Question about Asrock P4I45GV R5 Motherboard
Check cmos error
I have a Asrock p4i45gv M Board,when everytime I power on my pc a message come,check cmos error,F2...and F1 continue,I think Its my Battery Problem,I change Battery,But still Show this Message,I make Load default Value also....My keyboard has problem that some of its Button does not work,Is it the Problem of Keyboard? sometimes show an error cmos/gvm..if anybody know the other solution pls tell me..
  • Nazmul Hasan Jul 25, 2007
    But This mother board has no jumper....like P3 motherboard,It has two pin jumper,which I also Make short..but the message which is came it reson for jumper shorting...but I make bios defaylt value but still come error..
  • Nazmul Hasan Jul 26, 2007
    Dear senthu,
    Thanks for your trying. Automatically I slove my problem,I use a just
    new Battery so I have to need it charge.So when I worked on PC for 3 hours continiously,the Battery was fully Charged.Now I have no error, showing on Bios.After buying a new battery,I didnt have enough time to open pc,I just worked for 10 or five mintue, I just check my mail,and shut down it.For this reason the Battery couldnt get chance to Charge..I think My sufferings would be helpful for other..thanks..
Read this only if you are sure that you have replaced the correct type of battery & you have set the jumpers to the default locations.
It is not the problem with the battery or the charging problem (Actualy CMOS battery is not Recharable )..in most cases.
The problem is the battery holder in mainboard where we put the battery IN. eventualy or accidently these Pins from the Battery Holder are made loose or not contacted with the battery.i had the same problem and the solution was to adjust the Battery holder to seat the battery in proper way.
May be This helpe
Posted on Dec 21, 2010
  • fariskhan Dec 21, 2010
    Gr8 ......................... THis helps me..... Ashamed To be a NUT.......................
If you identify the cmos problem. first u check the cmos battery. chck the battery. 1. FIRST REMOVE THE CMOS-JUMPER 2. NEXT PLUG-IN THE JUMPER ANOTHER TWO PIN 3. SWITCH ON ON THE PC BUT THERE IS NO CHANGES 4. plug the jumper normal position & switch on the pc surely pc is working. ok my mobile number 99444-58957
Posted on Jul 25, 2007
SOURCE:
When i switch off power and restart the pc i get error 'cmos/gpnv checksum bad' and sometime 'cmos setting wrong press f1 to set defaults or press f2 to enter cmos setup'. I replace the...
sir have you tried clearing the jumper settings. if it still persist remove power supply of board and cmos battery for 5 mins. Then try to startup.
Sep 14, 2011 | Asrock P4I45GV...
Start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at...
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
Hi, I really need your help, please help me. I get this CMOS Settings Wrong CMOS Memory Size Wrong Press F1 to Run SETUP Press F2 to load default values and continue ... and my keyboard doesn't work ...
press delete during boot up process enter BIOS then f1 for general help then run chkdsk/r/f which will automatically fix any corrupt files on your hard drive
hope this helps good luck
Oct 04, 2010 | Asrock P4I45GV R5 Motherboard
Error 00161 00163
[CHANGE YOUR CMOS BATTER WHICH IS INSIDE YOUR CPU CASE]
I do not think you fixed the CMOS battery - (backup battery = CMOS battery)
According to the error codes, you have a dead backup battery and the time is not set. Makes sense?
161
(Dead battery.) 1. Go to Checking the Backup Battery
2. Backup battery.
3. System board.
163
(Time and date were not set.) 1. Set time and date.
2. System board.
Go to www.ibm.com Find and download the user manual, and the "hardware maintenance manual."
Do you know how to get into bios/setup?
Start with the machine OFF. HOLD DOWN and CONTINUE TO HOLD THE "F1" key.
WHILE STILL HOLDING "F1", turn the power on, and CONTINUE TO HOLD "F1"
This will get you into the bios "setup." You should check the date, bootup order, etc, and reset.
I would check the "wire" you think you reconnected---you may just not have actually reconnected it.
The "hardware maintenance manual" shows you how to maintain this machine, and it explains the meaning of the error codes.
This will get you started on looking for the manual:
http://www-307.ibm.com/pc/support/site.wss/multiplefiledownload.do?validate=true
May 16, 2010 | IBM ThinkPad 380ED
Cant get 4600i started. powers up but will not get past intro screen. screen shows F1 to continue and when i press F1 it tells me to press it again to retry reboot, F2 for setup options.
you need to go to cmos or bios setup, set all the date and time and proper boot setting there save and exit, it is a cmos or bios failure that causes these problems try replacing the cmos battery if the message still continues
Nov 22, 2009 | Dell Dimension 4600 PC Desktop
CMOS Battery do no work
Just change your CMOS battery with a new one and after that goto the bios settings and update the time and dare.
After that just save the settings and then check that the warning message is coming or not.
If its coming then it means you need to change the CMOS jumper settings.
Mar 09, 2009 | Asrock 845GV (P4I45GV) Motherboard
Always f2
If I understand correctly your saying when you exit the cmos, id doesn't save your changes. Make sure when you exit you select the option to save and exit. If that doesn't work, your cmos battery is dead. Look in the mobo manual to find out what replacement battery you need.
Harris
May 01, 2008 | Asrock P4I45GV R5 Motherboard
Restarting problem
constant restarts are down to a faulty driver or the cmos battery needs replacing, or short the motherboard cmos jumpers and reset the motherboard settings
Jul 25, 2007 | Asrock P4I45GV R5 Motherboard
Asrock P4I45GV R5 Motherboard Logo
802 people viewed this question
Top Asrock Computers & Internet Experts
Thomas F. Schneider
Joe Negus
Joe Negus
Davit Mamyan
Davit Mamyan
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
