Question about White Sewing 2037 Mechanical Sewing Machine
Bobbin jumps out of place while I'm sewing and jumbles the thread. I took it to a repairman, it worked for about 3 weeks. Now, same old problem.
  • Anonymous Apr 15, 2009
    The bobbin will not stay in place while sewing. The bottom thread bunches and the machine will stop sewing.
I had a similar problem but found it only happened when I used plastic bobbins. I've been using metal bobbins and haven't had the problem again. Hope this helps.
Posted on Jul 21, 2009
  • 3 Answers
Take the white back to the store, purchase a Singer and never look back. White products are a piece of junk in my opinion.
Posted on Feb 11, 2009
Bottom stitch skips stitches
MY FIRST THOUGHT IS THE TIMING IS OFF A LITTLE. BEFORE SPENDING YOUR HARD EARNED MONEY FOR A REPAIRMAN TRY THESE POSSIBLE CURES:
1. TRY TO SEW WITH THE NEEDLE ALL THE WAY TO THE LEFT AND THEN TRY IT ON THE RIGHT. IF ONE OF THE TWO SEWS BETTER THAN THE OTHER YOU CAN BE ASSURED IT IS THE TIMING WHICH MEANS YOU NEED A REPAIRMAN.
2. JUST FOR GOOD HABITS DO THESE BEFORE GOING TO THE REPAIRMAN: CHANGE NEEDLE AND THOROUGHLY CLEAN THE BOBBIN AREA WITH CANNED AIR AND A QTIP TO CLEAN DIRT OUT. AFTERWARDS PLACE A DROP OF SEWING MACHINE OIL ON THE RACE THAT YOUR BOBBIN CASE FALLS IN.
3. PLACE TWO INCHES OF THREAD UNDER THE PRESSER FOOT. TURN THE HAND WHEEL TOWARDS YOURSELF AND WATCH IF THE UPPER THREAD WRAPS ON TOP OF THE BOBBIN CASE WHILE THE NEEDLE IS RISING. THE THREAD SHOULD PULL AROUND THE BOBBIN CASE WITHOUT CATCHING ON THE BRACKETS THAT HOLD THE BOBBIN CASE. IF IT DOES CATCH A LITTLE BIT YOU MAY NEED TO MOVE THE BRACKET AWAY FROM THE BOBBIN CASE ABOUT ONE PAPER WIDTH.
Jan 29, 2015 | Sewing Machines
I've had my singer simple 3116 for a number of yrs. For last few weeks I've had problems with the bobbin stitch, it sews fine for a few seconds then jumps & the stitches are a tangled jumbled mess , I've...
You may have a burr from an errant needle strike on your bobbin case or even on the bobbin itself. Check to see if there are any rough spots on or around the bobbin.
If you don't find anything, you may want to remove the bobbin assembly and clean the lint out from the lower assembly. Sometimes the smallest amount of lint or pieces of thread can cause problems with the bobbin.
You didn't mention if the tangled thread happens on the top or the bottom of the fabric. If it is on top, then it is a bobbin issue. If it is on the bottom, then it is an upper tension/thread issue.
Try removing the bobbin, thread, and needle. Rethread the entire machine using a different bobbin and a new needle. This may solve your problem. Good luck!
Jul 07, 2014 | Sewing Machines
Pixie plus bobbin housing
if you have the reciept for the machine, I'd take it back & get another one
maybe some place else
Feb 23, 2012 | Singer Pixie Plus Sewing Machine
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
I'm in trouble deep-I was trying to fix an old
Good day!
Good day!
Jun 06, 2011 | Toyota SE-06 Mechanical Sewing Machine
I cannot get the bobbin to wind on my Model 1260 Euro-Pro. It was working fine the last time I used it. Any ideas?
Good day!
Good day!
Jun 05, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
Husqvarna Model 215: My t-shirt material got jammed. I cut it out and then lifted out the needle, cover plate, bobbin and metal plate over the teeth. Then I took out the casing or whatever it's...
Good day!
Good day!
May 24, 2011 | Husqvarna Huskystar 215 Sewing Machine
Upper thread will not pick up the thread from the bobbin
1.check the needle & see if it's damaged
2.check the bobbin & bobbin case to make sure there inserted properly
3.rethread & try again
4.if the same thing happens,, it should be took to a service technican
Jul 29, 2010 | Singer CG590 Mechanical Sewing Machine
Will not sew
Had same problem with another Machine...I also have a cs 8072. it jumped time. any sewing machine shop can fix it in unser an hour for around $20-$30. Good Luck!!
Aug 17, 2007 | Brother CS-8072 Computerized Sewing...
White Sewing 2037 Mechanical Sewing Machine Logo
376 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
