Question about Samsung RS2578BB Side by Side Refrigerator
I have a Samsung side by side with compressor MK183C-L2U. It is making this horrific noise. Not constantly, just throughout the day. What is causing this and can I fix this myself?
    Novelist:
  • 145 Answers
I seen this problem before this fridge is different from others because has tow evaporators Must likely your defrost heating element on the fridge side burn out and is letting ice to build up on till touch the fan blade and start making that sound now The problem is than the defrost heater element is build on the evaporator So the options are discharge the system and emplace the evaporator or what I do is Carefully cut of the old heating element install a generic one and a defrost thermostat and a mechanical defrost timer (8-10 hours) drill a hole to the back of the fridge and run a line from the back and the timer next to the control boar tapping the main power lines Now unless you are familiar whit electrical wiring and the defrost system of older fridges I don?t recommend to tray. Even must technicians would not dare do make modifications to a existing system. If you can?t do some thing like this what a recommend is turn the ?POWER COLD? off and see if gets any better .
Posted on Jun 08, 2009
How do I fix a Samsung refrigerator that started to make noise
Noise could signal a failing or worn motor/compressor unit or falling gas pressure but it is worth checking to ensure the motor is still secure and then the fridge is perfectly level and stable.
If the fridge has been laid down, during a house move for instance, it should stand for a few hours in it's new home before being switched on. Switching on too soon can deprive the compressor of lubrication with a resulting shortened life.
Oct 05, 2015 | Samsung Refrigerators
Compressor hot, draws 9amp tried hard start kit with no joy. used external 120vac windings not grounded, windings ~3 ohms ~ 8 ohms,
Dear Robert,
  • I am assuming you clean the coil.
  • Compressor may test out good electrically but has a mechanical failure inside.
  • Check the Run Cap.
  • Here is a link to the Service Manual.
http://www.manualslib.com/download/446846/Samsung-Rb215bssb.html
  • Click on it or paste to your browser.
Let me know the turn out.
Good Luck,
JP
Jun 08, 2015 | Samsung RS2530BSH (25 cu ft) Side by Side...
My compressor wont come on
Check for a bad start capacitor/relay. Also check all wiring and contacts for integrity. Get it to run. If loud noise on start up or shut down that is caused by a broken internal spring (usually three) that hold and center the motor inside the container. If one breaks the startup torque will twist the motor up against the shell making the noise. Has no effect on operation and/or longevity - just noise that can be lived with. If you shim compressor in the opposite location of spring break you may eliminate start up noise completely.
Aug 28, 2017 | Samsung RS263TDBP Side by Side...
Model RM255LASH/XAA COMPRESSOR MK183C-L2U SERIAL 406043EL600140 M HI it appears that there is about a cup of what appears to be oil that seems to have come from the front of the...
The oil could be from a slow leak on the refrigerant lines which of course is a Freon leak. Where are you seeing the oil exactly pictures would help. Schrader valve's could be the issue if close to that area.
Jul 06, 2017 | Samsung Refrigerators
Model rs2544sl no cooling
Try resetting the frig by holding the power freeze and power cool buttons down at the same time.
Jun 12, 2017 | Samsung 24.8 Cu. Ft. Side-by-Side...
Constant noise when compressor running
most likely there is something touching the body so try to lift the back side and if noise goes away put a block of wood under the unit
May 19, 2009 | Frigidaire FAH126N2T Thru-Wall/Window Air...
MK183C/L2U compressor making noise
take and look at the condenser fan in the back of the unit and make sure that its working properly. If the noise is from the inside then yoiu will have to defrost the unit first.
Jan 28, 2009 | Samsung RS2578BB Side by Side Refrigerator
A constant loud rattling noise throughout most of the day and night from a KGN33V60 model, appearing to come from the freezer compartment, for a very long time. This is the third replacement model we have...
Lots of stuff can cause noise. The only moving part in the freezer is the fan. I don't know of anything else that moves. If ice build up is an issue, then there are several things to concider.
Not enough defrost time. Cycle too short or heaters are not hot enough for some reason. Could be undersized heaters from manufacturer.(?) Defrost timer could be bad causing short or no defrost at all. This timer also controls the defrost heaters and compressor being off during defrost.
Be sure the seal around the door is tight. No air gaps. Warm air (contains moisture) will cause freeze ups. Long shot is that the thermostat is bad and unit never shut off. If timer is bad, compressor coudl be running during defrost cycle.
Hope this helps
Jan 15, 2009 | Freezers
Freezer not working
sounds like the clicking noise could be the overload on the compressor. pull off grill cover on bottom front of refrigerator check to see if condenser coil if blocked with lint and dust if it is clean it throughly it could cause the compressor to overheat and cause the refrigerator to thaw and the overlaod to make a clicking noise. hope this helps you out
Dec 15, 2008 | Kenmore 53642 / 53644 Side by Side...
Electrical noise
If the noise from the compressor sounds like a humming followed by a click, the compressor is "short cycling". Could be either the compressor relay or the compressor itself is bad. Not sure on the hissing noise. Could be just a loose panel that needs to be tightened or adjusted.
Apr 07, 2008 | Samsung RB1955 Bottom Freezer Refrigerator
Samsung RS2578BB Side by Side Refrigerator Logo
279 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
