Question about Avid Xpress Pro - (bundle) (05600360101) Video Capture
No video comes into AVID express pro only audio with capture
With the capture tool open no video is visible in the source/recording window only hear audio
The problem was with the Mojo. I disconnected the power supply then reconnected it and it solved the problem. Thanks for your reply.
Posted on Jan 29, 2009
While trying to capture a DV tape, avid freezes ( rainbow wheel )
Is it dv and not hdv? Have you selected the record format, using a native one is generally best. Take it you are using firewire directly, it could be the camera driver - codec, Can you borrow someone elses and try? Has it worked for you before (with and with-out that camera)?
Jun 11, 2009 | Avid Xpress Pro - (bundle) (05600360101)...
Avid Express Pro vers5.
Can you set up an external monitor (like a client monitor) and change the setting to view through external monitor it is worth checking if this works, (even if you can't) it is worth changing this setting and then change it back. I have had issues with lagging picture wile capturing in the past and swaping the input from SDI to Composite and back again has worked for me. If your graphics card seems to be still working with other software packages I doupt it is this but reinstalling avid could clear up issues (just back up what you've re-captured).
Jun 02, 2009 | Avid Xpress Pro - (bundle) (05600360101)...
Cant capture sound with DVC 90 with vista
Make sure you check the recording source for audio and also the volume levels. Check the default audio input settings in Vista as well as the audio recording source in the recording program.
Jules
Dec 17, 2008 | Pinnacle Dazzle DVC 90 (210100371) Video...
How do I record just VO on the AVID? I can't find the tool to disable deck control for VO record only
In the Capture tool the Icon that looks like a deck. If you click that till it has a circle with a redline through it that disable deck control for recording VO.
Feb 19, 2008 | Avid Xpress Pro - (bundle) (05600360101)...
?Error? Cannot render audio capture stream
Download intervideo windvr and your problems are over!
Feb 18, 2008 | Philips TV Tuner Video Capture PCI Card -...
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Avid Xpress Pro - AVID crashes when deck is turned on
This sounds like a fatal error out side of avid settings, you're going to need to do an avid reinstall to replace any currupted files. Just back up your media capture and .bin / avb files. Does xpress let you create an omfi file just import that rather than relinking?
Nov 27, 2007 | Avid Xpress Pro - (bundle) (05600360101)...
No Sound when Capturing
ah. This happens to me sometimes. Well, for some reason it always works when i first open USB streaming tool( this program is not for recording)use the program to edit the video, like to fix brightness etc. Then open capturing tool. This is what you use to capture the video to your computer. What i do is to press the play button in the program, not the capture button. The video on the camcorder and the video on your screen should start playing. I do this just to test the video if its gonna have sound or not. Then you rewind the video by pressing the rewind button in the program. After that press the capture button. Sometimes it records and you don't hear the sound on the computer, I'm not sure but maybe after its captured into the computer, the video will have sound. If you do record, but with no sound, record about a minute and then stop it. Go to where you saved the video and check if there is any sound. Hope this helps you. Sorry if it's kinda confusing because i don' use the program no more. I use a DVD recorder which you connect your camcorder to the DVD player and it burns the video directly to a DVD. Its much mroe easier but you can't play around with it on the computer.
Jan 12, 2007 | Sony Handycam DCR-HC32 Mini DV Digital...
Avid Xpress Pro - (bundle) (05600360101) Video Capture Logo
361 people viewed this question
Top Avid Televison & Video Experts
Electro Med Services...
Are you an Avid Televison and Video Expert? Answer questions, earn points and help others
