Question about Philips HTS-3565 Theater System
Philips Home Theater Speaker Wire (can it be cut?)
I recently remodeled a room in my home and added speaker wire terminals to the corners for a home theater system. I purchased a Philips HT 3565 and realized that the wires are fixed to the speakers, and have color coded plugs the insert into the back of the system. Can I cut these wires to utilize my prewired room?
Thank you
-Joel
Ohio
  • joellorenz25 Jan 28, 2009
    Thanks for the quick answer!!
    President:
  • 2,992 Answers
Sure you can, Joel.
Put the speakers wherever they will go, and cut the wire from the speaker to whatever length you need to reach your wall terminals. Leave some slack so you can move the speakers if needed. Strip off whatever length of insulation you need to make the terminal connection. Note that the speaker wire will have some kind of polarity marking. There will be a colored stripe or other mark on the insulation, or the conductors themselves may be different colors (usually one wire is copper, and the other tinned so it's silver colored). It doesn't matter which you use for positive as long as you're consistent and use the same one for each speaker.
At the other end where the prewiring comes out for your home-theater system, splice the connector ends you cut off onto the installed wires, following the same polarity. I recommend using an appropriate size insulated **** splice to make the connection. The crimper and splices can be found at auto parts stores, Radio Shack or most hardware stores. It's quick, reliable and makes sure there are no bare wires to short out.
Plug the speakers into the system and you should be good to go. Whip up some popcorn and enjoy the show!
Posted on Jan 28, 2009
  • Jan 29, 2009
    Hmmm... I forget that they bleep out certain words. The kind of splices I was referring to are a 4-letter word that means a cigarette end. If you didn't get that already. I wonder what happens if you write "butter?"
What is the error code W-1 Phase mean and how do I correct it?
"W-1 Phase" error, when running the YPAO, means that one or more of the speakers in your home theater set up is out of phase. This happens when the + and - wires are not consistent throughout all of the speaker connections (red and black terminals). Make sure your red/copper color wire is connected to the "red" speaker terminals , and the silver color wire is connected to the "black" speaker terminals. This error can also happen even if all of the speaker cables are connected correctly but the acoustics of the room are creating the out of phase sound the microphone is picking-up.
Oct 27, 2014 | Yamaha Audio Players & Recorders
No sound from rear speakers. Mustek DVD V600RZ tks giuliano
This is almost always due to a bad speaker connection in the speaker output terminals on the back of the receiver unit, or the speaker input terminals on the back of the speakers. Check your wire connections at these points and fix as necessary. If the plastic wire insulation is pushed inside the terminals, it will prevent the wire from making contact in the terminal.
May 29, 2011 | Mustek V600RZ Theater System
The back speaker wire isn't long enough to reach to the back of the room. How can I splice the wire and still get it to hook back up to the receiver? Please give a very detailed description, and video or...
buy some speaker wire and wire nuts
cut speaker wire for the speaker and strip back the wire on both ends
cut length of speaker wire required for installation and strip both ends
connect one of the wires to one of the new wires and twist together and then twist on a wire nut... do this for all four individual wires making sure that you don't cross the wires by twisting the new wire.
connect and check. if you don't hear any sound or it is really low, untwist one side of the wires and exchange them.
Mar 13, 2011 | Philips HTS-3555 System
My subwoofer doesn't seem loud enough. I have it set to 80%. Is there other settings that might solve this problem?
Bas response is highly dependent on room boundaries, speaker placement and relative listening position.
Page 13
"Place the subwoofer at the corner of the
room. Otherwise, keep it at least one
meter away from the TV."
http://www.retrevo.com/support/Philips-HTS3555-Home-Theater-Systems-manual/id/2869dj188/t/2/
You might experiment with moving the sub around.
Jan 16, 2011 | Philips HTS-3555 System
Speaker wire problem
Yes you can splice the ends onto the existing wires, but first make sure the ends are labeled + or - and make sure you hook the other ends to the speakers the correct way. Before you cut the connectors off of the speaker wires mark one of each of the pairs of the wires with tape, on each side of where you cut it so you can match the wires back up. Are the pre-wired, wires labeled + and -? or red and black? Or one of each pair is a different color wire ie silver and copper? If they aren't labeled its going to be hard to get the correct polarity (+ and -) for each speaker. I hope this helps post back if you have any problems.
Aug 19, 2009 | Philips HTS-3565 Theater System
How to extend speaker cables of Philips MX6050D DVD Home Theater
Go down to your local RadioShack or any place that sells wire of any sorts (heck, even Walmart might carry it now) and ask them for speaker wire. I'm not sure what the impedance of this particular model is, but you should be able to find it printed on the back of the speakers, or in your user's manual. This guide will help you to identify what size speaker wires you need, that way when you go in looking for speaker wire, you'll at least sound like you know what you're doing.
Jun 02, 2009 | Philips MX6050D System
Lengthen speaker cable
i had same problem. yeah, there's not much wire included. i just purchased a spool of speaker wire and got the length i needed. since the wires are usually color-coded, i tagged each new wire with 2 stick-on-spots, with sticky side back to back over the wire, and wrote RR & LR to make it easier for locating them in a jumble. you can also just splice and tape extra wire on but i feel every cut cuts back on quality of sound.
May 27, 2009 | Montgomery Ward Audiovox DV1201 Theater...
Need an fm antenna
If it uses a simple terminal clip (similar to a speaker connection) then extra speaker wire or lamp cord thats laying around works beautifully. But you could always visit a Radio Shack to get the proper stuff.
Apr 04, 2009 | Philips MX6050D System
Do they sell extentions for the speaker wires for the HTS-3565d?
you best bet for that much wire needed would be to go out to eather wal-mart or radio shack and get a spool of speaker wire normaly the mid range wire is a good bet for home use
Mar 27, 2009 | Philips HTS-3565 Theater System
Proprietary speaker terminators - Clip them?
Don't waste effort with phillips take system back get better one then put the effort to make the perfect quality sound dynamics in your room, none of our phillips systems work after 8 months and warranty work is non existant.......sorry
Jan 12, 2008 | Philips HTS3450 System
Philips HTS-3565 Theater System Logo
2,006 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
