posted by desperado on Jul 25, 2007
i have a Casio Pocket Viewer PV-S400Plus
i used it for two years
i have changed the batteries once
after some days suddenly it is dead
i request experts help me to repair my casio pv-s400 plus
Best Solution
posted on Aug 12, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
When batteries are to be replace you must move the switch on the back cover to "replace batteries". After you replace the batteries, you must move the switch back to "normal operation". The unit will then want you to touch the dots in the cross hairs and then ask you to adjust contrast. Try replacing the batteries again with a fresh pair. If this does not work, open the cover with the switch in the "replace batteries" position and use your stylus to press the "P" button underneath the battery cover and try again. If this fails, try resetting the unit.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Casio Pocket Viewer PV-S400Plus
Email this problem
Email this problem
Can you Help with these PDAs problems?
Casio Pocket Viewer PV-S400Plus Handheld
PV 600 & PV 400 sync does...
My Casio PV600 plus PDA... Answer This...
i need user manual
i need user manual
hai i want to pv s400plus user... Answer This...
I have a casio cassiopeia...
I need to get a manual on this... Answer This...
Cassopeia PV-S400Plus - Pocket...
Is there an upgrade... Answer This...
Unable to connect Casio PDA...
When i am trying to connect... Answer This...
Repair Service
Find PDA Repairman Near You:
