Question about Toshiba TE55T11 55" Rear Projection Television
TV turns off after lightning strike
I have a Toshiba TE50T11 (chassis TAC9955) rear projection TV that was struck by lightning. When I try to turn it on, you hear a click, and then the front LED blinks red. Once I got the set to turn on for a few seconds, and there was perfect sound, and a good picture, except that red was the only color in the picture. I have inspected all of the boards and there is no apparent burning or exploding of any of the components.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
Please post how many time it blinks, this does help us solve your problem.
Posted on Aug 05, 2007
Sanyo tv won't turn on after a lightning strike.
Ask friend if broken when given to you. If not I would suspect the power supply is fubar..
Sep 16, 2017 | Sanyo Televison & Video
Won't turn on. No click, no power light, nothing.
dear,
check its fuse first..yes, the basic thing is fuse..if its ok then we will do further..
regards,
Oct 12, 2008 | Toshiba 57H82 57" Rear Projection...
TV will not turn on.
you need to remove back cover and check for fuse, if burn try to replace if burn again check and replace power regulator.
Apr 03, 2010 | JVC HD-52G786 52" Rear Projection HDTV
My tv was struck by ligthning how do i fix it?
fixing the tv after a lightning strike is a higly specialized task, you have to deliver it to a qualified tv technician ,there is nothing you can do yourself to fix it
Jan 26, 2010 | Televison & Video
Tv struck by lightning
You wont be able to fix the TV your self as the power circuit board may have blown - consult a qualified repair man. Buying a surge protector for your expensive electronic goods is highly recommended.
Jul 10, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Will not turn on
Yes this would have damaged the tv IC"s and power unit of the tv you need get it serviced ...............
Jun 14, 2008 | Hitachi 60SBX72B 60" Rear Projection...
Color messed up on tv since lightning strike
your tv may have ben magnetized by the lightning strike.
tv's have an automatic degaussing circuit that demagnetizes
the pix tube when the set is turned on. this degaussing circuit
may not be working or magnetism may have been too strong for
the internal degaussing to correct.
contact local tv repair shop in your area see if they can manually
degauss your set , it should be a min. service charge around $25.
roland
Mar 22, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Lightning hit sony kv29xbr85
If it was me...I would first check the series of fuses on you main circuit board. Look for any burned components.
Dec 16, 2007 | Sony KP-46WT500 46" Rear Projection...
Toshiba TE50T11 Chasis TAC9955 won't turn on.
Based on the fact that when you remove the back and press on things making the set work for a while I would say that you have bad (cracked or cold) solder joints. If you can solder, disconnect power, remove the board (the one you normally have to press) and solder all the connections or at least any feed throughs, major power componnents and anything suspicious looking under magnification. If you can not solder you will need a reputable shop to look at it. Cost should not exceed $125 US. Good Luck.
Jun 18, 2007 | Toshiba TE55T11 55" Rear Projection...
This set is pretty common for the regulator IC to go bad. Its inside on the power supply Printed circuit boad assy. It will start with STR#### and have 4 digits after the STR####, depending on the model of the set. Good Luck
Jun 03, 2006 | Toshiba 51H93 51" Rear Projection HDTV
Toshiba TE55T11 55" Rear Projection Television Logo
145 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
