Question about JVC TH-C5 System
Cant turn on dts on dvd player
We have a problem with the sound on a dvd and to fix this we need to turn on the dts sound setting on the dvd player, it apers to be off and no way off turning it on,
  • Anonymous Apr 14, 2009
    How do u turn on the DTS setting on the dvd player, it is a Sony MHC-GN90D?
  • 336 Answers
First check that the DVD has DTS (digital theater sound). Then you may need to change the audio option. In the main menu of the dvd go to sound options or set-up and check that its not 5.1 or some other audio option and is in DTS.
You did not list the make or model of your dvd player and or receiver, It would help if I had this info.
Posted on Jan 29, 2009
My techwood won't play sound and the colour is completely wrong. How do I fix this?!
please see the chart troubleshooting. and fix it. God bless you
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Oct 14, 2013 | Gemini 1 Device Universal Television...
My techwood tv will not play sound and the colour is not right. how do I fix this?
see the charts troubleshooting and fix it. God bless you
No sound
  1. Disc is dirty or damaged. Clean the disc or try another disc.
  2. Reset the color system of the player or the TV set.
Try a direct connection from the DVD player to the TV set, instead of via other components.
Turn Sound ON, now it's "Q SOUND OFF""
follow this steps and fix it. God bless you
Jul 09, 2013 | Televison & Video
Volume too low on toshiba portable dvd sd-p91ske
see the causes and fix it:God bless you
Jul 21, 2012 | Televison & Video
The sound goes on and of when watching a movie
see the cause and fix it: God bless you
Jul 21, 2012 | Wharfedale DVD-M3 DVD Player
When DVD uses DTS Sound, doesn't use 5.1
The bitstream sent out by the BluRay player is selectable via menus on thedisk. And the player itself may have a menu that allows it. Would need to know more about the source.
Feb 21, 2010 | Technics SA-DX950 Receiver
Only 2 port in the back of the dvd player is working
In some DVD players you need to activate the DOLBY or DTS settings in the audio menu. So you activate those options to get the sounds from all the speakers.
Make sure the DVDs must have DOLBY OR DTS recording.
Jul 25, 2009 | Televison & Video
My dts is not coming on when I attach it to the dvd with optical
DTS will only come on if you are playing a dts dvd,most of these dvd,s need you to pick dts in the setup menu or sound settings.If you have done this make sure dts out is set to on in your dvd player.
Hope this helps.
CABLE GUY.
Apr 20, 2009 | Kenwood VR-505 Receiver
Samsung dvd m101. cant get audio from a dts music dvd
You could try reset the player to the factory settings and see if that help. Press and hold the stop and play buttons down on the front of the player for 15 seconds then restart player. John
Jan 04, 2009 | Samsung DVD-M101 DVD Player
I cannot seem to get DTS-HD master to show on the receiver screen
You need to check 3 things:
1) DTS will only work through a digital connection (coaxial, optical, or HDMI) between your receiver and dvd player. DTS and Dolby 5.1 cannot carry a signal over red and white rca connections.
2) After number 1 is solved ensure the reciever is set to the digital channel, your DTS-HD in this case, or in an auto mode.
3) Finally the most important is that the signal is a DTS signal. Start a DTS capable dvd, go to the sound menu and set it for DTS.
Press play and all should be well...
Cheers,
NTIMID8
Dec 13, 2008 | Onkyo Audio Players & Recorders
JVC TH-C5 System Logo
115 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
