Question about Acer TravelMate 2300 Notebook
Startup freezes and laptop won't even switch off in XP
Acer Travelmate 4220, Windows Professional (SP2). Startup proceeds until unput required from mouse to select user. Mouse freezes and power down button won't allow to switch off, even when held down for 5 seconds or more. Have to take battery out to switch off!
Startup in Safe mode is OK, including mouse, and after that computer will start up correctly when reset. However after switching off the problem will re-appear.
I have carried out chkdsk /r and a few bad sectors were repaired, then reinstalled Windows XP from fresh, and new drivers from ACER website. The computer had virus protection (AVG). I tried to use the XP disk to repair the original XP installation but the mouse kept freezing and had to resort to a new installation, but now even with that the problem has returned exactly as before.
Could it be either a BIOS problem or a faulty RAM section? What else is it likely to be?
Thanks for your help
Lindsay Easson
  • lindsay_eass Jan 29, 2009
    I will have a go at updating the bios but I would appreciate any other suggestions the experts may have
    Thanks
  • 679 Answers
It's not the bios, i doubt it's the ram, very rare to get a virus in the ram. But here is what from your description it "may" be. Even though you formatted the drive prior to reinstalling windows, the virus, "if that's what it was" can still be there unless you do an Fdsk, that will clear everyting from the drive. If it was a nasty virus it very well can still be there. You can google this and see that what I am telling you is quite common, formatting does not kill viruises, i copied the following for you to better explain what fdsk does,
Most effective anti-virus products will be able to remove a virus from
a partition sector, but some have difficulties under certain
circumstances. In these cases the user may decide to use FDISK /MBR.
Unless you know precisely what you are doing this is unwise. You may
lose access to the data on your hard disk if the infection was done by
a virus such as Monkey or OneHalf. Part 4, section 14 of this FAQ
contains details as to how losing data might happen.
(v) Won't formatting the hard disk help?
Not necessarily. Formatting the hard disk can result in everything
being wiped from the drive *apart* from the virus. Format alters the
DOS partition, but leaves the partition sector (AKA the MBR) untouched.
There is usually a better way of removing a virus infection than
formatting the hard disk.
I hope this helps you
Posted on Jan 29, 2009
  • George Bill
    George Bill Jan 30, 2009
    I had a virus problem in a brand new acer laptop, and it was very hard to get out, I ended up it in safe mode and running adware pro, and avg pro, to get it out. You can get a trial version for the adware on the adware pro website. I read about some of the new variants earlier the day this happened, it just happened to be a dear friends laptop, so I felt responsible because I installed the OS and Software, but it couldn't have been more than a few minutes from the time I installed the OS to the time it picked up the virus. So if you don't want to re-install the OS, try running the virus program in safe mode. I saw from the post thst you were functioning ok in safe mode. Try it.
    President:
  • 2,110 Answers
Your registry is corrupted..try to restore the system...
  • 68 Answers
My suggestion will be a little hard work for u:
1. you already format and install the driver, in safemood its ok, so try not to install touchpad and quicklunch driver after formating.
2. Second option is try to format with other xp cd, maybe your cd is corrupted.
3.Hardware faulty is the hard one to diagnose, if you think the ram, the only way to test it is by replace it with other ram but i know it is not practical similar to hard disk. The only thing i know if it work in safemode mean two things - either your xp cd is uneffective/broken when install there will be missing file or some driver just not get along with your version of xp.
So.
1.try not to install touchpad.
2.if still the same, try to format with other xp cd.
3.maybe you can update bios but i'm just think it is not the problem: http://support.acer-euro.com/drivers/notebook/tm_4220.html
Posted on Jan 28, 2009
    Genius:
  • 1,550 Answers
Try to update BIOS .
It cant be faulty RAM section . It is only due to BIOS set up . You need to configure the BIOS properly .
  • Acer Master
  • 13,433 Answers
Hi since the computer works fine in safemode theres a problem in the full mode. in safe mode, try start -> run -> type in msconfig
Remove the check from load startup items, try starting up in normal mode again.
report back.
  • Ekse Jan 28, 2009
    use can use memtest to test your ram
    http://www.memtest.org/
    available on the above, page you will need to download and burn the cd image to a cd. with iso burner available on this page
    http://www.ntfs.com/iso-burning.htm
    See if the problem is with the ram, the issue may also be overheating, try canned air on the ventalation ports with the laptop turned off to get the dust out.
Hello, I still have a laptop "Acer Travelmate
no reason why it shouldn't
run this adviser there is also one for window 8 if you look for it
http://windows.microsoft.com/en-GB/windows/downloads/upgrade-advisor
Aug 08, 2013 | Acer TravelMate Computers & Internet
I need acer laptop extensa 4220 model webcam software for windows 7 ultimate x32
try thi link:
http://www.laptop-software.com/acer-software/acer-extensa-4220-windows-xp-7-drivers/
Dec 24, 2012 | Acer 4220-2346 Notebook
Where did i get all driver travelmate 3270? because if i reformat my aser some are not supported on window xp sp2...and every more all less 20min my lappy shut down automatically tnx in advance.....
Download the device drivers from the Acer WEB site. Makesure you select the model of your laptop the drivers you that require thatmatches the Windows version that is installed on your laptop. Use this link toget to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Jul 15, 2011 | Acer TravelMate 3270-6569 Notebook
Free download acer travelmate 4050 serios cl51 drivers
The only drivers available for this laptop are for Windows XP.
You can download these drivers directlyu from Acer:
http://us.acer.com/ac/en/US/content/drivers
From this page, choose "Notebook" then choose "TravelMate" then "TravelMate 4050"
You will see that Windows XP is the only operating system selected, and Windows Vista and Windows 7 are not selectable.
The two choices for Windows XP are XP Home Edition( 32 bit) and XP Professional Edition( 32 bit)
The drivers listed here are for:
Intel Chipset
Realtek Audio
ENE Cardbus
SMSC FIR( (Fast InfraRed) A high-speed IrDA protocol with data rates up to 4 Mpbs.)
RealTek LAN
Agere Modem
Feb 27, 2011 | Computers & Internet
Acer travelmate 3210
Acer Travelmate 3210 is the Series
and in that series your Laptop model is 3212NWXMI
like Acer Aspire 5300 is series and 5320 is the model number like that.
there was no need to update Bios
now in case your laptop is turning on
Please try to start in the Safe mode
and there you shut down your laptop properly and try Restarting in normal mode.
Secondly, If you are well versed with the technology then please
try to reinstall the Windows Xp
and BIOS update is something you should be very careful of.
do not try unless it is MOST required
Dec 30, 2008 | Acer Computers & Internet
Travelmate 290 starts then shuts down
please re install the recovery software.
Dec 10, 2008 | Acer TravelMate 290 Notebook
Laptop switch off automatically
u r hard drive didnot configured properly (it is in default)
go to cmos settings change hdd mode from sata to ata r some like that & save it
now try to re install.i will tell u tomorrow if u require.
Jul 21, 2008 | Acer TravelMate 2300 Notebook
Computer Freezes During Startup (Urgent!)
slamming the keyboard would jar the memory on the bottom or under the keyboard, and make this happen, inspect them both, and then restart it..
check your computers warranty here 4 FREE
Mar 15, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
53 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
