Question about Sharp FO-DC550 Laser Fax
Error H3 00 appears not found in guide book
Our power went off and when it came back on the fax had an h3 00 error code and we can't find this error in guide book.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
H3-00 Heat roller high temperature detection
The fusing temperature exceeds 240C°.
Thermistor abnormality.
The easiest and cheapest solution is to replace the fuser.
This is very typical of a laser machine as some point the fuser will go out.
These little machines have a disposal fuser unit. It is possible to replace the parts. After the time and parts, in the long run it is cheaper to replace the whole unit.
Posted on Feb 06, 2009
Code h3-00
This appears to be a "Heat Roller High Temp" error
Dec 10, 2014 | Sharp Ar-507 Digital Imager Copy Machine...
"Failed to read the PC-FAX Phone Book"
Try this
Browse to Control Panel > Administrative tools > Computer management > Services and Applications > Services
Locate the following services:
1. Telephony
2. Network Connections
3. Remote Access Connection Manager
4. Remote Access Auto Connection Manager
Right click and select Properties. On the General tab, next to Start Up type, select Automatic followed by OK.
May 09, 2014 | Epson Artisan 810 AllInOne InkJet Printer
Error code:1203
Hi Your error is to try
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Dec 24, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
Error H3-00
Hello sir; This error code require a reset procedure ;
press "#", "*", "clear", "*",these four keys by order, then enter 14 press start. then turn power off and back on.
Aug 26, 2009 | Sharp AR-168D Copier
It reads close back cover when i close the back cover it continues to say the same thing and wont let you do anything elese has anyone else had this problem ? if so how did you solve it
* Open the back cover
* Pull the flap down that hides the orange roller on the fuser
(Careful it's Hot on that fuser!!)
* Locate the thin piece of plastic that runs from the centre to the right hand side. This bar is the problem
* 3/4 along the right hand side, there is a sticky out bit on this bar that should sit in a hole.
* I have found three printers where this was not located properly. Once I located it properly, the 'door open' error went away.
This can be guide found here
Mar 04, 2009 | Brother IntelliFax-2820 Laser Fax
Brother MFC 210C
I am unable to clean and ended up with these notice (unable to print see troubleshoot in user's guide book).pls send the solution to the e-mail address provided.
Apr 03, 2008 | Brother MFC 210C All-In-One InkJet Printer
Error code H3 displayed on Xerox XC1044 Copier
this is the solution:
To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: 'Clear', 'Exposure Mode', 'Clear', 'Exposure Mode' (Exposure Mode is the button on the far left). The console will go completely blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the 'Print' button, then the second part of the code followed by the 'Print' button again.
To exit diagnostics: Press 'Clear' repeatedly or turn the power off.
*To clear a fuser code:(14) Enter diagnostics, select '14' followed by 'Print'... exit diagnostics.
H3 stands for high temperature at the fuser.
Mar 15, 2008 | Computers & Internet
Code error 021 not in book inforation codes
1. Push the function button
2. Push 7 on the key pad
3. Push Monitor button 4 times (it will only beep at you - nothing will appear on the screen) - so count the beeps)
4. Push * on key pad
You should now see the service menu option
5. Push 7 on the key pad
6. Push "Set" button
7. Push down arrow button once
You should now see the fuser reset option
8. Push "Set" button
You will be prompted for 1 for Yes 2 for no
9. Push 1 on key pad.
You should receive confirmation that the reset is *COMPLETE*
10. Push Stop button until back to the main screen
11. Power down the fax
12. Wait 5-10 seconds.
13. Power on the fax (and cross fingers)
Jan 02, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Printer Code and Power Failure Error
the machine memory is hung
try this
press Function 7 monitor(4 times) *
service mode is appear
scroll down.. select Ram initialize select all job clear.. if the problem still there.. repeat the procedure but instead of all job clear.. select the Flash memory clear.. found it after all job clear mode
Oct 29, 2007 | Panasonic PanaFax UF-490 All-In-One Laser...
Not printing
hi i have similar problem .error code 5a .can you help ?
Oct 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
Sharp FO-DC550 Laser Fax Logo
219 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
