Question about Canon imageCLASS MF6550 All-In-One Laser Printer
CANON MF6550 printer started to show error TONER IS NOT SET INSERT TONER, we already replaced the toner and still keep on give that error message, what do we need to do, because we always have to open the door where you put the toner to be able to use it
  • Anonymous May 23, 2009
    yes but this didnot fix it. i changed the toner two days ago but still says to replace
  • Carlos Perez
    Carlos Perez May 11, 2010
    did you replaced the cartridge or just filled it up?
  • 22 Answers
The error you are describing is usually cause by a bad cartridge but if you have tried a new Canon cartridge because refills will cause this a lot then we would need to look internally. If you look inside the unit (cartridge removed) on the right hand side towards the bottom you will see 3 flat metal plates. These are called spring plates when you push on them they should move in and out check and make sure they are not bent or depressed in you can try and use your fingers to fix them if they are. If not this unit would still be under the 3 year manufacture warranty call Canon they should give you service options. 800-828-4040
Posted on Jan 29, 2009
HL-2280DW says replace toner but I already have
Just do a manual reset:-
Open the front cover of the printer
Press and release the "clear" key
Press "start", then press the up arrow until you see the number 12 on the display
Press "ok", you will see "accepted" on the display
Close the front cover, your toner cartridge should now work.
Original Brother tonor cartidges should reset automatically.
Apr 17, 2014 | Brother HL2280DW: HL-2280DW Wireless Laser...
HOW CAN I SOLVE "THE TONER IS NOT SET INSERT THE TONER" ERROR ON MF3220 CANON, I've checked the sensor and cartridge gears.
TAke out the cartridge and unplug it and plug it back in and put the cartridge back in and see if thats the problem for you.
Dec 29, 2012 | Office Equipment & Supplies
Turn off low toner message
This is not possible on this model, as the error is a direct result of a sensor bar in the cartridge reporting an unacceptable level of voltage due to low toner in the cartridge. You must replace the cartridge.
Sep 29, 2010 | Canon imageCLASS® MF6550 All-In-One Laser...
Canon image class MF 4150: it is flashing, message says toner is not set insert toner. Toner has been inserted, it was working this morning, I printed documents fine, now this message. I have taken the...
spacer.gif If you removed and reinstalled toner correctly several times and this error code is flashing, you need to try another new toner cartridge, even though the other one may seem still good to you. If this doesn't remedy problem the Troubleshooting section of the website says to call 1-800-OK-CANON.
Jul 16, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
I have faxs stored in the memory but do not know how to print them?
It should print by itself unless you have an error message (Low Toner, or Incorrect Paper Format or no more paper) and your Cont. Printing setting is set to OFF. To set it to ON, go in your Fax Settings, then Printer Settings, then Cont. Printing. This works on my MF4150, hopefully this will also work on its older brother MF6550... Just check your user manual (if you lost it, check canon's website).
Nov 20, 2009 | Canon imageCLASS® MF6550 All-In-One Laser...
Error message keeps showing to "reset black toner".
Try to reset the toner by taking it out and putting it in again.
Jul 16, 2009 | Ricoh Aficio AP3800C Laser Printer
Toner is not set Insert toner. Toner is set.
toner is like the catridge.. i think yu ve an laser printr.. yur toner is removed or else loose.. yu shd fix tat problm... by checkin yur toner.
Jul 06, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Toner replacement
When this happens it is usually because the paper has misfeed remove paper from cassette tray replace it then reseat toner.
Jan 03, 2008 | Canon imageCLASS® MF4150 All-In-One Laser...
Toner not set insert toner message
The problem is with the paper tray not the toner, believe it or not. Take all of the paper out of the tray and then reinsert the paper into the tray. It should then work fine.
Nov 06, 2007 | Canon imageRUNNER 400S Copier
Canon imageCLASS MF6550 All-In-One Laser Printer Logo
437 people viewed this question
old marine
old marine
