Question about Canon BubbleJet i550 InkJet Printer
More than one paper at a time
Our Canon i550 [6 yrs. old] seems to want to print a novel every time that we try to print a single page. When we hit the file or printer icon the printer will start the printing process but it will try to put sometimes 20 or sometimes 3 or 4 papers out at a time. Also the paper will travel part way out and it will get pulled back into the printing housing. These problems have just recently cropped up and maybe the printer is unrepairable.
  • 628 Answers
Are you saying that the printer pulls in too much paper at a time, or that it's actually printing on more than one page, even if you only want to do a single page? If it's pulling in too many pages, try fanning the paper. At times, especially in low humidity conditions, paper will tend to stick together and then several sheets get pulled into the printer. Fanning will often relieve the symptoms. Also make sure that the feed roller is clean. Use a cloth with some alcohol on it and rub the tire all the way around or as much as possible. See if that works.
Posted on Mar 17, 2009
Canon pixma ip1000 black ink stop printing suddenly
Based on your explanation I will try to help.
Your ink tank had run out. You can refill it through the bottom of the tank or just simply replace your ink tank.
Aug 11, 2017 | Canon PIXMA iP1000
How print back to back in canon LBP 2900B
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printer cannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn the page upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for the rest of the document.
I suggest you try a test page first, to get the printing the right way up on both sides of the page so it reads correctly.
Oct 01, 2012 | Canon LBP Office Equipment & Supplies
BJC-85 Not printing. New BC-10 and BCI-10. Paper loads normally
The problem you are having is with the print head and not the printer. Unfortunately, with these canon print heads, they are not dated, so it is possible to install a print head that was bought new and sealed, but is still dried out because it is old.
Try running the print head through one deep cleaning cycle, this sometimes will start to get an old print head flowing.
Deep cleaning cycle can be found by going to PRINTERS , right clicking on the BJC icon, selecting PROPERTIES from the drop down menu, and then selecting the MAINTAINENCE tab.
Check to make sure that the ink tank in the print head isn't dry. Even a new print head can have a dry tank if it's old.
Jan 10, 2010 | Canon BJC-85 InkJet Printer
Adf sporadically pulls fax/ copy through top
Yes,but the most imported part for dubble feeding is the sepatation pad,this white pad is on the lower part of the docfeeder and work with the feed rollers,fist make sure that pad is clean before you replace the rollers,and then replace the pad.
Jun 17, 2009 | Canon PC-1080F Plain Paper Laser Fax
11x17 Landscape will only print 1 page then switches to Portrait
I found an acceptable workaround. If I leave the paper size set to "defined by driver" in the Print dialog box and chose the paper size in the Page Set Up dialog box, that seems to do it. There were numerous complaints on the web about this and it seems to be a major glitch in CS3 with the Leopard OS.
Jan 13, 2009 | Canon imageRUNNER C5180 Color Copier
HP J5780 Problem-Line on printed pages
most likely you have a flat spot on the roller.
that is exactly what is going to happen, when the paper hits the flat spot or a low spot. the paper stops and skips. them the print is coming out smeared.
you can get a repair kit or replacement roller from HP.
Jan 04, 2009 | HP Officejet J5780 All-In-One InkJet...
Canon IP3300
clean you print que it prints all the pages because the print button was pressed several times so for to empty the print que unplug itwait 30 seconds then restart the printer if you press print more than once all the pages will print when the printer is turned on safety measure
Mar 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
MF4150 Printing all Black - pages covrerd in black
Yes. Exchange it while you can. It will more difficult after the first 30 days. Could be a toner cartridge not seated properly. Or could be a high voltage power supply.
Aug 10, 2007 | Canon imageCLASS® MF4150 All-In-One Laser...
Canon BubbleJet i550 InkJet Printer Logo
old marine
old marine
