Question about Rival (PATHT17ZU) Tower Fan
Mini tower desk fan smells like it burned
My mini tower desk fan just stopped working. Everything (including interface and the actuator) worked but the motor. When i inspected it (still plugged) it was hot. I unplugged it and let it cool. Thinking it was the dust building up, i opened it and vacuumed the dust away. I tested it and it still didn't work but it emitted a buzzing sound. I examined the electric motor and it was really different to what i expected. Connected to the turbine was a cylindrical solid metal horizontally "wrapped" with flat metal which with an attached coil electromagnet in its side. (See this picture: Note: You can slightly see this rotating cylindrical solid metal in the picture. As i personally tried to rotate the turbine, i felt that it was in need of lubrication. It turned like what it feels to twist a pen cover on a pen. In theory, to make the fan more efficient, resistance among the moving part should be the least. My question is, is it SAFE to lubricate (using a WD40) the rotating cylindrical solid metal? Or basing on the symptoms, is the motor actually dead?
  • 883 Answers
No. you are correct in attempting to lubricate this motor, except that use 30W motor oil...WD40 is great to "loosen" the bearing, will only last a short time. The motor shaft should spin freely as this is not a permanent magnet type motor. This motor is widely used and quite common. I often "cure" broken machines by lubricating these motors. There is only a magnetic coupling (when powered) between the rotating shaft and coil. it should be safe to handle this motor even when powered up, providing there is no electrical damage to the coil. Think of this motor as a magnetic machine that requires AC power for the magnet.
Posted on Jul 25, 2007
How to clean your Dyson Cool fan
How to clean your Dyson Cool AM01 or AM06 desk fan, AM02, AM02 Living, AM02 Mini, AM07, AM07 Living or AM07 Mini tower fan, or AM03 or AM08 pedestal fan.
Your machine may differ to the one shown in the video, but the process for cleaning it will remain the same.
IMPORTANT: Please turn off and unplug your Dyson Cool fan before cleaning it. We recommend using a soft, dry cloth or soft dusting brush to clean the intake holes and loop amplifier. Do not use liquids, polishes or detergents to clean your Dyson Cool fan as this could cause damage not covered under guarantee.
on Nov 27, 2014 | Dyson Dryers
Where is the fuse box for mini cooper 2001
where is the fuse for the remote central locking in a mini one (2001) as I have changed the battery in the key fob and still not working. Can it be reset?. it has 2 button and not 3 on the key fob. Could the problem be a fuse that stops the actuator in the door from working?
Oct 16, 2012 | 2001 Mini Cooper
My G-tech Gmini 500g won't mount on the desktop but it mounts on disk utility.
Hi, if you can see the drive in Disk Utility, is the volume appear greyed out? If so, then it sounds like the directory has been damaged, which usually is caused by disconnecting a drive improperly or losing power. DiskWarrior is a utility that can often repair a damaged directory and allow the drive to mount.
Feb 17, 2011 | GTech G-Tech G-Drive Mini 2.5 Portable...
Hi, The following is the spec. What is the best graphics card upgrade options without upgrading PSU? Thanks. 1 03FCY Base,Mini Tower,Configure To Order,INSP 560 $358.67 1 07GHK...
HERE is the direct link from Dell that will tell you what graphic card will go into your system. Since there are many factors involving graphics card updates this is the best place to start.
Jan 06, 2011 | Dell Inspiron 560 PC Desktop
Hello I have a Dell optiplex GX270, with the mobo it comes with. It will boot, has sound coming from the HD, CD drive, cpu cooling fan, etc, but will not show anything on the monitor and the keyboard...
Hi,try swapping the Memory chip ie putting it on the other slot,also test with another processor if after all these system does display,i'll suggest you go get a new board.
Jan 04, 2011 | Dell OptiPlex GX270 Small Mini-Tower...
What is Mini Tower ATX Cabinet
A mini tower is a PC desktop case which is approx half the height of a full size desktop tower case. ATX probably refers to a ATX switch mode power supply.
Sep 10, 2009 | ASUS TM-220 (generic) Micro ATX Mini Tower...
Chefmate RS-06DR mini Fridge (1.6 Cubic Feet)
My chefmate is **** because the internal fan is garbage, its cheap, it doesn't work or give enough flow, try a higher flow unit. You can get the 12v at with some high flow (AND LIGHTS :) ) for a few bucks to save your 100 dollar investment. The removal of the orig fan is easy. The evap is a good setup, but the cooling setup for it seems to be sh*t. Cheap fans = cheap setup and this is why everyone hates these units cause it can't pump the goods.
For the record my fan died, so my evap and fan froze over completely and spoiled my food and burned out the fan completely and probably helped to short it. I can get it going if I flicker the fan with my finger but she is dead and can't catch naturally. You could replace the chefmate fan with most computer fans too... fyi if you got a junk tower laying around.
While your at it clean the fans on the back and take off the back panel which kicks out the hot air from the hot flow. It helps if your unit is older (a year plus+ in a dorm is like 4 in a clean house lol)
Nov 03, 2008 | LG GC-051SS Compact Refrigerator
Adding a video card
yes you need to find one or order one from hp or off ebay a normal video card will not work in a mini tower, the ports are to small in a mini
Jun 20, 2008 | Computers & Internet
Rival (PATHT17ZU) Tower Fan Logo
1,157 people viewed this question
Top Rival Dryers Experts
Are you a Rival Dryer Expert? Answer questions, earn points and help others
