Question about Sanyo Transmax SC-150 Bagged Upright Vacuum
Need to change bag
I have been given this model vac without instructions; I have no idea how to open the vac to change the bag thanks for any help jatkowski
  • 944 Answers
Here's the link to the instruction manual; http://sanyoservice.com/pdf/images/SC-180E.PDF (it is for the sc-150 and sc-180) Check page 8 for details. Hope this helps :)
Posted on Aug 01, 2007
How do I open my Readi Vac model 36610 Vacuum to change the bag?
First, I'm not a RediVac or Douglas tech.
* Check your warranty. Call for service, support ;
*** the following is for information only ***
* Eaze Demo (and empty canister); https://www.youtube.com/watch?v=zQL5-7crJ9o
* Storm Demo; https://www.youtube.com/watch?v=TgBJ-azVA_I
* Difficult to locate company (Home vacs). May need to go to Amazon.com or Walmart.com for support.
* Amazon specs; https://www.amazon.com/dp/B005A3PT62
* Douglas Redivac bag at WalMart; https://www.walmart.com/ip/Douglas-Readivac-Vacuum-Cleaner-Filter-Bags-3PK-91051A/927082623
* Another source for bags (note questions line); https://www.ezvacuum.com/douglas-readivac-36600-36610-36610ds-canister-vacuum-cleaner-bags-5-pk.html
Aloha, ukeboy57
Jul 11, 2018 | Vacuums
I am trying to change the bag on my sanyo transformax 3in1 vac, cannot open it how do i open it?
This video may help you. Also you might find the manual at this site: http://homeappliance.manualsonline.com/manuals/mfg/sanyo/sc15m.html
Nov 16, 2016 | Sanyo Vacuums
So I just got my shop vac second hand and it has no manual and no basic instructions were given either. Does it actually need a bag when using it? I feel like something may be broken or missing....
Shop cacs are multiple purpose dry/wet intake so typically you don't need a bag. You just open the tank and empty it like a big trash can. They will have a large filter In the tank that needs to be cleaned/replaced.
Oct 16, 2015 | Shop Vac Vacuums
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
Bag needed changing there was no burn ing smell or strange noises before i changed bag after bag was changed it wouldnt start. the cord is new no fraying and vac is about 5 years old. didn
I'm not real experienced with this model vac, but I do know that many of the newer vac's are being manufactured with a small button or lever, whatever the particular brand of vac decides would best fit on their unit, that would be located somewhere around the edge of the bag door opening and would need to be depressed by having a bag inside in order for the machine to run. I would check for something of this nature to be sure that during the bag change that you didn't just miss putting it in quite right to depress the go button. Other than that, it's entirely possible that the switch died. If that's the case you'll need to bring it in to a vac repair shop for help.
Nov 11, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
Vac light comes on after i changed the bag
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
http://evacuumstore.com/
Apr 14, 2010 | Electrolux Lux 5500 Canister Vacuum
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Kenmore upright vac model 33922 - good suction but developed loud whining noise after accidentally vacuuming room without bag. Added bag and changed both filters. Still makes noise. How can I stop noise?
The bag is the first stage in your filtration. Most times what you did will draw fine dust right through the filters and into the motor itself, affecting the bearings and clogging the motor fans, throwing them off balance.
The fact that there is a new noise would seem to indicate bearing problems which will only worsen unless the vac motor is dismantled, fans cleaned and bearings either replaced or cleaned and repacked.
Sep 14, 2009 | Kenmore 33922 Direct Drive Bagged Upright...
Same Shut Off Problem as Hamster71
The part that you call the particle size sensetivity adjuster is bad. There are 2 seals in the assembly, the lower seal is slipping out of place because the plastic lip which keeps it in place is broken. Split housings and replace part. This machine is alot of work to take appart and get back together correctly. Might want to bring to local vac shop. good luck.
Nov 15, 2007 | Vacuums
hey just thought you might like to know that I have been given an answear on the same problem log in to get the info. Now I just need to know how to open it without breaking it!
Oct 26, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Sanyo Transmax SC-150 Bagged Upright Vacuum Logo
924 people viewed this question
Top Sanyo Vacuums Experts
ray gallant
Thatvacguy.com
Are you a Sanyo Vacuum Expert? Answer questions, earn points and help others
