Question about ASUS P5QL-E Motherboard, LGA775, Intel P43 + ICH10R, Dual DDR2, PCIe x16, SATAII, RAID, eSATA, Gigab
Psql pro onboard ethernet problem
I just built this today and everything works fine except the ethernet port. At start up it tells me to activate windows. There are two options by tele or over the internet. I cannot access my desktop at all until I finish this process. The real problem is this. The mobo does not recognize that I have an ethernet cable plugged in. The indicator lights do not even light up. Help me!!! I tried over the tele, but Microsoft said to call back in 1 hour due to problems.
  • 1,602 Answers
There maybe another problem is the service network or local network service files are turn off or on manual settings, they need to be on automatic automatic delayed.
service folder is very important and if you mess with it it can make life a nightmare from hell, if you fell uneasy making these changes than have a computer nerd friend help you to understand these files and ther importrance of the folder.
another problem maybe virus program like windows defender, anti virus programs, firewalls, networking and sharing information folders that are in the control panal,
devices managers, windows default folders,
rod is candymangandy
Posted on Feb 03, 2009
  • 56 Answers
THIS MAYBE A SOFTWARE ISSUE, WHAT I MEAN, GO INTO PROPERTIES OF THIS DEVICE AND SEE IF IT IS WORKING PROPERLY, IF IT WORKING OF OKAY YOU NEED TO CALL THE PROVIDER OF YOUR INTERNET AND HAVE THEM RESET THE SYSTEM SO IT CAN UPDATE ALL THE NEW CHANGES YOU MADE WITH UPGRADED SYSTEM
GO INTO CONTROL PANAL UDER NETWORKING AND LOOK AROUND SEE IF SEE YELLOW TRIANGLE, RED CHK MARK, GREEN CHECK MARD EVERYTHING OKAY WITHIN YOUR SYSTEM.
CANDYMANGANDY
Posted on Jan 28, 2009
How do I connect to the internet when using Netflix? I have plugged an ethernet directly from modem into Blu-ray and still nothing works. I have tried everything
Check if a light on the router comes on to tell you that something is connected to the port behind .if you have more than one port try others also try more than one cable.if your blue ray has wifi it will override Ethernet.check the settings on the blue ray as that should give you connection status....and tell you if Ethernet is up and running in its network settings.
you may need to go to the manufacturer of you blueray's website ie.g.if it's a Sony Buda by registering the product with them to activate a user: pass word of your choosing. and configure the player to activate it via a tablet laptop or computer.you can google more info on this subject.good luck!
Feb 05, 2015 | Netflix
Computer restarts everytime i connect monitor to it
It sounds like the onboard video is failing. The computer should have a PCI Express x16 slot. You can get a basic graphics card to install into the machine for about $35 locally.
Jan 30, 2014 | Dell Dimension 5150 (DIM515MIN) PC Desktop
OnBoard USB Ports Not Working and No PS/2 Ports!
When you boot the machine does it tell you what key to hit to get into the BIOS or System Setup? If so, press it. Maybe you need to try another keyboard if it won't allow you to press a key to get into the Bios or System Setup.
Apr 21, 2012 | Dell XPS 400 PC Desktop
Downloaded drivers for on board ethernet and still says no drivers installed when done installing and ethernet isnt working but is detected by windows
did u download from the manufacturer website of the mother board if it is a onboard ethernet card built in on the mother board u will have to download from their website (chipset drivers)
Jan 22, 2011 | Abit IL9 Pro Motherboard
Ethernet not appearing on xp pro
Check the BIOS to make sure the LAN/Ethernet port is enabled. Run the Add Hardware wizard in Windows to see if it can find the port. If it can't, then the port is bad. You have 2 options; replace the motherboard or buy a $10 ethernet card and install it.
Feb 11, 2010 | EliteGroup GeForce 6100SM-M Motherboard
MV43V motherboard by shuttle
Here are your MB specs:
MV43V/N - Supports Socket 478 Intel Pentium 4, Celeron with 400/.533 MHz FSB
- VIA P4M266A + VT8235 Chipsets
- DDR 200/266 SDRAM, 2 x 184 – pin DIMM, Up to 2 GB
- 2 x ATA 133
- 4 X AGP device, 2 PCI slots, 1 CNR slot
- Onboard AC97 audio two channels
- Onboard S3 Pro-Savage 3D Graphics
- Onboard VIA VT6103 10/100 Fast Ethernet (MV43VN only)
- 6x USB 2.0
- Micro ATX Form Factor
The your motherboard has an ethernet adapter all you need to do is download the drivers for the ethernet adapter and install them. here is the link : http://members.driverguide.com/driver/detail.php?driverid=206328 do a free subscription first. cheers
T
YE
Feb 16, 2008 | Shuttle MV43N Motherboard
Maxtor 500g network drive
Describe to me exactly how you are set-up. Include the IP addresses of each device and exactly what ports are being used on each device. Could like an IP mistake or in some cases an X-over cable is still required IF your switch does not have does not have a x-o button on it. But that depends how things are connected. These are the 2 most likely but need the above info to diagnose.
Jeff
Feb 15, 2008 | Computers & Internet
Ethernet Port seems to be a failure, but the USB works fine
I managed to fix the problem manually using a computer kit I had.
The problem was the Ethernet port on the modem was messed up
you should check if the small wires are on the back are all facing towards the top if not you should try to fix its actually pretty easy
no need to pay for a repair :D
Jan 10, 2008 | Arris SURFboard SB5120 Modem
ASUS P5QL-E Motherboard, LGA775, Intel P43 + ICH10R, Dual DDR2, PCIe x16, SATAII, RAID, eSATA, Gigab Logo
799 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
