Question about Maytag Atlantis MAV8551 Top Load Washer
Agitator now moving VERY slow one way, making loud grinding noise
Agitator started making a load grinding noise. Drain tub via spin. Could manually move agitator one direction. Tried again and made same noise. After playing around with it a while, and tried the cycle again, it now is moving VERY slow only in one direction and still making a load noise, just not as loud when it wasn't moving at all. I can't figure out how to get the agitator off to see if something is stuck in there or not. Once I do that and find nothing there, what would be my next move.
  • sitruc2000 May 11, 2010
    It could be the washing machine transmission. C
  • 6,784 Answers
Hi, this is a bad transmission gear box that is stripped at the moment. i recommend purchasing a agitator kit and a new transmission Assembly and clutch as well. this will fix your issues
Posted on May 21, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
What is causing my Kenmore top washer to make a grinding noise before the rinse cycle?
Have you replaced the clutch or spin tube? There is a brake actuator that comes with the clutch kit and if this is broken it can make a very loud grinding or clacking sound.
Jun 25, 2014 | Kenmore Washing Machines
Loud constant noise (metal on metal clicking / whirring / grinding) during spin cycle
renault laguna 2006 diesel. unlock code for radio... modell renrdw100-10 .
n874 security...
pls..
thanks
Nov 22, 2013 | Whirlpool Washing Machines
Washer makes grinding noise but isn't doing anything else
Remove the cap off the agitator, flip back the top of the console, remove any nuts keeping the tub in the console. There will be a clutch ring that needs to be replaced. I have an older top load washing machine. I agitates, fills, and drains, but it won't spin. It sounds like it is spinning, but it doesn't. It might be the coupling. That is a 3 piece kit that goes between the transmission and the motor. I found the directions how to do it over the internet, got the part and fixed it myself.
https://www.structuredsettlement-quotes.com/
Nov 08, 2013 | GE GSM1800NWW Spacemaker 18" Built-In...
Washer is a Samsung WWF337AAW-XAC. Just prior to the spin cycle we hear a rattling or grating noise and then it rattles throughout the spin cycle. It will sometimes rattle at the end of the rinse cycle but...
hi Rick.
Reasons a washer will make noise during spin mode:
1. Main tub bearing faulty
2. Main drive pulley
3. Motor coupling worn
4. Bad clutch
5. Worn out drive belt
6. Clogged or damaged drain pump
7. Transmission is worn out
8. Shock absorber (front loader washers)
9. Springs or dampening straps (top load washers)
10. Agitator directional cogs aka "agitator dogs" (top load washers
When the washer spins, it rides on a bearing that allows the tub to move freely with zero resistance. If this bearing is worn out, a loud noise will be heard when the washer spins. A good way to tell if your washer problem is the main tub bearing will be that the washer noise will get worse or louder as time goes on. This means the bearing is becoming more worn out and close to complete failure. The bearing in your washing machine is a circular metal object that has many small little metal balls inside. These small metal balls inside the bearing sit in a track and move when the washer is spinning. If the tub bearing begins to wear out, usually the small metal balls inside can fall out one by one causing the noise you hear. (If your washing machine is a front load washer, open the door and turn the drum by hand. If you hear a rubbing sound or the drum spins uneven, then the main tub bearing is most likely bad and needs replaced.)
Washing machine tub bearing
Washer has noise during spin cycle
The bearing may also be without lubrication. If the sound you hear is more of a squeaking noise than a grinding noise, it may mean the bearing needs to be lubricated with a mechanical grease. If the sound is more of a grinding noise, then this usually means the bearing is falling apart and will need to be replaced ASAP. If you suspect your washers main tub bearing is worn out, the repair process is one of the most difficult to perform yourself. A worn bearing can also damage the tub of the washer. This means the tub (inner or outer) may need to be replaced also.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to your washer) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose. To find out if the drive pulley is causing the noise, you will need to take the washer apart and inspect the pulley for signs of damage.
WASHER MOTOR PULLEY
The motor coupling could also be the cause of the loud noise. The motor coupling in your washer connects the washers transmission to the motor. It is made of plastic and built to break if the washer gets overloaded. This is so the motor and the transmission do not become damaged. The motor coupling is an easier repair and can be done by most people.
Washer Washing Machine Motor Drive Coupling Coupler
The clutch in a washing machine connects the inner wash tub to the transmission. The clutch lets the washer get to the proper spin RPM in a gradual way. If the clutch is worn it can make noise when the washer is spinning. A bad clutch needs to be removed and replaced to stop the noise.
Washing Machine Clutch
The belt in your washer can become worn and cause noise while spinning. If worn out, replace the belt. Replacing the drive belt on a washing machine is an easy task and can be ordered online for less.
