Question about Maytag 30 in. CSG7000 Gas Cooktop
Elect Ign not sparking, but get gas, other appliance working.
All 4 burners usually spark when turn 1 on, but now none spark.  Looks like Maytag 30 inch wide CSG7000 Gas stove top.  Elect plug is in all the way, and was working fine 5 minutes before.  I can still light them with a match.  Any idea?
3 of my electonic ign. burners lite fine but the other won't without a match, been like this since I brought it home from the store
Posted on Jul 04, 2010
I don't know, I did nothing, it just started working again??????
Posted on Jan 29, 2009
Maytag/Jenn Air JGD8130ADS one burner will not ignite but all others will. solutions?
Turn off gas. Remove the cartridge and remove back cover. Clean the ignition spark area. Re-install the cartridge without the back cover. Try to ignite the spark. If the spark works. The spark wire is too close to the back cover. Use an electrical tape to insulate the wire from the back cover. Other swap the two spark to see if you have a faulty spark.
Jan 02, 2012 | Maytag JGD8130ADS 30 in. Gas Cooktop
Cooktop spark igniter will not turn off
This is usually a bad spark module that is not sensing that the burner is lit. You need to replace it. Is it still under warrantee? Good Luck, Appliance Specialists
Jan 06, 2010 | Jenn-Air 35 in. JGC9536 Gas Cooktop
My ignition will not stop clicking
hi friend,
There are a few things to check for. Make sure the electrode ( the small metal piece that the spark comes off from ) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and NOT a tooth pick as these can break off and make things worse. Example of a burner. The next thing to check for are the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it. Sometimes cleaning can get moisture into the surface switches, try drying them with an hair dryer to see of this will help.
it sounds like it is the spark module that's making the clicking noise. normally there are 4-6 wires that connect to it , and if you are not comfortable making the repair yourself then I would call an appliance repair company.The part should cost 30-50 $ Good luck
hope this helps u
please rate me.......................
thank u for using fixya
regards
sivaranjini
Nov 25, 2009 | Wolf Range 18 in. SPR-100 Gas Cooktop
Electronic ignition sparks continuosly (even when burners are off).
one of your electronic ignition switches is bad and burnt closed telling your spark module to spark
call applaince parts pro
1-877-477-7278
tell them u need part number
AP4101545 ignitor switch
18.00 dollars
they sit below the top under neaqth the selctors
you will have to go one by one
but the wires push in and pull out
Oct 04, 2009 | Maytag 30 in. CSG7000 Gas Cooktop
New cooktop-1 burner does not light automatic
find the spark module. Follow the spark wires to the module . unplug the one that doesn't work and plug in a working wire. If it sparks it the wire if it doesn't spark change module
May 16, 2009 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
Spark module will not stop after lighting burner
The module might not sense the flame: check electrical connections: wire (and its contacts0 and conections by fryer chasis; to be sure please bond with 18AWG wire pilot burner with spark module green wire.
MarKor
Mar 09, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Ignition sparking on its own with GE mongram gas stove top.
the sparking is one of the switches under the knobs shorted you may be able to open the top and take a switch off 1 at a time and you can figure out what one is shorted.or you can just change all of them.
to stop this you may be able to just unplug the cooktop from under the top.if you unplug the cooktop you should be able to light the burners with a match.
Nov 14, 2008 | Cooktops
(2) front Burner igniters on my new Matag 30" Cooktop continue to click
Sounds like water got into one of the switches. This usually happens when you wash the knobs. Water stays in the holes and runs down the shaft when replaced. Maytag has issued a recall on some stoves because this can be a fire hazard. UNPLUG THE COOKTOP UNTIL THIS IS FIXED!!!!!!!!! This has happened to me with a whirlpool unit and it tripped a breaker and shot sparks across the kitchen. First go to Maytags web site and see if yours has a recall. If so Maytag will fix it free. While you are waiting leave stove unplugged and light with a match. If you need to fix this yourself disconnect the wires from the two switches this should stop the sparking. Connect one switch at a time and see which switch is bad. Most of the time the electric part of the gas valve can be replaced seperately. and you can do this yourself. If you must actually disconnect a gas pipe unless you really know what you are doing call for service.
May 15, 2008 | Maytag 30" Built-In Gas Cooktop - White
One of four dials doesn't spark ignitors...
its a spark switch gone bad, 1 switch will turn on all four burner electrodes(its just easier 1 module)sometimes model dependant you can eplace justone switch, sometimes they come as a complete set
Feb 24, 2008 | GE 30 in.Profile JGP945 Gas Cooktop
Maytag 30 in. CSG7000 Gas Cooktop Logo
323 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
