Question about Toshiba TDP-T45U DLP Projector
Toshiba TDP-T45 projector doesn't recognize Macbook
The Tobisha TDP-T45 projector does not recognize my Macbook when I plug it in (it works with my Dell Latitude). I am using a Mini to VGA adapter (the same one that I use with my 22' LCD Hannspree monitor which is awesome by the way) to go from the Macbook to the Toshiba projector. Is the operating system just different and with therefore never work? Is there a different type of setting I can put the projector or the computer to make it work? Thank you.
5 Suggested Answers
  • 4 Answers
SOURCE: The color went out on my Toshiba TDP-T45
Color wheel failed. Clean the glass pieces out loose in the unit and replace the color wheel assy with Toshiba part no: 23125963. No soldering is required, just a no. 2 phillips screwdriver and and a set of jeweler's phillips screwdrivers like Radio Shack has.
Posted on Jun 24, 2009
  • 4 Answers
SOURCE: Toshiba tdp t45 dlp projector broken segmented colour wheel
23125963 is the Toshiba part number. Expect to pay about $65 on line. Google is your friend!
  • 74 Answers
SOURCE: Thin black lines: projector TDP-ET20
Do a factory reset to the projector. In my experience that fixes alot of image problems.
Posted on Sep 26, 2009
SOURCE: toshiba tdp-t90 projector. I rplaced the lamp on
set the beamer off, unplug the power line, press -on-/input/menue at the same time and plug the beamer to the power line again thereafter you can remove your fingers from the below mentioned buttons. now the lamp counter should be reseted to 0 hope this helps it works on a TDP-T100
Posted on Jul 22, 2010
  • 59 Answers
SOURCE: How to reset lamp timer
Reset the LAMP COUNTER HOURS:
1. Turn off the projector and unplug the power cord.
2. Press and hold down the three buttons at a time (ON/STANDBY) (MENU) and (INPUT) and plug in power cord.
3.The lamp hours counter will automatically turn to zero
4. Now you press POWER BUTTON and after warm up you check lamp operation counter in the STATUS display it should be "0"
Posted on Jan 25, 2011
How to reset lamp timer on Toshiba TDP-T45
Dec 27, 2010 | Office Equipment & Supplies
Toshiba TDP-T45 projector, groups of vertical lines across entire screen. Someone said try setup frequency to someone else with same problem but that person said it didn't work, then someone said replace...
the tube referred to is the light tunnel. which in your case is not the problem. unfortunately the only thing you can do is give it a good slap on the top 3 inches behind the lens for an unlikely long term fix, or try reseating the main board to the light engine. if neither work then the main board or the light engine is bad.
Aug 07, 2010 | Toshiba TDP-T45U DLP Projector
I am looking for a hardware that will allow me to install Toshiba TDP-T45 on ceiling.
you can get a universal ceiling mount from pc world or online at toshiba get any toshiba.
Feb 05, 2010 | Toshiba TDP-T45U DLP Projector
Sep 26, 2009 | Toshiba TDP-ET20 DLP Projector
I have a toshiba tdp-t45 and a Dell D600 how do I get the image from the computer to display from the projector?
Connect the toshiba tdp-t45 to the back of the D600 and then hold down FN and tap F8. This will transfer the video to the tdp-t45. If this does not work for the first time try the Fn and F8 keys 2 - 3 times.
Rate if useful.
Aug 11, 2009 | Dell X2033 - Latitude D600 D500 Inspiron...
Toshiba tdp-t90 projector. I rplaced the lamp on
Aug 02, 2009 | Toshiba TDP-T90 Multimedia Projector
The color went out on my Toshiba TDP-T45 projector. Watching the projector and heard sound and the color went away. What is wrong?
Apr 23, 2009 | Toshiba TDP-T45U DLP Projector
Toshiba TDP-T45U DLP Projector Logo
642 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
CheckitRight
CheckitRight
pkwc
Electro Med Services...
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
