Question about Refrigerators
I have a 5 yead old Maytag, side by side, refrigerator. Suddenly It has begun to thaw. I will admit though that it was packed to the brim with food. Could a packed refrigerator cause this problem or is it more like the coil is going bad?
The problem may be solved but I still need to watch it for a few more days. The solution was to remove the back freezer panels and use a hair dryer to defrost the coils. The freezer works well but the refrigerator still seems to be slighly warmer than before (may be my imagination). Anyway the liquids are cold to the taste so I should be ok. If the refrigerator gets warmer, in the next few days, I will change the defrost board.
Thanks for your response!
Posted on Jan 30, 2009
Refrigerator and Freezer not cooling Maytag MFI2665XEM7
check to be sure condenser fan motor is still working bottom back of refrigerator , also is there frost at back of freezer if so you have a defrost problem,
Nov 30, 2013 | Maytag Refrigerators
Coils in my 2454 packed solid with ice. Thawed it out....worked fine for a couple of weeks. It quit staying cold so I dug behind the freezer to discover the coils again encased in ice. Thawed it...
your defrost heater around the coils is open and can no longer heat,or the adaptive defrost timer or defrost thermistor are defective located in the refrige control panel behind the temp controls and the thermistor is located on the defrost heater assy
May 02, 2010 | Maytag MSD2454G Side by Side Refrigerator
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
The freezer is warming up
If you found something lodged in the door that may have kept it open for a while, i suspect frost formed on the coils behind the panel. Frost will not let air pass through the coils to the refrigerator side. This is one of the most common problems there is. If you look through the louvers on the rear panel that is for sure your problem. It most likely just needs thawed out. After it is thawed out, your normal defrosting routine will take over again and hopefully you will be trouble free again.
May 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Electrolux side by side refrigerator
this uses a adaptive defrost board its located in the fridge compartment in the back left side remove the cover and you'll see the adaptive defrost board if you have any questions don't hesitate to e-mail me @ hvac.tech7872pr@gmail.com
here's an URL of the diagram (copy paste link to your browser)
http://www.partselect.com/Schematics/Frigidaire/XFXTKOQX.gif
Aug 02, 2008 | Frigidaire FRS26R4A Side by Side...
Admiral - GC2224GEKB
Does freezer cool like the cold food section? Did this suddenly happen, and frozen food began to thaw?  Most freezers control the cooling in the cold food section. The freezer must work fine before the cold food section will work fine. Let us know more, Thanks JT
Oct 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
