Question about RCA P61960 61" Rear Projection Television
Rca tv my guide plus has quit working
I love my guide plus and here about a month ago i got a message saying that my cable company was blocking my guide plus, since then i cannot use my guide plus all that comes up is no listing for every channel. i have insight cable.
is there anything i can do. is this legal for them to do that? i have a 61" rear projection that i bought new in 99
thanks
rob
  • 2 more comments
  • Anonymous Jan 29, 2009
    ABOUT A MONTH AGO MY CABLE COMPANY UPDATED FOR HDL AND MY GUIDE PLUS WHICH I TOTALLY USED WAS NOT SHOWING ANY INFO JUST STATED NO LISTING ON ALL STATIONS.....
    I WOULD LIKE TO KNOW HOW TO GET THIS BACK AS SOON AS POSSIBLE. THE GUIDE PLUS OPTION WAS ONE OF THE REASON WE PURCHSED THE TELEVISION.
  • dhb1ibo Jan 30, 2009
    I have the same problem and I'm using Continental cable, I will try hooking up an antena and see if this makes a difference. This also started the first of 2009 or there abouts.
  • kayaklessguy Feb 23, 2009
    I had the same problem with the same message about my cable company blocking input. I called Thomson electronics, and they put someone on the phone who went through some diagnostics with me on the Guide Plus menu. After about a week, they told me it had something to do with their broadcast, and it was magically fixed. That lasted about a week and a half, and now I'm back to square 1. Same problem all over again.
  • Anonymous Apr 26, 2009
    I have a RCA 61" TV also purchased in 1999. All of a sudden a couple months ago the guide plus stopped working. I have two RCA's and neither one works. I love this feature ad would like to get it working again. I have Knology cable. Does any one have an idea on how to correct this problem?
    Guideless
    Sergeant:
  • 227 Answers
The guide plus needs to reset itself over night. But as long as you are only connected to cable it will not allow for it to reset. You need a two way splitter the cable company signal will go in one side and the outside antenna or what ever you were connected to before cable will go on the other connector. The single side connector will go to the tv. Where the splitter says 'in' you will actually be using it as out to the tv. Where the splitter says 'out' you will be using as in for the cable and the other antenna. Guide Plus is built into your tv and needs the tv to be off to reset over night.
Posted on Jan 28, 2009
My Guide Plus stopped working 2 months ago. Time
Also on Time Warner Cable and two TVs have stopped receiving Guide Plus in the last month.
Does anyone have suggestions?
Jun 09, 2010 | RCA F36650 36" TV
RCA F36715 36" TV received this tv used from a friend. we do not have original remote so we use a generic universal remote. tv works fine, but we cannot get the Guide Plus+ to work. we went through the...
You're cable company may have quit using TV Guide info from "TV Guide", because they want you to get their box for this info, or to save expense. It happened here in Michigan about a year ago. If you have local ABC, NBC, and PBS stations, you can get this info downloaded nightly through an external "over-the-air" antenna.-- assuming you're in the U.S.
May 05, 2010 | RCA F36715 36" TV
I bought a 27 inch tv in 2002 now the tv guide
Here is a whole forum discussing this.
http://forum.ecoustics.com/bbs/messages/2/138384.html
It sounds like you need to reset your local zip code to 99999 then unplug the TV for at least 12 hours. Then plug it back in, reset to your real local zip code and go through the guide setup menus.
Dec 24, 2009 | RCA F27442 27" TV
Guide plus on my rca p52937 tv
You are right, the Guide Plus is transmitted to your tv over the air. If you have a cable company supplying your programs, your Guide Plus will not receive a signal to set up. You will need to get a two-way splitter. It has two connections on one side and one on the other. The side that has one connection goes to your tv. The side that has two connections will connect to your cable supplier and the other to a rabbit ear or outside antenna. Then the tv has to be off over night to restore your Guide Plus.
prs1c-2266633t98.jpg 2-Way Gold-Plated Bidirectional Splitter pixel.gif Model: 15-2587 | Catalog #: 15-2587 pixel.gif
Use this 2-way gold-plated bidirectional splitter to divide a signal to feed two devices, such as TV...
Jan 30, 2009 | RCA P46924 46" Rear Projection Television
Not receiving guide plus + tv listing -no problem until 2 weeks
I called TimeWarner Cable tech support, and the solution is to unplug the power to the box, after 1 min plug back in, let the box reboot, and PRESTO, this time around, the guide should be working.
Note--this is a solution for the problem of online guide that is showing No Data in the boxes, but is bringing up the grid of times/channels/date.
If you can't get the Guide at all, I don't know if this solution works.
Good luck.
Dec 16, 2008 | Televison & Video
My Guide Plus does not work. When I try to program it it says "The search for data has failed'" My cable company has checked my reception and it is OK. I love my Guide Plus. What can I do??? My TV is a...
Mine stopped mid-
December. I used the old reliable 99999 as my zip code, turned off the tv for an hour, turned it back on, entered my correct zip code and was patient. Today, the 15th of January, it popped back up. I have a feeling that it is all due to the switch over. I think different cable companies are setting things up and the gude was lost during that time. Maybe if you are patient, it will pop back up also.
Dec 12, 2008 | Proscan PS35660 TV
Guide Plus on RCA television
My guide quit working also on my RCA 61" big screen and I called the cable company and he said something about the encryption data had changed and I needed to call RCA to find out what to do and the whole time trying to sell me a converter box. It is the cable company's fault or the guide wouldn't have put that message up to start with. We all need to call the FCC!!!
Dec 04, 2008 | Televison & Video
I have 3 RCA TVs with Guide Plus and as of about a week ago I can no longer get the TV listings on any of them. I called RCA and they give me the same song and dance to reset and nothing worked. I get this...
Maybe the tv is to old I have a rc tv to but no cable you could get a new tv I guess not to sure maybe your anntane [an-tan-a] is broke if you have one
hope this helps
Dec 01, 2008 | RCA F36668 36" TV
Guide Plus
Called the cable company..they said they don't block the signal. sooooo..
first..i unplugged the tv from the power source, and unplugged the cable from the wall. left both off for an hour, and reconnected power and cable.
entered the guide set up...changed the zip code from the area where i actually live to the zip code of the cable provider for my area. here on maui, there is only one provider.
used the editor in guide plus to turn on and off the channel line-up according to the published channels listed in my area tv guide.
24 hours later...voila..!! it WORKS..!! good luck..!!
Oct 16, 2008 | RCA G36705 36" TV
RCA P61960 61" Rear Projection Television Logo
343 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
