Have had this vacuum several months, light never indicted it was time for a bag change. Decided to check. It's FULL. The "Owner's Guide" is useless, and I cannot get the old bag out. How is this done without the thin cardboard holder tearing off in my hands? It won't budge.
my oxygen has a little red lever on lh side of bag enclosure, that has to be pushed to left and bag then is free to be removed. make sure you have the correct bag to replace.
Was this helpful?
Yes
No
Popular Solutions for Electrolux Lux 5500 Canister
When I turn on my veacume cleaner it shuts off after 2 seconds of running. A red light comes on. It...
(More)
When I turn on my veacume cleaner it shuts off after 2 seconds of running. A red light comes on. It is not the ? light. If I remove the hose from the canister it runs fine. I have checked the hose for obstructions and there are none.
8 yr old system started making noise several months ago. Last week lost power but can still here...
(More)
8 yr old system started making noise several months ago. Last week lost power but can still here solinoide trying to click on. There is some black arching inside the unit on top of the filter. There seems to be a saftey switch inside that the filter holds in place, this is where the arching is. System will not now turn on??
Vacuum runs 5 or so minutes then shuts off indicating bag is full. Bag is not full and almost empty....
(More)
Vacuum runs 5 or so minutes then shuts off indicating bag is full. Bag is not full and almost empty. Have cleaned out hose so no blockage. Also put in new filter. Same issue. Each time it will start up but shut off quicker and quicker so that eventually it shuts off immedialty after restarting. Appears once it gets warmed up then it overheats and automatically shuts off. If you let it sit 30/60 minutes then you can run it for another 5 minutes or so.
