Question about Hoover F7431-900 SteamVac Vacuum
Hoover SteamVac Spin Scrub carpet cleaner has lost suction
Used a lot on floors with pet hair on them, but no visible clogs. Became noticeable that floors were wetter than used to be, but now seems to have stopped sucking up water altogether. Machine is about 8 years old and has had moderate use.
  • DaMuse Feb 21, 2009
    When I turned on my Hoover Steam Vac today, the little red float in the dirty water tank popped right up - which it's only supposed to do when the water is sudsy or the tank is full. When I turn it off, the red float drops back down, but comes right back up when I turn it on again. It won't suction as long as the float is up. HELP!!!
VacuumRepair
  • 438 Answers
SOURCE: Scrub brushes not rotating
Hi There,
You'll need to first diagnosis why these brushes are not spinning. When the SpinScrub brushes on a Hoover SteamVac don't spin, this can be 1 of 3 different things.
In order to diagnosis which one of the problems is causing your problem, here's what you'll need to do.
Step 1. The first and easiest thing you should check is to make sure that that the brush speeed selector knob on the top of the machine is turned on, and is not in the off position. This may sound obvious, but I've had several cutsomers that have come in with this exact problem, only for the brushes to be turned off. Also make sure that the SteamVac's handle is reclined, and not in the upright position. There's a switch inside that shuts the brushes off when the SteamVac is moved into the upright position. If the brushes still are not spinning, move on to step 2.
Step 2. You'll need to remove the SpinScrub brushes from the SteamVac. Turn the machine upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed (my left hand was holding the camera, lol), but the tabs on the left hand side are in the exact same location:
Step 3. Once the brushes have been removed, plug the machine in, make sure that the handle is reclined. Look in the SteamVac where the brushes used to be. You should see a hole that is square shaped where the brushes go into.
Turn the machine on, and look to see if this square shaped hole is spinning. If the hole is spinning, this indicates that either the brush block itself is bad, or there maybe something clogged (such as pet hair) in the brushes that's preventing them from spinning. If the square hole is not spinning, this indicates that your internal turbine brush gear has gone bad. Here's a link to a repair that I've written on how to replace the internal brush turbine gear if the square shaped, female receptacle hole is not spinning.
If the square shaped hole is spinning, here's what you may do to see if the brush block is just jammed up with debris, or if the brush block itself is bad and needs to be replaced:
Step 1. I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem.
you should look at the brush stem that goes into the turbine inside the machine. This is the green pole pictured in middle of the brush block. Examine this pole to determine if the top of it has broken off. It should exactly how the picture shows it. Make sure that the plastic has not broken. If the pole has broken, you will simply need to replace the brush block.
It can really only be one of these three things that are causing your brushes not turn. Here are links to all of the products that possibly need to purchased (if the brushes weren't just clogged) on our website for the model that you listed this repair under, the Hoover F7425-900.
- Hoover Brush Turbine Gear Assembly Part 43191009
- Hoover Brush Block SpinScrub 6 Brushes For F7425-900, Part #
48437030
I hope that this helped you figure out the problem. If you have any follow up questions, please use the Clarification Request form here on Fixya and I'll be more then happy to follow up with you and help you out. If you found this helpful, may you kindly please rate my repair helpful by clicking the thumbs up icons in the top right hand corner of the repair? This is really what keeps Fixya repair experts coming back to give free repair advice, and helps Fixya users continue to get the free replies without having to pay for answers. It's greatly appreciated.
Thanks,
Chris J.
GoVacuum.com
Posted on Apr 13, 2010
SOURCE: Leaking Hoover Steamvac
Mine did this exact and it turned out my pump was cracked.
Posted on Mar 30, 2008
reddevil6
  • 1673 Answers
SOURCE: hoover steamvac won't spray water on carpet.
Check the ank valve to make sure when you push it in that water is coming out. The reservior asm, (the tank bottom sits on this)is bad or the rod in the handle isn't pushing the reservior asm when you squeeze the trigger.
Posted on May 15, 2008
reddevil6
  • 1673 Answers
SOURCE: Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
Posted on May 26, 2008
  • 107 Answers
SOURCE: NO DIRECTIONS FOR HOW TO ATTACH AND USE STAIR TOOL FOR MY HOOVER
Here is the link to Hoover's manuals. I could not locate a model F5900-900 But i believe it is F5914-900. Please verify before downloading manual by checking the serial number stick for a model. Its silver and should be on the back or bottom.
Posted on Dec 09, 2008
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
How can I get power switch to work on hoover spinscrub steam carpet cleaner?
Replace the switch.
http://www.ereplacementparts.com/hoover-f5914900-steamvac-with-clean-surge-parts-c-37315_37419_37425.html
Aug 28, 2014 | Hoover SteamVac F5914-900 SpinScrub...
On hoover steam carpet cleaner, the brushes do not rotate on low or high settings.
Follow these steps if the Brushes Fail to Spin
•If the brushes on your Hoover carpet cleaner fail to spin, there may be a problem---some sort of blockage---with the suction or with the belt that turns the brushes.
Turn the Hoover carpet cleaner over, and inspect the brush area. Debris, strings, or pet hair may be tangled in the rollers, keeping them from turning. Use a pair of scissors to cut away any obstructions in this area. Flip the Hoover carpet cleaner back over, and turn it on to see if cleaning the rollers has solved the problem.
To check the belt, turn the Hoover carpet cleaner over, and remove the bottom plate screw with a Phillips head screwdriver. Investigate the belt area to see if it is broken or has somehow slipped off. If it is broken, you can order a part from Hoover.com or from many of the other online parts stores.
When the belt arrives, simply slide it on in place of the broken belt, reattach the bottom plate and turn the Hoover carpet cleaner right-side up. Turn it on to test your solution.
Sep 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
The hoover shampooer will not extract the water from carpet, is it because the carpet is so low ?? the carpet is cleaning fine there is VERY poor underlay and then wood under that, worried about the wood...
do you have suction at the front of the base,if you don't then look at the plastic cover on the base,you should be able to see through the plastic.the suction slot on the bottom front of the base is very narrow.i don't know if you have pets but most of the time the suction chanel gets clogged with hair and dirt.the chanel is right up the middle on top of the base.look in there and see if you don't see a lot of hair and dirt stuck up inside.there are some screws on the bottom that you need to take out to remover the cover.then the cover comes apart in two pieces to allow you to get to the suction chanel.please leave some feedback.i hope i was some help to you
Apr 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Lost suction
there is a screen by the brush that may be clogged. Make sure the water tank is on tight
Feb 19, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Have a Hoover Steam Vac Spin Scrub, Model # f5858-910
You can order parts from http://www.searspartsdirect.com
Dec 08, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac Deluxe
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=624426
Posted by providence51 on May 26, 2008
My cleaner is not dispensing the shampoo solution. Still sucks up the dirty water that I manually applied with a scrub brush. I use this on my tiled screen porch floor and it has worked great many times.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There is a release value in the bottom the holding tank that may be bad and not opening or the trigger assm in the handle may be broken and not connecting to release the water to scrub and clean the carpets. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
May 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
HOOVER STEAM VAC SPIN SCRUB
Cannot hook the upholstery cleaner into slot..lost manual in fire
Jun 16, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
171 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
