Question about Apple iPhone Smartphone
Vibration how can i change ringtone to vibrate and how to lower ringtones, they r too loud lol
  • mofassa Dec 25, 2007
    my i phone doesn't ring when I get call
  • 140 Answers
The small switch on the top of the left edge of the iPhone turns on/off the vibrate function. Ringtones are affected by pressing the longer switch just below the vibrate switch.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ronald_f3c54257e2cc2559
Posted on Jul 26, 2007
How do I get a ringtone instead of vibration on my LG530G cellphone?
try going into settings and change the method from vibration back to ring tone
Sep 06, 2015 | LG 5350 37V 1550mAh Extended Life Liion...
Tracfone customer service
  1. Check a ringer volume and profile. Press a volume key to see the volume status bar at the top of the screen. Use the volume up and volume down keys to adjust the loudness of the ringer (scale 0 to 30). Tap on the text next to the ringer icon to change the profile (vibrate only, ring+vibrate).
  2. Check if the issue is with a specific ringtone: Go to Settings > ringtones+sounds > Ringtone, and tap on a playbutton to preview the ringtone.
  3. Switch off the ringer vibration (Settings > ringtones+sound > vibrate) temporary, to determine if your phone is affected by any motion settings i.e. Flip-to-Silence.
  4. Make sure that call forwarding is not switched on: Tap the phone icon > ... > Settings.
If the problem persists, restart your phone by pressing and holding the power and volume down keys simultaneously until the phone vibrates. Release and the phone will restart. After this operation, you may need to re-adjust the volume and set date+time on the phone. Note that this does not remove your personal content.
Mar 13, 2014 | Computers & Internet
I can't change my ringtone. It's stuck on vibrate
press the # so that you can change from vibrate to tone
Apr 09, 2010 | HTC Snap S522 Cell Phone
How to change from ringtone to vibrate and back
Press and hold the * key to switch to turn "Vibrating mode on." Press and hold * again to turn "Vibrating mode off."
Dec 23, 2009 | LG CU515 Cellular Phone
Change Ringtone Automatically when charging
The BlackBerry gives few profiles to choose from; e.g. Normal, Loud, Quiet, Vibrate.... my recommendation would be to configure each profile separately and just enable/disable the profile you like when you enter/exit your car...
The phone itself is not capable to switching the profile on its own once it is plugged in to your car charger...
Hope this was helpful...
Nov 10, 2009 | RIM BlackBerry Curve 8310 Smartphone
My Slice phone no longer rings out loud or vibrates when a call comes in. How do I restore those settings?
Check out this link for a PDF manual for your phone. Just copy and paste into your browser.
http://safemanuals.com/user-guide-instructions-owner-manual/UTSTARCOM/PCS1400-_E
I got this info off of page 60 from your manual.
CUSTOMIZING YOUR PHONE VOLUME
Control the volume for Ringtone, Speakerphone, Headset, and Advanced settings.
Ringtone
Set ringtone volume and incoming call alert options:
1. Press [Menu], then press "Settings".
Press "Sounds", then press "Volume".
2. Press "Ringtone".
3. Press / to adjust the volume level. Press to select Vibrate when High is the volume level.
The volume settings available are:
• Silence all: All sounds are off.
• Vibrate : Phone will vibrate to alert you of incoming call or message.
• Off: Only the ringtone is muted.
• Ringtone mode: Low, Medium, High.
Tip • You can adjust the ringtone volume with the side keys.
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Oct 05, 2009 | UTStarcom PCS1400 Cellular Phone
Cell cant ring
ur ringtone is in the vibrating mode i guess.... better change ur ringtone to loud or ascending in ur PROFILE.........settings--->profile
Oct 05, 2009 | Motorola Mobility PEBL U6 Cellular Phone
Change ringtone on phone
go to your main menu, click options, then click profiles(ring tones), then click which profile you would like to change (ex. loud, vibrate), once it has "(active)" next to it, click on it. then you can click on phone, SMS text and so on. then you just pick the ringtone
Jun 09, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
No ringtone on Katana phone
Sure the phone is not in sient mode.Is loud speaker working. if not change N2150 ringer IC or get it changed with a technician.
Nov 19, 2008 | Nokia 1110i Cellular Phone
Message tones and vibrate facillity
To change the vibrate function:Go to main menu, phone settings, phone profiles, highlight the 'normal' one & press the 'options' soft key to the left of the touch screen keypad. Pick 'edit', then the 'call alert type' will be highlighted. Press the left soft key saying 'options' & select 'change'. You can then opt for it to vibrate by highlighting the vibration one & pressing the tick on the touch screen bit. Then don't forget to save the changes!
To Change the ringtone:
  1. From the standby screen, press Menu (Figure 1).
  2. In the main Menu, press Settings (Figure 2).
  3. In the Settings menu, select Phone profiles and press (Figure 3).
  4. You will be presented with a list of phone profiles for different situations and environments. The one you're currently using will be ticked. Highlight the one you want to use (in our example, Normal) and press the Edit button at the bottom of the display (Figure 4).
  5. You are taken into the profile settings (Figure 5). At the top of the list you'll notice three tab icons - these represent (from left to right), ringtone, message alert, and keypad sounds. You can switch between settings for these by tapping one of the tabs.
  6. You should be taken first into the ringtone settings list. Should you want to change the Call alert type (from melody to vibration then melody, for instance) tap this option and scroll through the list of options to choose the one you want.
  7. To change the Voice call ringtone, tap this option on the screen. You will be taken into a list of phone file folders from which to choose your ringtone (Figure 6). You can tab across to view files stored on a memory card, if you have one installed.
  8. Press the Sounds option. You now have the choice of choosing from yourMusic files, Ringtones that are loaded onto the phone, or My voice clips(clips you have recorded) (Figure 7). You can select from whichever of these folders you want - the setting procedure is the same for each. In our example, we'll choose from our Music folder to select one of our tunes as the new ringtone.
  9. Press the Music option. A list of tracks appears (Figure 8). Tap the one you want in order to highlight it (Figure 9). Press Options, then tap on theSelect menu option to install it as your ringtone (Figure 10).
  10. You are now taken back to the Normal profile settings, where the Voice call ringtone has changed (Figure 11). To save this change, press Options and then Save (Figure 12). Alternatively, press Back and you will be asked whether you want to Save?. Press Yes.
In the ringtone settings menu, you can also change the video call ringtone (which is lower down the menu) by following the same procedure.
Aug 27, 2008 | Samsung U900 Soul Cellular Phone
Apple iPhone Smartphone Logo
310 people viewed this question
Top Apple Cell Phones Experts
jacobcheatha
Level 1 Expert
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
