Question about Ariens 34 In. Zoom Series Riding Mower
Ariens snow blower. Cannot get fan hub off the worm gear shaft.
I have every thing apart , except I cannot get the fan hub off the worm gear shaft. The two roll pins are out. It seems the shaft and hub are rusted from years of service. I have tried heating, soaking and hammering the assembly but nothing will move.
  • largevan Feb 02, 2009
    I finally got it out by putting it in a shop press
2 Suggested Answers
SOURCE: on my ariens snow-blower: Drive shaft spins but....
check the sheare pins
Posted on Dec 21, 2009
Auger replacement
Here is a manual for your snowblower. Yes, It's the same. http://download.sears.com/own/spin_prod_674132601.pdf . Go to page 30, it a parts diagram of the blower and housing.
You will need to remove the pulley #66 from the back of the unit, the bearing retainer #1, and the auger bearing bolts #18. The whole unit will then slide out of the housing. You can then remove the augers and then take the worm gear apart. That will get you to the auger shaft.
Mar 24, 2014 | Agri-Fab Agri - Fab Snow Blower - 42"
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Auger shaft jamed
Try removing the belt and turning it by hand. If that doesn't work, you may have blown something into bits inside of the gear case.
Nov 03, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
I have an Ariens 926LE snowblower. The blower spins but the auger spins slowly. It barely throws snow. Some times the auger stops spinning. Shear pins are fine.
Hi, The blower spins at full speed? If it does the belt, pulley, and shaft are good. Look at the shaft from the fan to the gear box while it's running and that shaft should be turning at the speed of the fan.
If the blower spins at full speed and the auger doesn't the most likely problem is the worm gear transmission from the blower shaft to the auger shaft.
A good way to visually inspect this is: With the machine turned off and the spark plug wire unhooked go to the front and try to rotate the auger by hand. If the gear box is good you will only be able to move the auger less than an inch. If the box is bad you will be able to move the auger a lot farther. While you are there recheck your shear pins.
You can also remove the blower drive belt and have someone turn the pulley by hand while you watch the auger. Put resistance on the auger with your gloved hand. If the box is good the auger will move smoothly in you hand. If it is bad, it will ****, move roughly, or stop.
While the other person is turning the pulley and you have some resistance on the auger look closely at the shaft running from the gearbox back to the blower. On some models there is a connecting sleeve and the roll pin that connects the sleeve to the shaft and gearbox will break.
If the gearbox is bad, it will have to be replaced as a complete unit.
Was this helpful? If you have any other questions, please ask.
Jan 10, 2011 | Garden
Unable to remove hub 02438900 to replace bearing on ariens 1128 snow blower. This is the pully/hub that controls the auger.
I also had this problem. I actually pulled the ears off of the hub using 2 different pullers. I ended up heating the hub and hiting the shaft through the hub with a small sledge. It took 45 minutes. Then I tried to remove the impeller from the shaft. Not a chance! Both pins out but it would not budge. This is a customers machine and it needed a gearbox. I'm going to end up putting an impeller on it as I can't get it off the old shaft.
Sep 06, 2010 | Garden
Only one blade turns automatically on Ariens snow blower.
There is a bolt that goes through the center of the shaft that shears off if you hit something. You will need to line up the holes of the internal shaft with the auger tube and install a new bolt.
Feb 09, 2010 | Ariens 34 In. Zoom Series Riding Mower
I have a ariens snow blower model 1128 when i engage the impeller turns and the shaft to the auger gear box turns but the augers don't turn. the shear bolts are not broke either
Have you confirmed the bolt integrity completely through the shaft? Also check the gearbox for proper lubrication or gear failure.
I recommend contacting your nearest authorized service center, or you can download operators and service manuals typically online by performing a simple Google search using your make, model number and part needed.
Downloadable Manuals
I trust this information proves beneficial.
Jan 02, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
Ariens snowblower auger wont turn
Just finished repairing my ariens, 6 years old with aluminum gear box. Same problem encountered. The problem turns out to be the BRONZE gear driven by the worm shaft. Shear bolts did not shear and bronze gear broke about 5-6 teeth. This is why you can move the auger a half turn or so, there are no gears in one area of the gear and as the gear turns to engage the worm drive it will stop. The fix: the cast iron replacement from ariens! About $200 including shipping, got mine from Jack's Small Engine (MD). Fairly easy repair if you are mechanically inclined. Buy yourself a set of roll pin extractors ($20 from Sears), new roll pins, new woodruff key for shaft. You will also probably have to press 2nd stage impeller from shaft with hydraulic press & heat (took mine to my local auto garage). What stinks is ariens seemed to have admitted the design problem with the aluminum gearbox, yet won't help with repair cost! Anyways, I learned a lot about my snowblower for future repair (belt replacement)!
Dec 21, 2008 | Garden
Ariens 34 In. Zoom Series Riding Mower Logo
144 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
