Question about Zebra Z4Mplus Label Printer
Unable to align printer to start at top of a new label; where can I download a manual for this printer (Z4M plus) thank you - barry
  • Stephen Clouthier
    Stephen Clouthier May 11, 2010
    have you tried
    This is the link where you can select the correct model. there are alot of different manuals but the main user guides & soforth that come with the unit when new are in there you just have to weed out the ones you do not need. they are in PDF format so hopefully you have Adobe reader.
  • 2,976 Answers
Put in a new roll of labels. Calibrate the printer. Make sure the program you are using is set for the size label you are using. If it calibrates properly, you should end up with the tear off perforation at the edge of the feed out area.
Posted on Feb 05, 2009
Z4MPLUS doesn't recognize the MEDIA(LABEL) automatically.
you should recalibt=rate the printer.
Are you sure that your previous label was not longer?
With the autocalibrate function activated the printer should try to detect the correct length. If it doesn't the yoou have
- A problem with the label border
- Preprinted stuff which the printer detects as to fo feed
Dec 09, 2013 | Zebra Z4Mplus Label Printer
I turn on the zebra z4m and it runs the labels even with no information sent to the printer. I can not use the cancel or pause button to stop. I runs for a minute and then error condition ribbon out. I...
1.Double check that the ribbon and the labels are routed correctly. 2.Make sure the media guide is holding the labels against the inside of the printer and not moving to the right away from the media sensor. If the labels are sliding to the right as they come out, increase the left side head pressure on top with a flat blade screw driver. Download the user manual at .Check the media type and sensor type, and set for thermal transfer if using a ribbon.
Feb 24, 2011 | Zebra Z4M Printer
My printer always start printing short so that the lables end up on two pieces instead of one
We must establish whether the problem is a moving label or just that the labels are not aligned properly. Is hte printing split across the two labels consistant regardless of hte number of labels printed? If so, then the lables are not aligned properly. The user manual has the procedure for aligning these. This is part of the setup procedure.
If hte first line of the labels changes position on subsequent printings, then either the label size is not defined properly or the format being used is not correct. I don't have the manual handy at the moment so I can't give you the particulars, but if you could update this and tell me which of the 2 conditions you are experiencing, I will look up the specifics in the morning.
Dec 09, 2010 | Zebra Z4M Printer
Z4m printer will miss labels in jobs. I've saved the job in the spooler and if I resend the jobs the blank labels will print out so I know the job is good. Any suggestions welcome.
Check the label size is set correctly in the application. Try using a driver from Nice Label or Seagull Scientific websites to suit Z4M (Not Z4M Plus). Recalibrate the printer and try again. Remember to setup the driver correctly because the driver will override the printer settings.
Nov 30, 2009 | Zebra Z4M Printer
Printing half the vertical, no matter what size label in use.
Some drivers adjust the length of the print area, regardless of the length of the label. Do calibrate the label and also verifies that the margins are zero.
Roberto Martinez
Jul 21, 2009 | Zebra Z4M Printer
Zebra Z4M Plus
Is the length of the label correct on the configuration print out?
Else try t check if there isn't a feed or print adjust in the parameters
Jun 25, 2009 | Zebra Z4M+ Printer
Zebra Z4M plus printing an extra label
Restore factory defaults. If this doesn't sort it out, get back to me and I should be able to point you towards the right solution.
Mar 31, 2009 | Zebra Z4M Printer
(zebra Z4M PLUS)
Here is a website to help with specs and supplies...
Nov 27, 2008 | Zebra Z4Mplus Label Printer
The printer is Z4M or Z4M plus? I found this error at z4m plus and the solution is to change the motherboard. Roberto Martinez Mexico
Nov 14, 2008 | Zebra Z4M Printer
Zebra Z4M Plus
this is a color printer or not
Oct 01, 2007 | Zebra Z6M Plus Thermal Label Printer
Zebra Z4Mplus Label Printer Logo
323 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
