Question about Frigidaire GLMB209D Microwave Oven
Over the counter microwave will start on first attempt
Either by auto timer or manual time it will not usually start first have - timer does run down but microwave is not on, I have to open door and push start button, open door push button etdc. anywhere from 2 to 6 times before it starts.
  • Frigidaire Master
  • 8,862 Answers
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
It's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Jan 29, 2009
My microwave stopped working you can input time but when you push start nothing happens it has power and everything just will not start its like the start button does not work
Possibly a bad door switch behind the holes where the latch hooks go into. Usually with the bad switch the timer counts down but nothing runs. It all depends on which switch is bad. Usually 3 switches inside.
Apr 13, 2015 | Sharp R530EWT Countertop Microwave Oven...
Turntable is not turnig
Check to see if your control panel has an on/off button for turntable and make sure its not off. If it still doesn't turn then the little drive motor may be bad. It can be accessed through the bottom of the microwave, usually through a small access door on counter top micros and by removing all screws around the bottom plate of over the range microwaves and allowing the bottom plate to hinge down. Unplug power before attempting this repair.
Mar 31, 2015 | Microwave Ovens
Cook works microwave timer stuck
If by "manual timer" you are referring to a knob that you turn to set the cook time, then you may have a failure of the motor that turns the timing mechanism, or a lack of power to it.
May 10, 2014 | Microwave Ovens
How do you stop, reset or change the remaining time on the Timer on the GE JES1142 microwave? Pressing Clear/Off does nothing. Do you just have to wait for the timer to run out? Manuel is wrong even on how...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Oct 27, 2013 | GE JES1142SPSS 1.1 cu. ft. Countertop...
After timer shuts down power, opening the door starts power up
for safty resons dont use it till you have it fixed
if there is microwave enegy flying around and it hits you you could get burnt badly
Jun 20, 2010 | LG 1.2 Cu. Ft. Mid-Size Microwave -...
JVM 2070 shuts off
My unit does the same thing - it will often simply power down or power down and display garbage on the control panel within a second or two of starting operation.  I have found in my case this seems related to slight obstruction preventing the exhaust hood from pivoting to the open position at the top of the unit.  Mechanical misalignment of the pivoting fan panel seems to cause a motor overdraw, or something similar, which shuts down the unit.  I've found that I can usually slide the pivoting fan panel a mm or so to the right or left, usually right (oddly), and then the panel will swivel unimpeded and the microwave will work.  As my unit has cabinets above it, I believe that over time there has been sufficient physical contact/impact with the pivoting exhaust panel to slightly deform it, affecting its ability to freely rotate down from the vertical.
Sep 24, 2008 | GE JVM2070 Microwave Oven
Help, my Panasonic NNA724M Combination Oven will no longer microwave. I can set the microwave going but after 20ish seconds the microwave stops and timer is replaced by the clock, without any audible...
This is an inverter model, and when they stop after 20 seconds, it usually means a problem in the high voltage section, either the inverter or the magnetron.
If you don't have experience troubleshooting high voltage inverters, I recommend calling a pro.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 01, 2008 | Microwave Ovens
Timer problem
Sounds like your timer board is fried. Replace it.
Dec 19, 2007 | Panasonic NN-T774SF Microwave Oven
New microwave not starting
Chances are the oven is designed for 60HZ and your supply is 50Hz. This will cause the unit to shut down because it thinks it is not getting the proper "interrupt" signal from the power line. You can check the owner's manual (or model number tag) and the manual for the converter.
Apr 20, 2007 | GE JES738 Microwave Oven
Frigidaire GLMB209D Microwave Oven Logo
83 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Electrolux
Electrolux
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
