the engine itself. If this blower still has the original engine then it is a
Tecumseh HSK50-65496
Recoil Part Number TEC590604 Image
t_590604_000.jpg This item has been discontinued by Tecumseh, part number STE150-003 will work but does not have the handle cup.
Original Tecumseh Part
Replaces Tecumseh 590604 and 590605
Fits Models: H, HS, HSK
For use on Snow King Models
RECOIL STARTER ASSEMBLY TECUMSEH 590420A
Nov 10, 2014 | Garden
Snowblower starting problems
I have a sears snowblower and cannot remove the pulley, the bolt and are one.
Nov 29, 2013 | Tecumseh Snowblower Snow Blower Starter...
I got a yard king snowblower with a 10hp Tecumseh I need a belt routing diagram for please help!!!!!!
Should be able to Google your model and see the view.Here is an example of a parts manual http://www.outdoordistributors.com/pdf/Murray/MURRAY-MODEL-627804X89A-PARTS-LIST.pdf that may help you.You have to know the model # which you did not post.
Dec 27, 2012 | Cars & Trucks
Diagram for 5 pulley belt 98 pontiac transport.
start from bottom crankshaft pulley and ac compressor turn belt tensioner counterclockwise or lift forward then run pulley belt around crankshaft pulley and around AC compressor,run pulley belt around power steering pump then around alternator,once drive belt around alternator you done make sure drive is center of crankshaft pulley and AC compressor pulley.and belt back is center against water pump pulley before releasing the belt tensioner.
Aug 27, 2012 | Pontiac Trans Sport Cars & Trucks
Need a diagram for the drive belt on a wheel horse c 100 8 speed
i don't have a diagram but the belt goes around the trans pulley and around the engine pulley and the pulley from the clutch pedal goes under the top section of the belt pulling up in the center hope that helps you
Aug 18, 2012 | Garden
Need to replace serpentine belt on 2006 Nissan Altima. what are steps?
the first thing to do it locate the under hood diagram that shows the belt route. if there isn't one than be sure to make note or make your own diagram of the belt position and how it "snakes" around the pulleys and in what order. the next thing you need to do is locate the tension pulley. once you know which pulley is the tensioner you place a wrench and socket on the bolt in the center of that pulley. and turn it counter clockwise as you do you should notice the belt getting some slack as this happens slip the belt off the most accessible pulley. after you get the belt off the pulley be careful not to pinch your wrench on anything.once the tensioner has been released pull the belt out from around the other pulleys and replace with the new on pulling it around all but the most accessible pulley at which point you can reapply tension to the tension pulley and pull the belt around the last pulley before releasing and putting full tension on the belt take a good look and be sure that the belt is on all of the pulleys correctly then let off and voila thats that hope this helps
Dec 24, 2010 | 2006 Nissan Altima
Need the belt diagram for the water pump belt for a 95 Auroa
42161874BELT, REPLACE
  1. Release belt tension and remove belt from power steering and alternator pulleys. Twist belt to get between tensioner and front cover and between power steering pulley and engine mount bracket.
  2. Raise and support vehicle.
  3. Turn wheel to the extreme right and remove right side splash shield.
  4. Remove belt from crankshaft and A/C compressor pulleys. Twist belt to get between idler pulley and engine mount bracket.
  5. Lower vehicle.
  6. Twisting new belt to get past the front cover, install belt around power steering pump pulley, Fig. 15. Allow belt to hang free.
  7. Twist belt to get between tensioner and front cover, wrap belt around alternator.
  8. Remove belt from power steering pulley and set aside.
  9. Raise and support vehicle, then twist belt to get between tensioner and front cover, wrap belt around crankshaft and A/C compressor pulleys.
  10. Install right side splash shield and lower vehicle.
  11. Position belt around power steering pulley and release tensioner.
Nov 23, 2008 | 1995 Oldsmobile Aurora
Not sure how to replace the belt in my MTD, Wards snowblower
Remove the housing with the machine off
The idler pulley is designed to push up against the outside of the belt between the drive and motor pulleys when disegaged the belt should look like a loop like a race track
engage the blade clutch and watch to see if it presses up against the drive pully and the motor pulley
their should be a spring attached to the idler arm and i believe the new belt is dragging a little
you should be able to move the belt with your hands ( it should slip freely) rod is engaged or it pulls the idler away
Either a spring causes tension when the rod is engaged or it pulls the idler away
Keep working with it until it is free you may have an adjustment on the spring tension or the linkage rod has an adjustment
I am sure you can do this without an diagram good luck
Nov 18, 2008 | Sport & Outdoor - Others
All belts came off , 1986 740 gle 4 cly. with air nedd to know diagram
On the 92, the belt closest to the engine goes around the power steering pump, water pump, and crankshaft pulley.
The second belt goes around the alternator and the crankshaft pulley.
The third belt goes around the a/c and crankshaft pulley.
Jun 26, 2008 | 1991 Volvo 740
Garden Logo
452 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
