Question about Panasonic ES 8077S Electric Shaver
Panasonic 8077 shaver top fastener broken
One of the button-click fasteners no longer grips the shaver head (the other side works fine).
I could send away to Panasonic repair site in Texas but they will not give me an estimate of repair cost.
What's the best way to go to fix this?
  • 1 more comment
  • rrpete1 Mar 28, 2009
    Partsstore.com seems to have most of the parts for this model but I don't have the part number for the broken plastic tab and in fact I am not sure what it is called. Tab, holder, clip, cap? Does anyone know the part number for this piece?
  • Anonymous Apr 02, 2009
    Unbelievable! I spoke with Panasonic and they told me that the button is called a foil frame release button and that it cannot be replaced. They obviously have a badly flawed design and are not prepared Their only solution is to buy an entire new shaver for which they will offer you a "generous" 10% discount. Some support! The take away lesson is don't buy Panasonic shavers period!
  • mattlinda
    mattlinda Nov 29, 2012
    panasonic es8077 Foil frame release buttons
    New Friend:
This may sound nutty. Please don't laugh. It works: attach a rubber band from the top "broken" corner of the shaver to the underside. Yup. Lousy design. Are you done laughing yet?
Posted on Jan 22, 2013
3 Suggested Answers
SOURCE: Disassemble Panasonic 8077 shaver
first put it up your butt and then turn it on to turn you on
Posted on Dec 06, 2007
  • 125 Answers
SOURCE: wet/dry Panasonic shaver stopped
Do you think a 1000uf, 25 volt capacitor will fit inside a shaver?
Posted on May 30, 2007
Trimmer of my Panasonic EX3833S is not working
panasonic es3833 replacement foil and blades
panasonic WES9979P combo set for electric shaver panasonic es3833 replacement heads.
panasonic WES9941P outer foil for electric shaver panasonic es3833 replacement parts.
panasonic es3833 replacement blades
panasonic WES9942P replacement blade for electric shaver part panasonic es3833 replacement parts.
Aug 25, 2013 | Panasonic ES3833 Electric Shaver
I have dropped my braun 8585 although in a bag. It is charged but just no longer works. I thought that taking the head off might reveal a broken connection but could not find a way further than removing...
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out.
Replacement parts can be found at shaveroutlet.com
Jun 27, 2010 | Braun 8585 Electric Shaver
Driver door unlock
Hello, my name is Ben. I believe I can help you with this. There are two possibilities, a faulty latch or a broken fastener on the connecting rod inside the door. Since it still opens using the inside handle, I think you have a broken fastener. Not sure of the proper name, but I call this fastener a swing away fastener due to the fact you un-clip the open channel shaped end and swing the fastener away from the rod. I am sending you a picture of one. If you find a broken one inside your door, try to take one of the broken pieces to the parts store since these fasteners are color coded for position. Also, this web site should help you with getting the inside door panel off to do the repair. Any questions, just let me know, good luck with your repair.
http://www.bodyshopzone.com/archives/trim/door_panels/Ford/Explorer_1999/front_rear_99exp.html94da444.jpg
May 26, 2010 | 2000 Ford Explorer
I do not know how to take each one of the 3 heads out in order to clean it
Hi. The shaver heads are not removable like on older models, you'll have to grip the grips on each side of the head and swing the top open to clean.
May 20, 2010 | Norelco Arcitec Electric Shaver with Jet...
Remington microscreen3 tct problem
I can only comment genericaly for this:
Most likely the internal drive shaft is defective. In some models there is a gear box. This may not be coupling correcty due to a failure. In any of these cases it will most likely need replacement parts to be reliable again. Your shaver should never fall apart!
You can call the company and enquire about where to send the shaver for service. Some of these companies have a flat rate fee for service. Look for your reciept to see if it is possibly under warranty. If the estimate for repair is too high, then you should consider a new shaver.
I would suggest for you to try getting a higher end type model. From personal experience and the research that I have done in the past, I found the Philips and the Panasonic to probably be the best shavers around at this time. You may pay a little more, but they are worth the few exra dollars for the performance and reliablity.
Jerry G.
Aug 24, 2008 | Remington MicroScreen3 TCT RS8986 Electric...
I have the same problem with my Braun 7570 as the Jan.8, 2008 writer about the 7526 or 7680 shaver. The blue button came off but the shaver still works
This button wears out or just fails with time, but is replaceable.
Braun 7526 Syncro Body Housing with Trimmer
$12.99, Fits Model: 7526, Type: 5493, Includes back case, front case with trimmer/switch, side grips and bottom 'plug', http://shaveroutlet.com/.
To disassemble the 7000 Series Braun shaver.
Disassembly of the 7000 Braun shaver is basically the same as the 8000 series Braun shaver listed below. The 7000 is actually easier to disassemble as the plastic is much thicker and the bottom socket cover pops right off as there are less tabs and they are bigger.
To disassemble the 8000 Braun Series shaver.
Remove the plastic cover on the bottom that covers the corded socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I usedmy fingernail to create a space big enough to insert the corner of a credit card in the center of the long side opposite the blue light indicator, then gently removed the cover. Using a screwdriver could damage the plastic.
The two sides then pop off, they only fit on their respective side when replacing. Don't lose the two small black seals on the top of each side piece.
There are a total of four screws holding the body together. Remove the screws, using the proper flat blade or torx screwdriver. The shaver will then split into. You can then remove the the Motor Drive Unit and the separate circuit board with the batteries.
This would also be a good time to clean the goo buildup from around the shaver head.
Assembly is the reverse of above. The Motor Unit will only fit in one way, there is a flat side and a angular side. Be sure the pin for the trimmer is placed in its proper hole, or it won't extend.
Jul 07, 2008 | Braun Syncro 7526 Electric Shaver
Blue Automatic Lock Button is broken
parts are not available at this time ,accessories are even dropping off
Sep 29, 2006 | Braun Syncro 7505 Electric Shaver
Panasonic ES 8077S Electric Shaver Logo
190 people viewed this question
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
gautam jha
Level 1 Expert
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
