Question about Whirlpool MH6150XMS Microwave Oven
MH6150XMT0 We had a small issue where someone, who will remain nameless (me) turned the microwave on instead of hitting the timer button to start a timer for some food on the stove. There was a metal pan in the microwave with tinfoil which started arching. The pan was one of those long ones and wouldn't turn all the way around in the oven. So it hit the door while it was arching. From what I can tell, it only damaged the inner window film and I've ordered the replacement film. How hard is it to remove the back of the door to replace this? Is just snapped in there? Should I really have a technician come out and do it?
  • SliderNC Jan 28, 2009
    Oh, it's a Whrilpool MH6150XMT-0 microwave. I guess that would help.
  • Whirlpool Master
  • 9,098 Answers
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams (and order any other needed parts) by entering your full model number here.
When you peel off the old seal tape, it's best to heat it up with a hair dryer and work slowly so it will all come off in one piece and to minimize the amount of adhesive that has to be solved and scrubbed off.
Posted on Jan 29, 2009
How can I to set clock on Sanyo Microwave EM-C678
1. Open door
2. Press clock/Kitchen Timer button the display will show "0:00" with the hour"0" flashing.
3. Enter the correct hour by turning the potary dial. Enter 1-12
4. Press clock/Kitchen Timer button the display will show "0:00" with the minutes "00" flashing.
5. Enter the correct minutes by turning the potary dial. Enter 00-59
6. Press clock/Kitchen Timer. The colon will remain flashing.
7. Close the door.
Sep 03, 2014 | Microwave Ovens
My oster OGB8901 microwave is having power situations it sometimes the power works and sometimes not i can hit the top and the power will come on than in the middle of cooking something it (the power)...
Hi, Could be a timer issue. Don't hit it anymore you will do more damage to it or even get a shock. Take it to a repairman or someone that has worked on one. Good luck.
Mar 17, 2014 | Oster OGB8901 Microwave Oven
Timer counts down. Microwave keeps going
It is a bad door switch, or the keypad control board is the issue.
Apr 11, 2012 | KitchenAid KCMS145J Microwave Oven
Whirlpool gold accuwave microwave oven lost power afer running em
Hello Davisaroundt, we are sorry to hear about your Microwave not powering on. If you would like for us to schedule service for you, then can you please email your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 13, 2017 | Whirlpool Accuwave Microwave Oven
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
Sansui Microwave: Nothing Happens when you hit start
there is a safty door switch,if that switch is not making proper contact this thing happens.open the microwave look for safty switch and replace it or if you know how to open it then clean it and it should work
Aug 07, 2009 | Microwave Ovens
Leaving microwave on pause
Unless the control electronics fail, leaving the oven paused won't hurt anything but it will enable someone unfamiliar with to restart it with nothing in the cavity and this can damage the magnetron. Unless you are just checking the food for progress, I wouldn't recommend leaving it paused and 'armed.'
Dec 28, 2008 | Kenmore 63252 Microwave Oven
Oster Nicrowave Model 0TM1101GBS: The timer works, but will not cook, I think it is the Child Lock
If the Child Lock is on, the microwave cannot be programmed.
What does the owner's manual say those flashing icons are?
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Sep 19, 2008 | Oster 0.7 Cu. Ft. Compact Microwave
Removing the control panel on the 1800XL to replace the fuse
Unplug microwave. Remove the two phillips head screws from the top at the very front edge, allowing you to remove the top grill. This will give you access to the one remaining screw holding the control panel in place. Lift panel up a bit and you're in. Note: even an unplugged microwave can hold a nasty electrical charge if the bleeder resister inside the capacitor is bad. Be cautious and don't touch things unnecessarily.
Aug 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Neff oven timer
Normally you enter the time digits, then hit power level then zero or hit the timer button (if so equipped) then enter the time digits and hit start.
Nov 12, 2007 | Neff H7871N2GB Convection / Microwave Oven
Whirlpool MH6150XMS Microwave Oven Logo
230 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
