Question about Compaq Hewlett Packard 6910p Notebook
Change the fingerprint user
Recently sold a laptop to a friend and don't know how to change fingerprint recognition or change manual password.
Can you help, please?
Carol
Fingerprint
Use the fingerprint to log in, open the user application in the control panel and change your password.
Sep 28, 2013 | HEWLETT-PACKARD Pavilion dm4-1265dx...
My laptop has a fingerprint how do i change
Run the fingerprint software.
* Search the software for "change user/ or print"
(in order to change you need to print again the old before replacing it with the new one.)
*Swipe the old fingerprint and choose change new
* Swipe the new fingerprint data
tnx
Aug 18, 2011 | HP Computers & Internet
Asking fingerprint password
Is the problem that it is asking for a fingerprint password?
You can skip the fingerprint password and log in manually by typing the sequence of Ctrl + Alt + Delete 2 times. This will let you put in an user and password.
Did someone perhaps set fingerprint password while you were not looking?
Mar 04, 2011 | HP EliteBook 6930p Notebook
I don't know how to use the finger recognition on my toshiba satellite , please help
Hello there!
Take note that for security-minded individuals, some Toshiba laptops can feature a fingerprint reader. This is incredibly more secure than facial recognition. You are the only person the world with your fingerprints. As long as you keep all your fingers on your hands, using the fingerprint reader is a secure way to logon to your laptop. A fingerprint reader is accurate and almost impossible to deceive, unlike facial recognition software. The convenience offered by the Toshiba fingerprint reader does not add any security risks. You can simply place a finger on the reader and access your user account.
There is several ways on how to set it up and it depends on the model. May I ask, what is the model of your Toshiba laptop?
Regards,
fossildude
Nov 13, 2010 | Toshiba Computers & Internet
Been using face recognition for log-on; would like to change my password but the system doesn't recognize my password. how can i remove or change it?
Start up in Safe Mode (Hold F8 at startup) and log in under Administrator. Then go to start menu, control panels, users and change the password of your login. Restart.
Aug 29, 2010 | Computers & Internet
HAVEA TOSHIBA LAPTOP WITH A FINGERPRINT IDENTIFIER TO OPEN WINDOWS, WANT TO CHANGE THE FINGERPRINT TO MY DAUGHTERS. HOW DO WE ACCESS THIS?
dentifying the fingerprint readerA fingerprint reader provides extra security for the PC. The VeriSoft Access Manager by Bioscrypt uses the fingerprint reader to identify the user, and controls access to Windows or other secure systems. Instead of typing a User ID and password, you can move your finger across a sensor to logon or start commonly used applications. Verisoft Access Manager can manage all of your different secure accounts and the required user names and passwords by recognizing your fingerprint.On HP notebook PCs, the fingerprint reader is a small metallic sensor located near the keyboard or display. By swiping your finger perpendicular to the metallic sensor you can logon to the PC, a network, or open a program. c00897920.gifBefore you can use the fingerprint reader, you must set up the fingerprint reader by registering your fingerprint with the Access Manager. Set up the fingerprint reader To set up the fingerprint reader to recognize a user, the user must have a logon account on the PC and the account must have a password. Multiple users can be registered for the fingerprint reader if each has their own user account.
  1. In Windows, double-click the VeriSoft Access Manager icon c00897921.gif in the notification area of the taskbar to open the My Identity window. Alternately, click Start > All programs > Verisoft > My Identity .
  2. Click Log On to open the VeriSoft Logon Wizard. Click Next to begin.
  3. Enter the User's Windows password in the Password field on the Introduce Yourself page, and click Next . If you have successfully logged on to Windows, click Finish to close the wizard.
  4. Click Register Fingerprints on the My Identity window, to open the VeriSoft Logon Wizard. Click Next to begin. c00897922.gif
  5. Select a finger shown on the hand graphic, and then slowly swipe your finger across the sensor. One of the squares below the hand graphic will change color when the scan is accepted. A message displays if the scan is not accepted.
  6. Swipe the same finger across the sensor again until all four squares change color, then clickNext to register the finger print. If you need to start over during the fingerprint registration process, right-click the highlighted finger on the screen and then click Start Over .
  7. If prompted to register a second fingerprint, click a different finger on the hand graphic, and then repeat steps 5 and 6.
  8. After using the Registration Wizard to registered at least 2 fingers, click Finish .
  9. To set up the fingerprint reader for a different Windows user, log on to Windows as that user and then repeat steps 1 through 8.
After registering your fingerprint you can log off and then use your registered fingers to log on to Windows. Using Fingerprint reader before registeringIf you swipe your finger across the fingerprint reader before it is set up, the Access Manager opens a logon wizard window and prompts you for informa
Feb 03, 2010 | HP Pavilion DV5234US Notebook Laptop
How to use password instead of fingerprint to logon
How to disable fingerprint reader
In Windows, in the settings section of the Fingerprint Control Center, uncheck Replace windows logon with fingerprint protected logon. In the Fingerprint section uncheck the Power-On Security section if the user has fingerprints enrolled there. You do not need to uninstall the software unless you wish to.
Nov 12, 2009 | Microsoft Computers & Internet
I have forgotten my password and need to connect a new computer to my router-the router is a belking plus mimo and I have a linksys wireless g speed booster -what do I do to fix this? Many thanks
Reset the both routers in order to go to the factory default setting.
BELKIN (192.168.2.1) normally has no user name or password. So just hit enter.
Linksys (192.168.1.1)
User Name: admin
Pass Word: admin
You can always change the user name and password
Good Luck!
Sep 04, 2009 | Linksys WRT54SG Wireless-G Broadband...
How do I change the fingerprint recognition for a updated user?
Click on your Start Menu, then select All Programs, then select ThinkVantage. Under this menu you should see the fingerprint reader software. Towards the lower left part of this screen you'll see a button to "Delete All Fingerprints"
Jun 21, 2009 | Lenovo ThinkPad X61s Notebook
Cq45-112au compaq laptop,i installed xp but fingerprint password is not working properly,what can i do & where i can find the drivers plz
u should install the recorces cd provided with your laptop to install the drivers for the fingerprint recognition device
cheers
Jan 24, 2009 | Compaq Presario Notebook
Compaq Hewlett Packard 6910p Notebook Logo
223 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
