Question about Zebra Stripe S600 Thermal Label Printer
HOW TO REPLACE LABELS
RAN OUT OF LABELS AND NEVER BEFORE REPLACED LABELS...NEED TO PRINT LABELS ASAP
  • Anonymous May 17, 2009
    REPLACED A NEW ROLL OF LABLES. WILL NOT PRINT. PAPER/RIBBON LIGHT KEPTS BLINKING AND PAUSE LIGHT STAYS ON.
  • 13 Answers
Look at this I think it will help.
Posted on Feb 05, 2009
I just want to print the label size 50MM x 38MM in the zebra s600 can u guide me how to print
Posted on Mar 02, 2009
Whe i boot up my printer it automaticaly prints out one label with leters on the top left corner and after that every other label i print out comes out with those leters can some one help me asap ...i need...
Sounds like a driver issue that is adding extra characters into the print script. Make sure your printer supports PostScript or PCL. PCL is the most common and works with all printer. PostScript requires a PostScript Chip installed in the printer. Download the latest driver either from the Printronix website or CNET.com
Oct 24, 2013 | Printronix T5000r Label Printer
Hello, I have a problem with Zebra Z4M Plus
Hi, if is the vertical line, its the print head that need to be replaced,
try to clean the print head and try this to confirm:
turn printer off, press PAUSE button and at the same time, power on, don't release the button, please wait until printer LCD screen come on, then release button. It will print the PAUSE test and after few 3-4 prints, u can turn off and on again otherwise printer not ready to print your labels until u restart it. (pause test stops after 10-15 labels). this pause print just show how the print head is and if come with vertical lines, u will need to replace. other idea is (if u can) turn the bar code different position or on vertical way at label format. Thanks.
Aug 04, 2013 | Zebra Office Equipment & Supplies
Canon Pixma 5100, no black ink, but blue won't print? why?
Main Cartridge is black it is required for printing it is not possible to print black with other cartridge.
Jan 02, 2013 | Office Equipment & Supplies
I am using a Zebra S4M Thermal printer with Zebra brand labels. I changed out the roll of labels with a new roll and it will not print. It completed the task like it always does but i only get a blank...
The new labels are probably not thermal labels. Test them by applying heat to the surface and see if they turn black. If they do not change, then they are thermal transfer labels and not direct thermal. Contact your label vendor and have them replaced.
Jun 09, 2011 | Zebra S4M Thermal Label Printer
Changes from 1 to 3 pages for Excel Print Area
verify the page dimension in your driver together with the header and footer dimensions
Mar 11, 2009 | Zebra GK420 Thermal Printer
DYMO THINKS ITS OUT OF PAPER ....
New versions of the Labelwriter 400 (original and Turbo) do not take Generic Labels. It is an issue with the firmware Dymo have installed - it will only relabelwriter400.jpgad the genuine labels made by Dymo. currently there appears to be no work around to solve this isses.
The Dymo OEM labels have lines print on the back, if you use labels without these lines, the printer gives an "out of paper" error
The only printers in the Dymo Range that will take our generic labels are the Dymo Twin Turbo and the Dymo Duo (both the more expensive from the range).
Dymo have only made this change in the last 6-8 months, old 400's will work with cheaper generic labels
Aug 09, 2008 | Dymo LabelWriter 400 Thermal Printer
Just changed labels to 99010 and can no longer print
Did you change the label type in the printing preferences?
Apr 07, 2008 | Dymo LabelWriter 400 Thermal Printer
Labels Print Once Then Fail (3.5 X 1)
"The printer will print one label then either push out a half a blank label or several blank labels. At that point the labewriter thinks it's out of paper. I also noticed that the labels tend to slide toward the middle while exiting. After each print I have to pull the labels back in and realign them. Then the process repeats."
This is because you haven't squeezed both sides of the spool to the edges of the label. Without the sides to hold the label in place it is free to slide about on the spool and therefore slides about where the print head and label sensor are. The sensor is on the left, so if it slides towards the middle the sensor can't see the label and reports "out of labels".
See the diagram here for a clear picture of how to correctly load the labels to avoid this problem:
How to load Dymo LabelWriter Labels
Nov 06, 2007 | Dymo LabelWriter 400 Thermal Printer
Lexmark printer error at power up
pc stands for photoconductor or print cartridge or in layman's term toner
the toner has reached its expected life or toner has ran out
Oct 03, 2007 | Lexmark Optra SC 1275 Laser Printer
Zebra Stripe S600 Thermal Label Printer Logo
665 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
lancer284
Level 1 Expert
kenneth njonjo
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
