Question about Siren Edge MP3 Player
Won't connect to computer
My Siren 4g was working fine. All of a sudden when I connect it to my computer (windows xp), the computer doesn't seem to recognize the device. It doesn't show up under "My Computer", although the device itself says "usb connected". I can't add or delete music. I have two identical players, and am having the same problem with both. My wife's player, connected with the same usb cable, works perfectly. My player will still play the music already downloaded to it. Neither player is anywhere near full.
  • 2 more comments
  • DWMILLS Nov 30, 2007
    I had the same problem . You must reinstall the cd that came with the siren player . The computer will not recognize it without it. Sirens website for support is way too cheap they do not even have the install cd on the site. They have have no downloads even though they have a download column. SO DONT LOOSE YOUR DISK AND COMPLAIN TOO SIREN'S WEBSITE..
  • Anonymous Dec 30, 2007
    Same problem. Siren won't let me add, delete or sync music.
  • Anonymous Feb 14, 2008
    1. i have restated my computer
    2. i have unhooked the device and retryed
    3. i have went to walmart where i had bought it and tryed explaing wht went worng
  • Anonymous Feb 22, 2008
    Same here ... My Xp does not " see " my Siren mp3 player anymore :(
Update your Windows media player
Posted on Nov 02, 2007
SOURCE:
Internet connection problem My older Compaq evo tower suddenly stopped connecting to the internet tried an other wire still nothing an even older computer connects fine what could be my problem
what Linux
non stated, of 100s.
why post lacking such key facts.
NO PC sated, just a nebuluas complaq.
no OS stated, just linux something
why not ask on YOUR linux forum.
try Ubuntu? yet?
best is to match PC old to Linux old.
but be impossible for me to guess what PC you own.
Mar 29, 2018 | Compaq Computers & Internet
Canon pixma mp470 won't print (doesn't talk to computer)
nancy try changing the user account on windows to administrator to refresh the user profile in the control panel settings of windows.
Why
I have come across this little gem of a windows bug and this fixed the problem. You may find your windows P.C does not print with MS office based programs !
Jun 18, 2017 | Office Equipment & Supplies
Alarm seems to work; been checked at Toyota but they say siren is broken and say it's a common fault. But everything else seems to work - you can hear the relay clicking; lights flash.
What is actually the problem, "Actually seems to work", what doesn't work.
If Toyota are on about the 9volt battery back up siren then the main siren may be working fine, but that might not be. Most cars especially Vauxhalls have a 9volt battery back up siren, so if someone tries stealing you motor and they disconnect the battery the 9volt battery will keep the siren going off.
Feb 19, 2011 | 1998 Toyota Corolla
My WL-138G cards loose connection info when shutdown
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 27, 2009 | ASUS WL-138G Wireless Adapter
I can't hear my Galls street Thunder siren model xs100.
bad output transistors or integrated circuit
Dec 29, 2008 | Radio Communications
Siren MP3 player not recognized by Windows Explorer‏‏
Installing the latest Windows Media Player solved the problem.
Oct 02, 2008 | Siren Edge MP3 Player
Everytime i try to download SKYPE on my asus Eee PC 4G operating on Windows XP it wont install. It does not recognize it as a windows program. How can i get it to work?
Try an older version and switch off auto update, the new version is too intrusive anyway, it installs it self everywhere in your computer.
I am using an older version and it works fine on my desktop and my wifes Eee PC 4G.
You can download an older version here:
http://www.oldapps.com/skype.htm
Sep 12, 2008 | Computers & Internet
Siren Edge 4 gig Boot error,
Siren's software support is bad, but you can call them: 254.224.0222
Sometimes reformatting a player can cause key system files to be lost - this particular mp3 player does not have a recovery tool or a firmware upgrade that I know of, so you can try the Windows Recovery Method: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Let me know how it turns out.
Jun 13, 2008 | Siren Edge MP3 Player
Different systems
windows media dont surrport mp3 u can play mp3s but thats it so dont use that. when u plug in the usb from ur mp3 player it should pop up new hardware found in the right bottom corner double click on that i should open up the mp3 folder after tat just click and drag the music u want in to that folder and ur on your way.
please rank
Dec 11, 2007 | Siren Edge MP3 Player
Siren Edge MP3 Player Logo
131 people viewed this question
Top Siren Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Siren Audio Player and Recorder Expert? Answer questions, earn points and help others
