Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Washer will not spin and finish cycle.
Bosch Nexxt wfmc3200uc will not spin or finish cycle. It drains a little water at the start of the cycle then you hear a little clicking noise. I have drained it out and tried again but no luck. any help here would be greatly appreciated. thank you.
  • robniner Jan 28, 2009
    I have already done that and the same problem persists. Anything else I can try. Thanks
I have the same problem not going into a wash cycle and get the "ready" message on the screen. It only went through a cycle with no clothing.With wet clotches back in, I put it into spin cycle manually and only the drain pump went on then back to ready. I tried this several times in a row and it finally went into spin cycle after draining each time before. I opened the drain clean out and got all of the water out(about 10 cups) with a wet dry vac. Now the machine goes through a cycle. The problem is intermittant and very common with this washer. I haven't seen a definitive solution yet. It seems to be an engineering problem with the drain and sensors.
Posted on Oct 01, 2011
  • 1 more comment
  • Jeff sanchez Jun 12, 2014
    Replacing the motor module solved the problem
  • Bryan w
    Bryan w Sep 06, 2014
    Thanks Jeff
  • Bryan w
    Motor module as in the printed circuit board or the motor itself?
  • 130 Answers
On the lower rhs is a clean out door, use ascrew driver to spin the door loose and clean out the pump behind the door.
Posted on Jan 28, 2009
I have a Bosch Nexxt 700 Series Washing Machine. We have been emptying our washer by shop vac for a couple months now. Nothing in the pump. Once through the wash cycle it will try to drain and then flash...
Is the pump pumping? Have you cleaned all the drain lines including the discharge hose? You may have nothing in the pump but it could be blocked somewhere else.
Apr 24, 2014 | Bosch Nexxt 700 Series WFMC6401UC Front...
Bosch Nexxt 100 washer will not fill with water.
Does the problem occur on both hot and cold washes. If not then check the inlet solenoid . If yes than check the board.
Jan 25, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
My washer will not complete a full cycle.. when on rinse does not finish beeps as though it done but is still on rinse..also fabric softner does not drain into machine. machine will spin if I manually set...
my washer does not finish a full cycle ;but is still on rinse and its a bosch and i was wondering
were is the fuses kept in the machine,
sandra read
sandrarread@yahoo .co uk
Jan 22, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
WFMC3200UC washer: The setting for the cycle is cold, but the water is hot. How to correct.
Check the water lines on the back of the machine. It sounds like the water lines are reversed.
Aug 13, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt 500 is on rinse cycle, won't drain the water or spin
Hi
I would check two things that might cause this problem .
1. there is small palstic capsule that comes out from the tank and has thin rubber pipe that goes to the electric tap. the purpuse of the tube is to send signale to the tap to close the water , actually the tap has a sensor that sence the change in presure when the water tank is filled . check this capsule and make sure that its clean.
2.looks like the cycle of washing hasn't started or started but hasn't pass the stage of heating the water . that means there is some problem with the heater that lies in the buttom of the tank . make sure all wires attached properly .
try run whashing program of cold water .
consider replacing the heater .
hope it helps
goodluck
May 25, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch washer - taking apart the anti-siphon valve
I have a Bosch Nexxt Washer when it goes into the spin cycle I get EOO2 and the washer stops
Mar 20, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
My bosch nexxt 500 series washer won't spin
possibly the motor brushes.
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
Oct 18, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt WFMC3200UC
Bosch Nexxt WFMC3200UC Water pouring out from beneath washer. This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Mar 15, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
787 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