Washing machine belt
The drain pump in your washer that drains the water out could be clogged or damaged. While in spin mode, your washer may drain out the water by using the drain pump. If the loud noise only happens at certain intervals during the spin cycle, it may be the drain pump. Usually this can be fixed by simply removing the drain pump and removing any debris that may be clogging it up causing the noise.
Drain Pump for Washing Machine
The next part of your washer that can be causing a loud noise is the transmission. If the transmission is bad, usually the cost to fix this outweighs the cost of a new washer.
If you have a front loading washing machine, they all have shock absorbers. The shock absorbers are used to center the tub movement while in the spin cycle. These shock absorbers are connected from the washer frame to the outer tub. If the shock absorbers in your front loader become weak the washer will make a loud banging sound during the spinning cycle.
Shock Absorber for washing machine
Top load washers usually have springs or dampening straps holding the tub centered. If a spring or strap falls off or becomes weak, a loud noise will be heard in spin mode. Simply replace the strap, spring, or springs to remedy this issue.
Washing machine suspension springs
Agitator directional cogs are used to operate the upper part of dual action agitators (Top load washers). They engage the cogs on the inner area of the agitator as it turns in one direction. They release when the agitator reverses its direction. This lets the top part of the agitator to ratchet in only one direction. The bottom part will agitate in both directions. The cogs are made of plastic and wear out with regular use. They will start slipping and make a grinding noise. Another way to be sure that this part is bad is if you notice the top portion of the agitator does not move in a smooth motion. Removing the top half of the agitator to see if the cogs are worn out.
Dec 08, 2017 | Washing Machines
My front load washer started making a very loud noise, as if rocks were being tumbled in the agitator. I did open the washer and found a small stone (probably from one of the children's pockets). However,...
HI- It is possible that one of the stones got stuck between the stainless basket and the tub. This is not a good scenario as the whole from panel and tub boot have to be removed and whatever is stuck has to be fished out. I would look as well for a nail or something long that is stuck down though one of the holes in the stainless basket and is rubbing on the tub. If you only notice during the drain or spin then likely there is something in the drain pump. You can check this by opening the pump cover at the bottom of the machine and removing the pump filter. Your Owners Manual should have an explanation of this procedure. It's pretty easy, just be ready to catch the water that will come out of the pump. Hope this helps, good luck.
Sep 24, 2010 | Asko W6021 Front Load Washer
WHIRLPOOL TOP LOAD WASHER MAKING GRINDING NOISE FOR AGITATION
When you put the motor in did you replace the coupler between the motor and transmission? When fixing the agitator you need to get the agitator repair kit, It has seals, dogs,thrust plate, cam bearing and seals. The upper agitator is supposed to move only in one direction to get the clothes to move down towards the agitator. Do not overload machine. I have one of these and after 12 years I finally had to install this upper repair kit because the upper agitator quit moving. You may have an agitate cam that is going bad inside the transmission
Jul 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
I replaced the coupler between gear box and moter and the cogs in the agitator now when spinning out the washer makes grinding noise
Murph!
Good job on the coupler and agitator cam! Way to go!
Now for the grinding noise... I assume that it wasn't making that noise before you worked on it, right? (except for the noise it makes when the coupler has failed. It make a kind of grinding noise, too.) So I'll assume that this is a different grinding noise.
2 things will cause this in "spin".
1.) Something is caught between the inner and outer tubs. Since you've had the cabinet off, you know that there is a perforated steel inner drum (the one with holes in it) and a plastic outer drum to contain the water. I've seen nails, paper clips, etc... get through the holes of the inner tub and get caught there. When the unit goes into spin, the object will spin along with the inner tub and rub the outer tub making a scraping/grinding noise.
To find out if this is the problem, remove the agitator again... yes the entire top and bottom portions of it. Now CAREFULLY inspect the inner tub and look for anything that may be stuck in the holes. It'll be small, so use a good flashlight.
2.) The "drive block" has cracked/broken and allowed the inner tub to drop to the point that it's grinding on the outer tub base. This one is a bit more intense than the fix above. If you would, please verify that there's nothing in the inner tub before we proceed to the next step.
Note----> I don't doubt that you can't handle the next repair. It's just that I want to eliminate the simple stuff before moving to the more complex stuff.
Let me know what you find, OK? Also... BEFORE you remove the agitator, look at the distance between the bottom of the agitator and the base of the inner tub. Use your finger for measurement. You should NOT be able to fit the tip of your finger between the two. If you can, write back 'cause then we'll be going into the drive block (#2) repair.
SG
Apr 15, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator ''dogs'' not gripping, agitator spins freely; tub rocks
Likely a broken dog itself was making the noise. They should all be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Kenmore Washing Machines
Roper RAS7233KQ0 NO SPIN
chek the water elctrovalvles and replace it , this most be 1 solution another will the hyperstatic hose or sensor of load size
Mar 04, 2009 | Roper RAS8244KQ Top Load Washer
Maytag Atlantis MAV8551 Top Load Washer Logo
1,059 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
