Question about Prestige APS686T Remote Start and Keyless Entry System with Additi
Prestige remote starter fell in bowl of water
I dropped my prestige remote starter in a bowl of water and now it still lights up but my car doesn't react. I don't have the manual because it the starter came with the car when i bought it. Is there anything I can do to make it work again?
  • efanouknow Feb 24, 2009
    My dog chewed mine and now it doesn't work. When I purchase another one will I have to re set it or will it work already for my car?
  • 116 Answers
Wasn't the unit hooked up already? You can't plug it back in? I'm still trying o picture the dropping into a BOWL? of water???
Give me the model and I can give you color codes, but if the wiring is still in tact you shouldn't need to rewire. Let me know and I'll help you out.
Larry T
Winona Lake, IN
Posted on Jan 28, 2009
Prestige APS787C wont start car
Try reprogramming the remotes: Turn ignition on, press and release programming/Valet button on antenna three times. You should here a short chirp, press the lock button on one remote. You should here a long chirp. Press the lock button on the other remote, you should here a long chirp. Turn ignition off. Test system.
Feb 11, 2013 | Prestige Remote Start
2011 jeep grand cherokee prestige remote starter drivers sid parking light
The technical documents list the parking lights as being in the drivers kick panel but, I have never found them there. I usually grab the parking lights for this vehcile at the fuse box under the hood. They are white and brown and, white and orange. Double diode the wires.
Aug 10, 2012 | Prestige Remote Start
My preinstalled prestige remote starter has worked twice at the dealers and i got it to work once. my question is do this combination sounds fimiliar for a chevy 1500. lock doors...lock door again, ho
If it is an add on remote starter, then you would use the factory remote to start it. If using the factory remote to start there are a couple of combinations to start it. Try lock, unlock,lock for Prestige/Pursuit models. If Directed models, try lock, lock or lock, lock, lock. If its a GM remote starter, press lock and then hold the remote starter button(circle with arrow.
Aug 03, 2012 | Prestige Appliances Vehicle Parts &...
I have a prestige remote Audio box starter remote alarm on a 2002 Toyota Camry.I unplugged the sensor and the car still doesn't start.can you help me i am out of the state need to get home.
Locate the valet switch( black push button), turn ignition on, press and release valet switch. the valet switch is plugged onto the main control unit. You can find the main control unit by tracing the harness that you unplugged from the shock sensor. The valet switch is plugged into a two pin plug and has a blue end. Trace the wire to the valet switch.
Jul 10, 2011 | Prestige Remote Start
Check engine,airbag and wrench lights come on the dashboard
Sound like they tapped into a low voltage ingnition wire or a data bus wire. It needs to be doubled checked for correct wiring. These new cars are very sensitive computer systems, its more than likely an improper wire.
May 29, 2009 | APS787 Prestige Remote Start and Security...
Alarm remote dropped in water alarm enabled on entry
open your remote soak the circuit board in 90% rubbing alcohol then blow dry on medium heat it should work as good as new
Apr 01, 2009 | Prestige 2 Button Remote Security System...
Prestige platinum by audiovox need to replace the remote for it
if you need a remote you can buy one from and also you can download the installation manual and user manual in which that will tell you how to program the new remote for the remote start.
Feb 15, 2009 | Prestige 2 Button Remote Security System...
Prestige APS686T Remote Start and Keyless Entry System with Additi Logo
458 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
