Question about Apple iPod shuffle MP3 Player
Headphone jack I suddenly lost sound to the left channel to any and all headphones I plug in. Right channel works fine, and everything is otherwise normal. I tried resetting, etc. so assume it is a problem with the jack itself. Is this a fixable problem in the first gen shuffle, or should I shed a tear and just toss my faithful (lightly customized - the edges were too sharp!) running companion and upgrade to a Nano?
  • David Brooks Jul 28, 2007
    New development: cleaning no help, but if I don't push the minijack plug all the way in I get stereo! All the way in, right channel only, half way out, right channel in left ear, 3/4 of the way in: stereo!
    Must be a loose jack...
  • Anonymous Nov 06, 2007
    hey mate,
    i have a similar problem, except when it is 3/4 way in, i dont get stereo, i get the right channel playing out of both left and right earphones. Therefore mono.
    Did you find a way to fix your issue? I havent tested for a dirty socket but i doubt it as these are 1 month old earphones.
Hi Guys!
I have had this problem for a while, but only while at work today I was listening to kanye west in mono and i felt like fixing it.
I have a solution to save you from spending $5 on a new 512mb ipod haha.
To fix my ipod, so that both earphones would play, I...
1) slide the panel on the back all the way up to switch ipod off
2) get a fingernail underneath the bottom of the slider, and wench the button off (takes a tiny bit of force and the slider shouldn't snap, although it does bend alot)
3) get a small amount of paper and fold a few times so that it is slightly smaller than the square of visible PCB (printed circuit board) (i used standard lined paper folder 4 times, so it is 16 layers thick!!)
4) place the folded paper on the visible pcb (making sure that the paper is not covering any of the plastic casing )and push to clip the slider back in to the off position with the paper underneath it.
and you done!
Hope i have help some people in the world, and done my part to make the world a better place hahah! tell me whether this worked for you, as it is only a temporary solution. :D
Dan
Posted on Nov 29, 2007
Same thing happened with mine. Looks like one side of the headphone jack has slipped. I have no cash or tools to go and fix this myself, so i put some aluminum foil on the side that the jack had slipped so it makes contact with the slipped side and with the headphones.. and it works perfectly fine now.
Posted on Mar 12, 2008
  • 64 Answers
I'd say upgrade, but a definite possibility is dirt in the jack. Take a sharp object and attempt to clean it out with a very lightly damp thin cloth. go in a few times, and it it comes out dirty, you have a shot(esp. since this might be garbage anyways) good luck, hope this helps! problem solved!
Posted on Jul 27, 2007
SOURCE:
My sennhauser 110 only work on left speaker ,nothing ,no sound on right?????headphones
The first thing to do is to disconnect the Sennheiser wireless unit and try another headphone, preferably a cable type and see if both channels work. If the sound is OK on both channels, the fault is within the headphones. If you are lucky it will be the wireless unit plug or the cable and can easily be tested and repaired by somebody familiar with electronics. Otherwise you will probably need to have it repaired by a service shop or a technician. I hope the guarantee is stilll valid.
Sep 16, 2015 | Sennheiser RS-110 Wireless Headphones
I plugged in my headphones and it only plays sounds on one side.
there is a head phone jack in the front and the back. have you tried them both?
Jun 15, 2017 | Dell XPS Computers & Internet
Suddenly there is no sound in the speaker but headphone works fine..laptop is Lenovo B575
If the head phone jack works its more likely to be the problem, if you use the headphone jack a lot the connections inside it can get worn or bent out of shape--engaging the headphone jack should shut the speakers in the unit off.
Other possible reason is a bad speaker or connections.
Dec 14, 2012 | Lenovo B575-1450A5U - IdeaPad Laptop / AMD...
Sp250 right outout seems to have broken and as a result there is no sound coming from the speakers on the keyboard or through the PA. If we use the left output through the PA - it works, Could you advise...
Check if headphone jack also has right channel dead... If headphones work on both channels, switch contacts on headphone jack MIGHT be the problem.
Jan 17, 2011 | Korg SP-250
My earphones suddenly stopped working all of a sudden. The sound in the left ear cut out and when I jiggled the wire and the connection a bit, the sound cut out completely. Now when I jiggle the...
Cutt the 3.5mm ********. You will need to cutt the cable about 10cm from the plug end to make certain you clear the damaged area. Buy a new Jack. You will need to solder the wires on. You will find when you have baired back the cable two coloured wires and two earths. The earths fit together on the metal flange that comes out of the main body of the plug. The coloured wires go on the the two smaller flanges (left and right channels). If you get them wrong way round reverse them you won't do any damage. Make certain the earths don't come into contact with the R & L channels wires or terminals and the left or right don't touch each other. The T shaped end on the large flange is to grip the cable body, bend the tabs to grip the cable.
Mar 20, 2010 | Skull Candy Lowrider Headphones
Sennheiser RS126 headphones/base stopped working
Broken audio cable entering the transmitter or audio jack plug.
Power supply plug loose / faulty power supply.
Nov 10, 2017 | Sennheiser RS 120 Consumer Headphones
ITouch 2nd g only plays music throuhg left side of all headphones
Try playing with the headphone plug, until you can also hear the right
channel and also try a different set of headphones as it is probably a
matter of an intermittent headphone jack, or plug, owing to sudden
snatching of the headphone plug from same, a very common problem.
Eliminate this cause before submitting your Touch for much more
expensive remedies
Apr 16, 2009 | Apple iPod touch
Headphones only have left channel on Denon AVR-588 Receiver
Hi peroty,
Two suggestions for you.
1. If you look at the headphone jack connecton do you see one or two black O-rings or black lines on the jack. If you only see one they are Mono headphones and you would only get sound out of the left side. If there are two black lines they are stereo headphones and you should get sound on both the left & right sides.
2. If after checking the headphone jack connection and there are two black lines on it then I would suggest try a different pair of headphones to see if a different set of headphones works fine.
If a different pair of headphones works properly the original headphones may be bad. If neither set of headphones work properly it may be the reciever that may need to be repaired.
I hope it's not the receiver, but let me know if you have questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Nov 25, 2008 | Denon AVR588 Receiver
No sound in rear speakers
I figured this one out, although I might still send it back for an exchange. It turned out that the right rear speaker works just fine, however the jack seems to be flawed. When fully plugged in, the rear speaker input only picks up the left channel. If you pull it out just a little, say 1/8-1/4 the way out it will pick up both channels. Not a good solution but it works for the time being.
Jun 03, 2008 | Razer Barracuda HP-1 Consumer Headphones
Apple iPod shuffle MP3 Player Logo
698 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
