Question about Samsung RS2578BB Side by Side Refrigerator
MK183C/L2U compressor making noise
I have a Sasung side by side and it is making this horrific noise throughout the day. Not all the time, just off and on. Any ideas?
  • Anonymous Apr 11, 2009
    Defrost and then do What??? My noise was from the inside k
    like a fan bearing going out. Now the noise has stoped along with the fan
  • 700 Answers
Take and look at the condenser fan in the back of the unit and make sure that its working properly. If the noise is from the inside then yoiu will have to defrost the unit first.
Posted on Feb 04, 2009
Emits a loud coarse noise, about 10 seconds long, intermittently throughout the day & nite
What type of compressor does it have? Some brands use a compressor that makes this sounds every time when it starts up. And its normal. Last for 5-20 seconds.
Feb 17, 2016 | Refrigerators
Compressor hot, draws 9amp tried hard start kit with no joy. used external 120vac windings not grounded, windings ~3 ohms ~ 8 ohms,
Dear Robert,
  • I am assuming you clean the coil.
  • Compressor may test out good electrically but has a mechanical failure inside.
  • Check the Run Cap.
  • Here is a link to the Service Manual.
http://www.manualslib.com/download/446846/Samsung-Rb215bssb.html
  • Click on it or paste to your browser.
Let me know the turn out.
Good Luck,
JP
Jun 08, 2015 | Samsung RS2530BSH (25 cu ft) Side by Side...
Model RM255LASH/XAA COMPRESSOR MK183C-L2U SERIAL 406043EL600140 M HI it appears that there is about a cup of what appears to be oil that seems to have come from the front of the...
The oil could be from a slow leak on the refrigerant lines which of course is a Freon leak. Where are you seeing the oil exactly pictures would help. Schrader valve's could be the issue if close to that area.
Jul 06, 2017 | Samsung Refrigerators
Model rs2544sl no cooling
Try resetting the frig by holding the power freeze and power cool buttons down at the same time.
Jun 12, 2017 | Samsung 24.8 Cu. Ft. Side-by-Side...
Frigidaire side by side making a vibrating/humming sort of sound
When a fridge is first installed it is important it is adjusted to stand level and firm. If it was transported upright and hadn't been laid down it could then be switched on but if it had been laid down during transit or during installation it should be left to stand before switching on - some authorities say four hours and others say longer.
Failure to do either of these things can cause accelerated wear of the compressor and that could be the reason for the humming noise and vibration.
A friend has the same problem with his fridge and he freely admits it was never properly levelled. It began vibrating years ago for a short time when it starts but apart from that it continues to work quite well.
Just to be on the safe side of fairly sure, it would be a good idea to check the security of the compressor and fixings...
Apr 18, 2017 | Frigidaire FRS26H5AS Side by Side...
Ice maker not turned on or hooked to water line
it my be not the icemaker check fan or you can remove icemaker
Feb 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a Samsung side by side with compressor MK183C-L2U. It is making this horrific noise. Not constantly, just throughout the day. What is causing this and can I fix this myself?
I seen this problem before this fridge is different from others because has tow evaporators Must likely your defrost heating element on the fridge side burn out and is letting ice to build up on till touch the fan blade and start making that sound now The problem is than the defrost heater element is build on the evaporator So the options are discharge the system and emplace the evaporator or what I do is Carefully cut of the old heating element install a generic one and a defrost thermostat and a mechanical defrost timer (8-10 hours) drill a hole to the back of the fridge and run a line from the back and the timer next to the control boar tapping the main power lines Now unless you are familiar whit electrical wiring and the defrost system of older fridges I don?t recommend to tray. Even must technicians would not dare do make modifications to a existing system. If you can?t do some thing like this what a recommend is turn the ?POWER COLD? off and see if gets any better .
Jan 28, 2009 | Samsung RS2578BB Side by Side Refrigerator
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Electrical noise
If the noise from the compressor sounds like a humming followed by a click, the compressor is "short cycling". Could be either the compressor relay or the compressor itself is bad. Not sure on the hissing noise. Could be just a loose panel that needs to be tightened or adjusted.
Apr 07, 2008 | Samsung RB1955 Bottom Freezer Refrigerator
Maytag fridge made some clicking noises and then stopped cooling
For what it is worth. I had this problem twice and both times the compressor ad to be replaced. Ton this day it sounds like a pin pong game whenever it runs. No it is not the fans or the ice maker.
Nov 29, 2007 | Maytag MSD2454G Side by Side Refrigerator
Samsung RS2578BB Side by Side Refrigerator Logo
745 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
