Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Fully charged battery. no response when key is turned to start
Worked fine yesterday.
where is the fuse?
  • terrymboyer Jan 29, 2009
    I downloaded the elec diagram and it turns out there are three safety devices that block started operation.
    first is the seat switch
    second is the PTO switch
    third is the clutch/brake device.
    this is ridiculous!. the seat switch is easy to locate and test but I have yet to find the other two plus those two safety switches do not show up on the factory parts diagram(only on the elec diagram)
    Model #917.270821
  • Anonymous May 06, 2009
    Engine willl not crank BUT when key is turned the electric clutch clicks only indicaton of power. Also disconnect lever will not disengage so I can push mower. It started yesterday but over night something happened.
  • 24 Answers
I like to start by making sure the starter gear not locked into the flywheel , this happens a lot on briggs take your hand turn the flywheel screen counter clock wise it will walk the gear down , you should be able to turn eng by hand now if not gas leaked into eng .
or eng is locked up.
Next I like to jump the starter solenoid to find it follow the heavy red wire from the battery it will led to it, there are 2 kinds 4 post and 3 post looks like you have 4 to test a 4 post unplug both small wires from the spades , you will need to small pices of wire hook one small wire to spade and ground it to frame of tractor now take the other wire hook it to the other spade and touch it to large stud that leads to the battery make sure you have parking brake set it may crank over, this by passes all safety switches and starter switch if it cranks over battrey good starters good solenoid is good .
safty switch on clutch pedal of mower deck engage switch not seat switch .
IF it does not crank over use a heavy wire or pliers jump large stud to large stud if cranks over solenoid is bad .
Posted on Feb 08, 2009
Sounds like a safety switch concern. Most mowers need the brake or clutch pedal depressed or the park brake engaged for power to go to the starter. Could also be the seat switch. My John Deere LT160 needs the brake pedal depressed or I can lock the park brake on and start it without being in the seat. Hope this gives you some ideas.
Posted on Jan 29, 2009
Electrical prob
batteries can be fully charged but fail under load conditions. have a load test done to eliminate the battery as a problem. Check for fusible link near battery and ING fuse near battery
Jan 10, 2015 | 2007 Kia Picanto 1.1
I checked all the fuses. No fuses are blown. The battery is fully charged & the electrical, lights, & radio all work fine. The 2004 Toyota Sienna van still doesn't even turn
Can be a bad contact in one of the cables. A bad contact in a switch or electronic switch. a bad relay, and a dozen other causes.
Please start measuring to where the power comes and where it stops. You are close to the car, we are not. For a correct diagnose use a multimeter and look under the hood.
Nov 20, 2014 | 2004 Toyota Sienna
No power to dash, key in ignition does nothing.
If I understand correctly, the headlights and brakelights work but the vehicle will not start and the dash lights do not work. That sounds impossible, so I'll merely suggest that you check the battery connectors and see that they are tightened down snug.
You should not be able to easily move them with a pliers. Sometimes, if you loosen them just a tad, and twist them a little, and retighten, you get better contact.
Jan 20, 2014 | Mazda 323 Cars & Trucks
Headlights not working, rpm gage not lighting up, neutrel light not coming on
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to Ignition
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a prime suspect please visit website below and good Luck.
Harley Davidson Sportster error codes and how to access them
Dec 15, 2013 | 2000 Harley Davidson XLH Sportster 883...
I have a 2000 Honda VTR1000F. Yesterday, I gave th...
a) Is your battery fully charged?
b) When you adjusted the idle screww, how many turn did you do?
c) When you tighten the chain, are you sure you have not overtighten the chain?
d) Disd you get the rectifier/regulator area wet when you were washing it, try to use compressed air to dry out all hidden nooks and cranny on teh bike.
e) Ensure your air filter box insides and element are not wet after washing the bike.
I hope those pointers can help you resolve your problem, as I strongly believe your main culprit is your battery charge more than anything else. Is suggestion good enough?
May 21, 2010 | 1999 Honda VTR 1000 F Firestorm
Vehicle ran fine yesterday. Today it wouldn't
This is going to sound strange but, have someone get over to where your starter is. While you try and start it have them tap on it slightly with a small hammer.
I t could be the brushes are hanging up.
Otherwise, I would pull the starter and have an auto center test it.
Please let me know what you find.
Feb 07, 2010 | 1993 Nissan Altima
Installed a new car battery yesterday and now the car will not start. I used jumper cables thinking that maybe the new battery wasn't charged enough,did not get a response at all. Could it be a blown fuse?...
It may be bad or dirty connections to the battery,starter or a fuse link located right on the wire to starter itself that is the culprit, make sure the battery is fully charged,clean all connections and then if problem persists inspect the wires from the starter solenoid for bad fuse links on wires, if all this fails to solve the problem replace the starter solenoid then the starter after trying a new starter soleniod.
Aug 21, 2009 | 1999 Ford Taurus
Murray 17.5 HP mower - no noise when turning key? Maybe ignition?
Look near the starter solenoid for a fuse. It is probably under the hood near the steering column. If fuse is good, problem is likely a safety switch.
May 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
766 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
