Question about Roper RGX4634KQ Gas Dryer
Roper Gas Dryer
My dryer was working fine, it rained, I covered the dryer, but it got a little wet. Now there is no heat in dryer. Gas lines seem fine, connected through a water heater. Please help.
  • 979 Answers
You may have gotten water in your igniter or pilot light. Put a hair dryer to the areas where the pilot and igniter and burner is so that it can be fried out.
Posted on Jan 28, 2009
Dryer seems to be working fine but not heating up on any cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 16, 2011 | Roper Dryers
My ROPER RGL4636BW2, isn't heating anymore. Everything else seems to work fine.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 17, 2011 | Roper Dryers
My roper dryer is not giving off any heat. and everything else works just fine. The dryer is only 6 years old. I also just cleaned out the lint trap straight through.
You did not say if your dryer is gas or electric. So if your dryer is electric go check out this electric no heat tip...
and if you dryer is gas check out this gas no heat tip....
heatman101
Aug 27, 2010 | Roper Dryers
The dryer is working but there is no heat. the gas line is open and all connections are secure. What else should i check?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 24, 2010 | Roper RGX4634KQ Gas Dryer
Clothes not dry but dryer turning. cleaned out
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 09, 2010 | Roper RGX4634KQ Gas Dryer
My roper gas dryer doesn't heat and the timer dial does not advance. I recently cleaned out the interior ductwork, it worked fine for a week, and then it seemed like the timer started becoming less and ...
heatman101
May 28, 2010 | Roper REX4634KQ Electric Dryer
Is ther a pilot light my roper rgs7648kq2 dryer is not heating up what could the problem be
All modern gas dryers use a hot surface igniton system(very old dryers had pilots). There could be a problem with the igniter,gas valve, ect. If you remove the bottom cover panel or inspection cap you can check to see if the hot surface igniter starts to glow when dryer is intially started. Just because the igniter does not glow does not mean that the igniter is the problem. There are two gas valves that work in conjunction with the ignition system as a safety(one could be defective). Also make sure that the gas connector at the back of the dryer is not restricted(kinked) and the gas line valve did not get shut off some how.
Sep 05, 2009 | Roper RGS7646KQ Gas Dryer
I have a roper gas dryer. The Timer stopped
my roper just stopped working this morning the timmer nor the heater or the dryer itself will not at all.
Apr 04, 2009 | Roper RGX4634KQ Gas Dryer
Roper Gas Dryer
The first thing I would check is the thermal fuse (#6 on the bulkhead parts break down diagram). Replace if it's open.
Also, the manufacturer recommended to replace the cycling thermostat (#8 on the bulkhead parts break down diagram) too if the thermal fuse is open.
- The part number for the thermal fuse AP3132867
- The part number for the cycling thermostat AP3131939
- Here are the break down diagrams for the Roper dryer Model RGX4634KQ2
"Did it solve your problem?"
Jan 28, 2009 | Roper RGX4634KQ Gas Dryer
Roper RGX4634KQ Gas Dryer Logo
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
