Question about Panasonic NV-SJ205 VHS VCR
Panasonic vcr nv-sj200
How can I switch to av?
  • Anonymous Mar 22, 2009
    ممكن اشوف ضبط باب NV-SJ205 VHS VCR
To select AV, you need to use the remote and press the input select button.
Posted on Dec 30, 2008
Go into your menu and select options. Then go to direct record and switch it off. Go out of the menu and then use the input select button on your remote to switch it to av.
Dirk
Posted on Mar 03, 2009
    Novelist:
    Champion:
  • 275 Answers
In some Panasonic models, AV gets auto selected when you insert the RCA plugs into the AV input sockets. Try it.
Posted on Jul 25, 2007
  • Demonic-2011
    Demonic-2011 Mar 05, 2011
    NV-SJ200 and NV-SJ400 (Z-mech series) with direct record allow AV to be selected via remote 'input select' or sequentially between channels either on main unit or remote CH UP/DOWN buttons. When the backup battery fails in these machines, direct record may be enabled by default. This is easy to correct. Go to menu, select 'option' scroll down to 'direct record' set it to 'off' and if the clock is wrong, set it to the current time. Press OK and you are done!
    Novelist:
    Champion:
  • 254 Answers
Panasonic has online manuals- enter your model number- I tried your model number but the search returned no results. Recheck and try here: http://service.us.panasonic.com/OperMan/ Most VCRs can select the audio/video input(s) via the remote- sometimes there is a button specifically for this purpose. Or, there may be a selection in the on-screen menu.
6ya staff
SOURCE:
How do I hook up my Toshiba DVD player to my old Daewoo Tv /vcr combo
what inputs does the old Daewood / VCR combo use is it RCA and Video cable on an AV input? How many Av inputs are there in TV ? Does the DVD player have AV out audio out (Yellow) RCA (Red and White). If you do not have enough AV inputs on the Tv use an AV switch box . and Switch two AV RCA inputs /DVD and VCR and into one output to the TV. You may be able to feed the AV out RCA out into the VCR AV in and switch the input on the VCR.
May 25, 2015 | Toshiba Televison & Video
When I switched my connection from HDMI to av on my ps3 I couldn't hear sound anymore why
Its completely understandable , lot of people face the same trouble switching between the two..
The first step is to make sure that your PS3 is on standby. In a more understandable term, just make sure that your PS3 is turned off but plugged into the wall to the point that the PS3 power light is showing red and not any other color. To switch PS3 HDMI to AV you will have to hold the power button down until it beeps twice. You will have to make sure that your PS3 is off before you begin holding the button down or it may not work successfully. This will tell the PS3 to switch back to AV video. You will have to do this every time you switch to and from PS3 HDMI to AV. This also means that you will have to select the option that allows HDMI every time you try to go back to the HDMI interface. One you do it once you will problem remember by heart on how to fix the problem of not being able to switch PS3 HDMI to AV interface.
Jan 30, 2014 | Video Game Consoles & Games
1. How do I watch the same movie on both screens on the Philips PET9422 37 9 in. Dual screen DVD players? 2. I bought a refurbished model but did not get a user's manual. How do I get one?
hi,
You can do the following to watch the same moving in both the screen.
1.Connect the AV out of both the unit together. with supplied av cord
2. If you want to watch the movie played on the first unit then put the DVD/AV IN switch of first monitor to DVD and the DVD/AV IN switch of second one to AV IN.Now you can watch the movie played on the first monitor on both monitors.
3. IF you want to watch movie played on the second unit then put DVD/AV IN switch of second monitor to DVD and the DVD/AV IN switch of the first monitor to AV IN. Now you can watch the movie played on the second monitor on both monitors.
I have the manual of the same . As it is large pdf file can't sent through fixya. If you can sent your email id through fixya will sent you the manual
ok
Jun 11, 2011 | Televison & Video
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
How to connect a DVD player and digital set top box simultaneously to the TV
Either use different AV entries or - if you have only one - use an AV switch like
http://www.meritline.com/4way-audio-video-av-rca-switch-translucent-blue-798---p-35487.aspx?source=nextaghdac
Mar 11, 2010 | Televison & Video
I have a mikomi ctv14440, and it is meant to be able to switch av so that you can plug in a game console,camera in the back.the problem i am having on both sets that i have just bought for my kids is...
The mikomi ctv14440 I have has a scart socket on the back. Plug in an scart to av phono adaptor which has an input/output switch. Set the switch to input and press AV on the remote control. Now you can use the mikomi ctv14440 as an AV monitor with suitable leads. Press TV on the remote control to return to normal TV.
Dec 28, 2009 | Televison & Video
IN TV i have not get a picture on av mode mean av is not switching in this tv IC 9380PS as microproccessor IC & 24c16 as memory IC
look to the IC near the AV jack there is a AV switch IC. try to replace it. but some tv use a large IC jungle which is the AV sw. is also inside that large IC.So study carefully if your tv has a separate AV sw. IC..
Jun 04, 2009 | Televison & Video
AV switch
hiya
the av on tv's are normally done automatically on detection of a video feed via the scart sockets. if yours does not have this feature then on ur remote u shud find a button that says tv/av
rik
Sep 02, 2008 | Sanyo HT27546 TV
Video swiching
have hook up to front av ports and tried to switch from video 1&2 and no change. To add to the problem it doesn't switch to video 2. thanks!
Apr 15, 2007 | JVC AV-36D503 36" TV
Panasonic NV-SJ205 VHS VCR Logo
819 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
