Question about Compaq Presario Notebook
AC Adapter melting
I have recently purchased a new Ac adapter for my laptop. When I plugged in my laptop to charge the connection got so hot that it began to melt. This was happening with my old adapter as well, the overheating no the melting. This occurs both while the laptop is in use and while it is on standby charging. I don't recall hearing any fans to cool the system down either. Is this a problem with my laptop or the AC adapter?
  • Compaq Master
  • 32,281 Answers
It could be a fault with your laptop which is drawing more current than what the AC adapters can supply.
OR
The adapters are under too powered for your laptop.
Check the voltage and current rating requirements of your laptop, this information is printed on a label on the bottom of the laptop.
The adapter should have the same voltage and current rating or same voltage with a higher current rating.
Posted on Jan 30, 2009
AC adapter 4750z
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
If you need to buy a new laptop charger, the following to adapters are for your reference:
Replacement Acer Aspire 4750 AC Adapter 65Watt 19V 3.42A
Replacement Acer Aspire 4750 AC Adapter 90Watt 19V 4.74A
Nov 15, 2012 | Acer Pwr Ac Adapter For Travelmate 4750...
Is there a software that is associated with my sonny battery that will make it charge again
If you plug in your AC adapter to your laptop to charge the battery and get the "plugged in, not charging" message then try the following solution:
  • Disconnect AC adapter
  • Shutdown laptop
  • Remove laptop battery
  • Connect AC adapter
  • Power on laptop
  • Click the Startup Menu
  • Type Device and select Device Manager
  • Under the Batteries category, right-click Microsoft ACPI Compliant Control Method Battery and select Uninstall.
  • Shutdown laptop
  • Insert laptop battery
  • Power on laptop
    If you follow these steps and find that your laptop still does not charge then consider replacing the laptop battery itself.
    Hope to have been of assistance,
    Thanks.
  • Sep 14, 2011 | Sony VAIO PCG-K23 Notebook
    No turn on notbook compaq 1711t
    Hello The mandatory requirements before you try anything else are the main battery must be installed, it must work correctly, and there must be nothing wrong with the AC adapter or it's connection to the laptop. -Your model is recent enough the main battery must be installed - it won't start up on the AC adapter alone. - The main battery must be capable of being charged up to at least a minimal capacity. - The main battery does not last forever. Typically it works as it should for a year or so then begins to deteriorate - by the second year it can't be charged to anywhere near it's rated capacity. It gets worse as time goes by. Older batteries often develop internal shorts that makes it impossible for them to produce the voltage they're supposed to produce (you can test for that with a volt meter), and they may get HOT when you attempt to charge them for a while, rather than a little warm, or they may never get warm at all. - If you haven't replaced it since the computer was new, this model is old enough the main battery should be replaced! There must be nothing wrong with the AC adapter or it's connection to the laptop - if there is, the main battery cannot be charged properly. A common thing people do when they unplug the AC adapter is to pull on the cord rather than the plug on the end of the cord as they are supposed to do. Doing that eventually damages the plug and/or the wiring near the plug, and over a longer period of time, doing that damages the jack in the laptop the plug plugs into. The jack in the laptop should move when you wiggle the plug in the jack. Most laptops have an led that lights up only when the AC adapter is plugged in, there's nothing wrong with the AC adapter or it's connection to the laptop, and the AC adapter is charging the battery. That led should come on at least briefly when you unplug the plug from the AC adapter, then plug it back into the laptop jack, even if the main battery is fully charged. The led should not blink on and off randomlyIwhen you wiggle the plug in the jack. If that led never comes on, there is something wrong with the AC adapter or it's connection to the laptop, or the main battery is shorted (check it's voltage). If that led never goes out even after a long time, the main battery is probably no good - replace the main battery. The plug on the AC adapter cord can be replaced, but if you damaged it by pulling on the cord you will probably continue to do that at least part of the time, so since a plug molded onto the cord stands up to abuse a lot longer than a replacement plug, it's often a better idea to replace the cord from the AC adapter to the laptop if it can be unplugged at the AC adapter (a laptop repair place may stock that), or if that can't be done or you can't find that part, replace the AC adapter. The jack on the laptop can usually be replaced but that requires taking apart the laptop and careful removal and replacement of the jack. A laptop repair place does that sort of thing frequently, and often have the more common jacks in stock, though they may have to order one. Hope this helps, if so do appreciate my effort by rating the solution Good Luck, Cmptrlink
    Dec 31, 2010 | Compaq Presario 1711T Notebook
    New AC Adapter Will Not Charge Battery/Operate Computer
    Most probably static electricity killed some circuitry inside your laptop.
    Nov 12, 2009 | Acer Aspire 3610 Notebook
    Today my cord for my toshiba was behind my pillow and i was lying on it. and I didnt notice, but then it showed that my laptop wasnt charging did my cord just get too hot? will it work later?
    The power adapter does not have a temperature sensitive device, therefore it won't stop for overheating if not in consequence of a fault.
    Try leaving the power adapter unplugged for about ten minutes.
    In the meanwhile also remove laptop battery and put it back.
    Connect it back to AC and laptop.
    Ensure that connection to laptop and power cord connection to AC adapter box are both well plugged.
    Before turning on laptop leave it connected for few minutes.
    If laptop still does not turn on and battery does not charge, then the AC adapter is faulty.
    A further test can be done using a multimeter to read voltage on AC adapter plug.
    A replacement AC adapter is not expensive and can be purchased online. Try entering in Google your Toshiba model followed by the words "power adapter".
    Aug 15, 2009 | Dell Inspiron 5100 Notebook
    ZHow do I charge battery (new user)
    just plug in your adapter that came with the unit.....leave it for the recommended time for charging and there you go.....if you don't have an adapter...you'll need to find out the required power that it needs and then purchase an adapter that will supply the necessary power....and also of course, the plug must also fit the receptacle on the back of your unit...with the correct polarity......good luck
    silvio
    Jul 08, 2009 | Dell Latitude C640 Notebook
    Toshiba Laptop not Taking Charge
    ya the solder connection connecting the ac power input onto the transformer is probably weak. aside from taking the case apart and resoldering the connection, not much else you can do.
    Jun 18, 2009 | Computers & Internet
    Ac adapter does not connect to battery
    You either have a faulty ac adapter; a bad power supply in your laptop; a bad battery; or a blown LED indicator light.
    1. If the connection is not loose when you plug in your ac adapter try letting the laptop charge for a while. (If you are using the correct ac adapter)
    2. Try removing your battery and using the ac adapter. If this works the battery is bad.
    3. Try a new ac adapter.
    4. Power supply is bad
    Jun 05, 2009 | Dell Inspiron E1505 Notebook
    HP home edition ze2308wm keeps seitching from AC to battery
    The soldier holding the DC jack on the machine has broken loose. If you can, you should take it back to the place you had fix the jack and have them resoldier it. These are very small connection points, and if they don't get the soldier in there good, will break loose. It's a common occurrence, I've had it happen to a few of my soldier jobs, they should take care of it. Be careful with the way it is now, you can do severe damage if the connection point gaps and creates an electrical arch. I would suggest not using it until you get it fixed.
    Jul 15, 2008 | HP Pavilion ze2000 Notebook
    Compaq Presario Notebook Logo
    103 people viewed this question
    Top Compaq Computers & Internet Experts
    Alun Cox
    Abhinandan  Patil
    Abhinandan Patil
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
