Question about Dell Inspiron B130 Notebook
I changed my old cmos battery but still date could not be set. I do not know what to do? while starting the system I set the present date but this get changed when I off the system and the problem remains as it was?
  • 124 Answers
Check and see if maybe you didn't put the battery in reversed. The problem you describe is exactly what happens if your CMOS battery dies.
Posted on Jan 28, 2009
Toshiba portege m100 hardwares not starting
Yes the CMOS battery needs to be changed. Then you can go into the BIOS and set the Date & Time.
The CMOS/BIOS will be set back to the defaults when you remove the CMOS battery and this may fix your problems.
Sep 05, 2012 | Toshiba Portege M100 Notebook
Why do date and time keep setting to default?
Are you sure you replaced the CMOS battery with a fresh one? Did you install it backwards (the plus side should be UP). I've only seen a bad CMOS battery cause that problem. I would try one you know is new and check the installation.
Good luck.
Dec 27, 2011 | EliteGroup ECS H61H2M2 Intel H61 Sandy...
Good Morning Sir... My Mother Board Is DG41 WV In This System Problm Is Cheq CMOS Problem... So Iam Change The CMOS Battery... Again Smae Problem Phase... & CLR Cmos Jumper Changed Again Same...
If you've replaced the CMOS battery, set the date and time as well.
If the CMOS setting default to the very first date (1st January 20??), it'll automatically report the "Check CMOS" error.
Let us know if this works,
-BuzzPuppy
May 01, 2011 | Computers & Internet
Every time when i restart the system my Time is changing so how can i fix this problem
1. There is a coin sized battery present onto your motherboard, which is used to remember your computer CMOS/ BIOS settings as well as date and time.
2. If the system time keeps changing when your computer is turned off and started back, this indicated that your CMOS battery in your motherboard drained out of its charge.
3. Open you computer cabinet and locate the CMOS battery. Replace it with a new one similar to this.
4. Restart your computer and set the time once and it will be retained forever without any problem
I hope this is helpful to you.
Please rate the solution provided.
Thanks
Aug 15, 2010 | ASUS Computers & Internet
Error 00161 00163
[CHANGE YOUR CMOS BATTER WHICH IS INSIDE YOUR CPU CASE]
I do not think you fixed the CMOS battery - (backup battery = CMOS battery)
According to the error codes, you have a dead backup battery and the time is not set. Makes sense?
161
(Dead battery.) 1. Go to Checking the Backup Battery
2. Backup battery.
3. System board.
163
(Time and date were not set.) 1. Set time and date.
2. System board.
Go to www.ibm.com Find and download the user manual, and the "hardware maintenance manual."
Do you know how to get into bios/setup?
Start with the machine OFF. HOLD DOWN and CONTINUE TO HOLD THE "F1" key.
WHILE STILL HOLDING "F1", turn the power on, and CONTINUE TO HOLD "F1"
This will get you into the bios "setup." You should check the date, bootup order, etc, and reset.
I would check the "wire" you think you reconnected---you may just not have actually reconnected it.
The "hardware maintenance manual" shows you how to maintain this machine, and it explains the meaning of the error codes.
This will get you started on looking for the manual:
http://www-307.ibm.com/pc/support/site.wss/multiplefiledownload.do?validate=true
May 16, 2010 | IBM ThinkPad 380ED
How to connect cmos cables for this motherboard series?
The date and time are incorrect. The CMOS battery may need changing unless you haven't set the date and time.
Press either F2 or Delete on boot.
May 10, 2010 | Asrock 775i65G Motherboard
How to know if the battery of the motherboard is empty
use multitester to check the battery of the cmos..
set the multitester to DCV 10..
and watch out for the pollarity of the battery..
Mar 18, 2010 | EliteGroup ECS GF6100-M754 Motherboard -...
When I turn my computer on, I get an istant error message: CMOS setttings error. Any idea what to do?
I THINK YOUR MOTHERBOARD BATTERY MAY BE DAMAGED OR DOWN. YOU HAVE TO REPALCE THE BATTERY AND TRY AGAIN TO START THE PC.
Oct 03, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
I have a Dell dimension 9150 which is 2 1/2 years old. Does it have a battery that I need to be concerned about replacing. I remember that used to be a problem with computers but don't know if that is...
Every PC motherboard has a battery. That battery serves two purposes: to feed the configuration memory (also called CMOS) and to feed the real time clock of the computer (the one that show the date and the time).
An indication it is time to change the motherboard battery is receiving one of the following error messages when you turn on your computer: CMOS CHECKSUM FAILURE, CMOS BATTERY STATE LOW, CMOS SYSTEM OPTIONS NOT SET and CMOS TIME AND DATE NOT SET. Another indicator of a low battery is a clock that, after being set, runs well while the computer is on, but shows the wrong time when the computer is turned on the following day (it is late).
Apr 21, 2009 | Dell (2336V) Motherboard
Motherboard with mistake in the initialization
after changing the battery the problem is suppose to stop but since it continues i think u have to set the date and then save the changes made after saving cos is not all about changing batteries most times too the new batteries u just bought may be bad as well. so set the date and time then save changes i think it shoukld work well.
thank u
May 29, 2008 | ASUS P4V8X-X Motherboard
Dell Inspiron B130 Notebook Logo
83 people viewed this question
Alun Cox
